#1 | |
![]() ![]() ![]() ![]() ![]() Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
Thanks for your experience with the exhaust. I'm thinking 2.25", since it will be crush bent, would be my best bet. I found a place that will do the exhaust with a day or two notice. I'll probably make an appointment for the beginning of the week.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ |
Too cool
#3 |
#4 |
The actual bolt fastened badge is a unicorn on these shores. May have to buddy up with one of our UK friends to arrange an acquisition.
Sent from my EML-L09 using Tapatalk
#5 |
Excellent idea! May have to make a post about it.
#6 |
2nd Test Drive and Exhaust Work
I went out for another drive this evening and I'm impressed. Took it out on the highway and found the steepest hill I could. I set the cruise control at 120 km/h. With the 1NZ and cruise set, it would always drop a gear. The 2ZR powers up the hill without a gear drop and not even a detectable increase in rpm. Awesome!
I was under the back of the car rigging up a bungy cord on the hanger to stop the clunking just for tonight. I had a look at the midpipe and I'm thinking I ought to have the exhaust shop chop the pipe at the resonator and upsize the pipe to the rear flange at the axle. Maybe to 2" or 2.25". I know that my muffler will be much more free flowing than the stock muffler, but I can't help but think that that midpipe is really restrictive. Taking into consideration what you have all said - and done - as well as reading a thread by 'the barber', I'm thinking this is the route to go. I've heard that a freer flowing (maybe too free-flowing) exhaust can adversely affect torque and I wouldn't want to lose any of that. Thoughts/comments welcome as always.
#7 | |
#8 | |
#9 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
I did an extensive amount of research on this topic back when I did my swap too. I ended up using a magnaflow resonator and muffler, and 2.25in piping. The 2.5in pipe is where you start losing torque according to the internet dyno charts.
I have a video of my dyno run as proof that I didn’t loose any torque |
#10 | |
#11 |
Data doesn't lie
Also
If you find those TS badges I’ll buy one for everyone on here with a swap. It’s the least I can do to show my appreciation for all the support of everyone here. |
#12 | |
I will keep looking and let you know if I come up with anything.EDIT: Following up on a lead now. I've emailed a UK eBay seller. Will let you know. I need to confirm if this is what we're looking for: https://www.ebay.co.uk/p/Toyota-7530152010/652635220 And this, but with different coloring and part number (and actual pic of back): http://vi.raptor.ebaydesc.com/ws/eBa...29206000&ver=0 I can only find pics of the front of the badge online. There is a cheaper one (4.99 pounds) but I think it's a sticker. The listing above refers to placement on the front of the car.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-08-2018 at 06:22 PM. |
#13 |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
Torquey == broke loose in 3rd gear this morning; yes, it was wet..
![]() Glad to hear you're enjoying the new found, smooth power of the 2ZR! -- Adam |
#14 | |
I am definitely loving the 2ZR. Car feels a lot lighter.
#15 |
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
An alternate part number for that badge you're after is
75312-52060 Im not sure what the differences are but both badges can be had for $30 AUD from amayama.com Can get pictures from the parts catalogue this evening if needed. :) |
#16 |
Thank you, Stidnam! Just checked that out. Definitely a possibility. It looks like shipping would be killer from no matter where.
#17 |
Not sure how much shipping is coming to for you, but 5 of those badges shipped to my address in Aus is only $8.50 AUD
#18 | |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
