Old 08-15-2007, 05:44 PM   #19
cdydjded
Drives: Yaris LB Turbo
I am hoping to done by the end of the month.
cdydjded is offline   Reply With Quote
Old 08-15-2007, 05:50 PM   #20
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
what are you going to tune it with?
stock fuel pump? Anything to boost fuel pressure under boost? Injectors??
Turbo&Auto is offline   Reply With Quote
Old 08-15-2007, 07:09 PM   #21
Removing the O2 sensor throws the ECU into "limp-home" mode. In this mode, it is too busy trying to keep your car running and no longer learns/overrides the piggyback management (E-manage, for example).
It's an OK workaround, but I think there must be a better way.
Old 08-15-2007, 07:26 PM   #22
johnnyfive
johnnyfive's Avatar
there will be a better way...eventually...but as to who is going to step up to the plate and work on it...that i do not know ;)
Old 08-15-2007, 07:27 PM   #23
punch
punch's Avatar
we need something from toyota, to replace the computer with... on my pt cruiser mopar stage 1 kit, replaced, and removed alot of the engine management, eg check engine lights, o2 sensor reading etc...
out of respect for nutzoid, I changed my avatar.
Old 08-15-2007, 08:32 PM   #24
Who was the member on here who got 142 bhp by balancing the motor, porting/polishing, etc., all N/A?
Old 08-15-2007, 10:39 PM   #25
joey1320
joey1320's Avatar
Drives: Yaris LB
Originally Posted by cdydjded View Post
About the CEL, I would like to know with the 2 guys that have the ZPI kit why they removed the O2 sensor? Also if they tried to use a O2 simulator.
well one was spkrman but he is no longer a member and the other is turboyaris, but he doesn't come by here much often anymore. i talked with him before about this same issue and he told me that zpi just removed the front o2 sensor and tuned the car as best possible with the emanage.
Old 08-16-2007, 08:49 AM   #26
Nabisco
Nabisco's Avatar
Drives: '08 Honda Fit Sport
Send a message via ICQ to Nabisco Send a message via AIM to Nabisco
Wide band data logers such as the Zeitronix kit has a simulated narrow band output for the ECU. This is only good when the unit is being used to data log. However I recall on some other Toyota forums there is a circuit you can build that will put a load on the o2 circuit so the ECU doesn't throw a code.
Another option: A resistor that makes the ECU think that there is an o2 sensor there, without ever varying values, so the fuel system will not ever account for unburned fuel hydrocarbons, the car may not enter closed loop mode, your fuel economy will suffer, and your catalytic converter will eventually die a premature death, possibly by slagging down and burning.
I think neither are sufficient. We need a donor ECU!
Nabisco is offline   Reply With Quote
Old 08-16-2007, 09:39 AM   #27
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
the resistor on the O2 is for the heater circuit to fool it that its heating something. Its 2 10K 10watt resistors in series I believe.
Old 08-17-2007, 09:16 PM   #28
elsteverino889
elsteverino889's Avatar
Drives: 2007 Yaris sedan black
Ay i just read you live in Miami? Do you go to any hangouts or what? FINALLY some miami pride in this forum!
I was 17-20 I lived the "Lifestyle". Fast cars, skanky hood rats, and stupid kids trying to prove who was faster. -Spades(the one and only street racer)
elsteverino889 is offline   Reply With Quote
Old 08-18-2007, 09:37 PM   #29
joey1320
joey1320's Avatar
Drives: Yaris LB
the o2 sensor sends a return voltage signal to the ecu to let it know what values is reading, a resistor may not be able to help our cause.
Old 08-19-2007, 12:23 PM   #30
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
TSK , TSK , TSK . I love it when people THINK they can 1 up the engineers who designed the cars , but I hate it when they ruin a perfectly good car .
First of all the pistons , rings , rods , crankshaft and bearings will NOT hold up for long .
Secondly , what about all that heat . Remember the ECU is in the engine bay . NEXT to the exhaust manifold ................
THIRDLY and the BIGGEST mistake that damn near everybody makes , what about the OIL COOLER . You can NOT have a turbo car without an oil cooler . You will need a higher flow oil pump as well . Ask yourself , "How many turboed hondas have you seen blow up " , answer , "ALL OF THEM" b/c they forget the OIL COOLER . Don't kid yourself .
If you want a fast car , buy an EVO or STi . If you wanna make your Yaris faster , sign up for one of the many High Performance Driving Events (HPDE)around the country . Granted some HPDE's are better than others , but it is a much more sound investment of your money . Also you WILL become a better driver (which in turn will save money on insurance) and you will probably make some kool new friends .
All of my students say the same thing " Holy Shit I didn't know my car could do this ". I took my future daughter in law to the track for her first time last weekend . At first she was timid . By the end of the day the guy in the M3 was almost passed by a woman in a YARIS . Luckily for the guy in the M3 there was a very long straight , but then we would reel him right back in when we got to the twisty section .
Like my buddy says " Straight roads are for fast cars , Curvy roads are for fast drivers "
Old 08-19-2007, 01:18 PM   #31
True about the oil cooler. True about driving skill. NASA (HPDE events) is a terrific organization and great place to improve driving skill (I'm a member).
However, I will respectfully disagree that a stock car cannot be modified to have more safe, usable power. Done right, it is not always "ruining a perfectly good car". I dislike generalized comments like this.
Old 08-19-2007, 02:34 PM   #32
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I also dislike comments like this. As much as I believe in driving skills, at some point, it's just fun to see what can be done with a small-displacement low-weight automobile. With the increase in power provided by a turbo, the Yaris will not only be able to hang with the big boys in the twisties but also in the straights. The engine management needs some work but once it's cracked, we are going to see some serious power out of this little engine. And it's going to be reliable power, and yes more power would be made with a built engine, and who cares if it's front wheel drive, and it's going to be so much fun walking a car with twice our horsepower.
Galavoxx is offline   Reply With Quote
Old 08-19-2007, 03:09 PM   #33
joey1320
joey1320's Avatar
Drives: Yaris LB
i can understand where you are coming on most points but i personally know of 4 turbo Hondas runing without oil coolers and they have been daily driven for at least 3 years and with more than 45+K miles and still runing great.
and i know because i was the one who put them together for my brothers and friends. they all had pass 60k miles on the engines and are all over 100k miles as of right now and no problems at all.
Yes, people do think they can one up the engineers and usually fail miserably, but then theres times when you can make a car better by adding a small amount of power and better handling(which could had been done at the faxtory) and end up with a fun car.
oh btw i'll be using an oil cooler on my turbo build.
Old 08-19-2007, 03:29 PM   #34
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
I never said that you could not modify a car to have more safe , usable power . In your own words , if done right . Just that most people don't think things all the way through . They get blinded by greed of power . I also like small displacement cars . That is why I only build 4 cyl and rotary cars . One more thing to keep in mind , whatever we do to our cars , the big boys can also do to their cars ......
Old 08-19-2007, 03:32 PM   #35
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
So true.
Old 08-19-2007, 03:50 PM   #36
joey1320
joey1320's Avatar
Drives: Yaris LB
cool, it just sounded like you were completely putting down the idea of a turbo yaris, thats all.
so you are also into rotaries? me too. hopefully i can get my hands on a Datsun 1200 so i can swap in a 12A next couple of years. but those chassis are so hard to find in good condition...
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
Garrett Turbo kit elsteverino889 Forced Induction Forum 24 04-20-2007 10:27 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
Turbo Kit Teaser Pics cdydjded Performance Modifications 27 01-31-2007 12:58 AM
