Old 06-17-2007, 10:11 PM   #19
YarisGuy
Drives: 2006 Yaris
Originally Posted by fu_im_from_texas View Post
The velocity of air passing through the intake does not flow at a uniform speed. At the edges of the pipe the velocity of the air is 0 (theoretically), as shown in the figure below. For more info, do a google search on "no slip boundry condition" or "velocity profile."
The MAFsenser is calibrated for the velocity of the air at the center of the pipe...
pm me if your interested in suggestions to maximize air flow...i have studied the topic extensively...
Excellent post. Thank you for the pics!
It's a red yaris
YarisGuy is offline   Reply With Quote
Old 06-17-2007, 11:17 PM   #20
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Clarification: Center measured along the diameter, not the length...
This is more clear than my statement, but is exactly what I meant.
Old 06-17-2007, 11:53 PM   #21
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
yea but like what was noted before, the stock maf sensor is located in the upper air box lid. So your thought of the maf HAVING to be located in the dead center of the piping isn't entirely accurate. It may be perfect in a perfect world, but we all know it aint true.
I unhooked the battery lastnight and it threw a code on my first decent trip this morning which was less than 30 miles....
when i try and check the code, my little unit doesnt give me anything. I doubt the maf being mounted upside down makes any difference, yes it is flowing in the same direction as stock. I made sure I kept that the same.
chino, if you have any ideas for me as to why the cel light is coming on id really appreciate it. If you need me to take more pics just let me know.
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 06-18-2007, 01:19 AM   #22
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Talking shameless self-pat on the back
i think the maf wont see as much air, the computer will see that the airflow falls outside the acceptable tollerence, and a code will be thrown...
Originally Posted by 07typeS View Post
...it threw a code on my first decent trip this morning which was less than 30 miles....
if i get any better at predicting the future, im going to have to apply for a crystal ball permit...
fu_im_from_texas is offline   Reply With Quote
Old 06-18-2007, 01:54 AM   #23
Black Yaris
der Zeck
Black Yaris's Avatar
Hmm.... same problem I ran into while trying to modify my TRD intake.... How about we just wait for Chino
Old 06-18-2007, 07:32 AM   #24
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Originally Posted by PetersRedYaris View Post
Nice job. What is your MAF sensor mounted in? In case you didn't know, it needs to be mounted so the actual sensor is exactly in the center of the pipe.
More than correct!
Old 06-18-2007, 10:02 AM   #25
07typeS
07typeS's Avatar
lol, all of you guys telling me it has to be mounted dead center of the pipe, go out and take a good look at where the maf sensor is located. Its mounted on the airbox lid, not on the 2.5" accordian tubing, so that theory shoots it out the window....
I open for ideas though, maybe the maf sensor has to be located a little closer to the throttle body? because of the open air filter? thats something i may try...
Old 06-18-2007, 11:26 AM   #26
RShatchback
Drives: 07 yaris liftback
Dont give up - you should def. try to move the location of the maf, youll get it..
Car forums are kinda like the public library - somepeople are just checking stuff out, and plenty of other people are just telling stories...
RShatchback is offline   Reply With Quote
Old 06-18-2007, 11:43 AM   #27
Black Yaris
der Zeck
It is not on the according tubing because the actuall air source is under the headlight.... like I said it was a similar problem I had while trying to modify my TRD CAI into a short ram... I kept throwing CEL because the MAF postion was for long tubes..... I am not saying I am an expert, I just know what does not work, can't tell what will
Old 06-18-2007, 12:18 PM   #28
fu_im_from_texas
Drives: Liftback
Smile air is incompressable, you can measure anywhere along the length
you are right when you say a square duct does not equal a circular tube. however, air at standard tempature and pressure can be treated as an incompressable fluid. incompressable fluids have constant volumetric air flow. the maf (in the stock location) measures the flow at the begining of the accordian tube (even though its actual location is in the air box)...which is equal to the air flow at the middle, and end of the tubing.
so, even though the maf is mounted in the air box (shaped like a square) it is actually measureing the airflow at the beginning of the center of the tubing (shaped like a circle)...clear as mud?
hope this is written clearly, and helps get you back on track...driving around in limp mode with a cel sucks...
Old 06-18-2007, 02:24 PM   #29
PetersRedYaris
[QUOTE=07typeS;99176]lol, all of you guys telling me it has to be mounted dead center of the pipe, go out and take a good look at where the maf sensor is located. Its mounted on the airbox lid, not on the 2.5" accordian tubing, so that theory shoots it out the window....QUOTE]
Tube length aside, you need to go take your airbox lid off all-together so you can see that it IS mounted exactly in the center (center of diameter) of a plastic tube formed within the lid. Disconnect the accordian style tube and you will see the tip of the sensor dead center.
Old 06-18-2007, 09:01 PM   #30
Motorhead6T5
Motorhead6T5's Avatar
Drives: 07 NCP96
[QUOTE=PetersRedYaris;99270]
+1 you could even cut the stock one out to make a maf housing for a cold air intake,if you cut in the right spots it would be a 2.5" diameter tube. Check it out. Just like with the 05 stangs,if you mess with the maf housing size,you need to reflash the ecu with new map. If you want a cia and you want it to work its going to come down to the maf diameter needing to be excactly the same size as stock,till they come out with a reflash device for this car.
Motorhead6T5 is offline   Reply With Quote
Old 06-18-2007, 11:32 PM   #31
07typeS
07typeS's Avatar
Thanks everyone for the positive comments, i think i may be hacking up the piping i got and moving it away from the filter and closer to the throttle body. I think fu im from texas is right that its seeing too much of the atmosphere and not so much of the turbulance of the incoming air....
unfortunately when doing an sri, you dont have too much room to work with, but I will definately give it a shot...i aint done yet...I wanna R&D this, even if it gives all of us a way to custom make a working intake that wont throw codes....
I aint trying to outdo chino in no way, im not nearly on his level. But i got some inspiration from his attempts. If anyone else has some knowledgable advice, bring it on.
Old 06-19-2007, 01:03 AM   #32
ChinoCharles
Drives: LB
How about a picture of where/how you have the sensor mounted? Can't see a thing in any of the other pics.
Old 06-19-2007, 09:56 AM   #33
07typeS
07typeS's Avatar
chino, if you look at the 2nd picture at the bottom of the tubing about an inch or 2 away from the filter, you can see the maf harness and plug. Thats where it is, id say its roughly 1-2 inches from the filter and that may be too close.
So what im gonna do is hack out that middle part between the vacuum line and the maf, leaving enough room on the ends for couplers, and swapping the section with the maf and the piping....
what do you think?
Old 06-19-2007, 10:03 AM   #34
07typeS
07typeS's Avatar
I went to check out weapon r's site and I noticed how close the maf is to the throttle body. I think thats gonna be my answer right there.
Old 06-19-2007, 10:19 AM   #35
ChinoCharles
Drives: LB
what do you think?
So wait, you're going to use four couplers?
Old 06-19-2007, 10:27 AM   #36
07typeS
07typeS's Avatar
Actually it would be 3, one at the throttle body, one between the vacuum'd pipe and maf, and one between the maf and the pipe to the air filter....
Like I have said a million times, this is just a tester piece to get a working intake, after I get the placement of the parts I can do some research on how to get it into one piece or two pieces max.
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
Intake VS modified filter housing Spades Performance Modifications 19 03-30-2007 12:30 AM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
