Old 03-02-2014, 12:51 PM   #361
jasonk1123
Drives: Toyota Yaris 5 door hatch
Hi CTscott
I have tried to place a led light in there, i earthed the one side and shoved the + side in the whole, it did not come on...
must i try it with the + side on battery and shove the - side in there? The reason i am using the LED because i dont have a meter hereXD
jasonk1123 is offline   Reply With Quote
Old 03-02-2014, 01:22 PM   #362
jasonk1123
oops double post:)
I have tried the + and - and cant get the light to shine:(
Oh well at least I tried... Now it is time for me to find a suitable cc for my Yaris. If anyone has any sudgestions let me know, Thanks a mil
Old 03-02-2014, 02:04 PM   #363
If you can get your hands on a voltmeter try that instead. The +12V on that pin is not intended to source current, but rather is just a high impedance ADC looking for the various resistances fed by pressing the different switches on the stalk.
Old 03-02-2014, 11:10 PM   #364
jasonk1123
ah so there is hope.
Will test it today and let everyone know
Old 03-03-2014, 05:21 AM   #365
jasonk1123
Ok so I got 0.3 DCV, it was steady like not dropping or anything. what should i be looking for?
Old 03-06-2014, 09:33 AM   #366
Originally Posted by hockysa View Post
Hi is there any information anywhere on these installs?
I've acquired a second hand AP800 and want to install it on my Yaris and have figured out the wiring except for the accelerator pedal.
Like I asked on your other thread - What year is your Yaris, as that makes a difference in the wiring?
Old 03-06-2014, 10:02 AM   #367
oh sorry didn't see a reply
it's a 2007 Yaris
OK. The accelerator pedal has a 6 pin connector.
1 - White: VCP2 (Sensor 2 power)
2 - Brown: EPA2 (Sensor 2 ground)
3 - Light blue: VPA2 (Sensor 2 output)
4 - Black: VCPA (Sensor 1 power)
5 - Green: EPA (Sensor 1 ground)
6 - Red: VPA (Sensor 1 output)
I haven't seen the install manual for the AP800 for the Yaris, but looking at the pinout of the AP800 it has a high and low throttle position sensor connections.
On the Yaris the VPA signal would be the low one (2.6 to 4.5 V at full throttle) and VPA2 would be the high one (3.4 to 5.0 V at full throttle).
Old 03-06-2014, 11:07 AM   #368
Awesome that's perfect
thanks!
you don't also happen to have the same thing for a 2006 Corolla do you?
It's also a 6pin plug but different configuration
*edit*
also where did you find it?
because I've been searching for hours and got nothing
*edit edit*
just googled corolla VCP2 and found it :S
I don't have the info for the Corolla, but the pinout order is likely the same with just the wire colors being different. You can verify that by measuring the voltage on the pins where the "power" pins should have 5 volts on them and the grounds zero.
I found a manual for the aftermarket cruise online, but it was not for a Yaris.
Old 03-06-2014, 07:50 PM   #369
Yeah I thought the same too but the order is different
yeah? could you link it to me anyway please?
http://nicolas.bct.free.fr/Regulateu...rateur_HDi.pdf
I ran into the diagram for the 05 Corolla and it shows:
1. Yellow - EPA2
2. White - VPA2
3. Yellow - EPA
4. Black - VCP2
5. Green - VPA
6. Black - VCPA
Old 03-07-2014, 10:00 AM   #370
omfg so lame... followed instructions to calibrate and now it doesn't work fml
linked the manual I was using
http://www.lupo3lklub.dk/pdf/AP900C_...ion_Manual.pdf
my unit is actually an AP800 but the seemed to have replaced that with a 2 in 1 type unit the AP900c
Will it respond to the "Diagnostics mode" listed in the manual?
Old 06-21-2014, 04:31 PM   #371
The_Ghostrider
Drives: Yaris TS 1.8
Since the car is built with a spiral cable that does not have enough wires to support cruise control, it is unlikely that the ECM is programmed for it.
In doing a bit more research on the Axio Fielder, the ones with the same engine as the Yaris (1NZ-FE) do not support cruise control, but the ones with the 2ZR-FE engine do.
Hey CTScott,
maybe it is again a stupid question about the cruise control in the european Yaris XP9.
I read that you have not found any model in the EWDs which has CC built in.
Pointing to the above quote I post it to clarify for myself. Because all my trials on the net gave only answers for the smaler engine types.
In my case it is the TS 1.8 (2ZR-FE engine) with the ECM 89661-52F30. So far as I could investigate built only for Europe and Japan.
Additional: This car was only built in Japan, so maybe this is a chance to have CC programmed.
If it won't be in I am going probably with the ROSTRA 250-1873. The European solution will be more than double priced (waeco magicspeed ms-880).
Thanks for your work here it is an outstanding platform with a lot of useful stuff.
from Germany
The_Ghostrider is offline   Reply With Quote
Old 03-20-2015, 03:22 AM   #372
Gitaniio
Drives: 14 sedan
Hello CTScott, I know you said that only cars with US/Canada specs support CC, but I need to know if my 2014 yaris with mexican specs supports it since the car appears to be fully wired (the d3 has the black wire for the horn, the blue and brown for the CC and aparently 3 more wires for audio controls). It also appears to have the CC indicator on the instrument panel along with the vsc/trac which is not an option for sedans in mexico. Is there any option for me in case OEM CC can't be installed? I take highways a lot and it's not fun for my leg.
Gitaniio is offline   Reply With Quote
Old 03-20-2015, 06:24 AM   #373
Yes. Mexico spec cars are the same as US spec ones, so it will work for you.
Old 03-20-2015, 11:29 AM   #374
Gitaniio
Drives: 14 sedan
I tried to test the CC with a two switch set from one of your tutorials but nothing happened, then I tried to bridge the blue and brown cables and nothing. I did the tests because I don't want to buy the stalk and the wire without knowing for sure if the car's CC is enabled. Am I doing something wrong? Is there any other way to find out?
Thanks for answering!
Old 03-20-2015, 04:27 PM   #375
Check for the presence of the blue wire on the ECM connector. The ones from the steering column may only run to the junction block under the dash top.
Old 03-21-2015, 04:51 AM   #376
Gitaniio
Drives: 14 sedan
There's nothing in the 40 pin, should I test it with a voltimeter? If so, please tell me the right steps to do it because I don't want to set the car on fire
Old 03-21-2015, 06:20 AM   #377
If you pull the rubber plug you can stick a small piece of wire in the hole to take the voltage measurement. Turn the key to the on position and take the measurement with the red on that wire and the black lead on a ground.
Old 03-21-2015, 07:47 PM   #378
Gitaniio
Drives: 14 sedan
Unfortunately there was no voltage there. Is there any other way to install a CC in my yaris? Thank you for your time.
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
