#1 |
Did you think of maybe running a Corolla TB on it later on down the road?
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
#3 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
I thought I read a thread where people were using a corolla TB with no wiring/ecu issues. Plug and play. Why not go that route? My plan is to buy another stock intake manifold and port match it to a corolla TB.
#4 |
play every day
Can you find where you saw that? Is the Corolla throttle body also drive by wire?
#5 |
Depot Damager
Drives: '08 Liftback Join Date: Jul 2012
$2000? I guess i forgot how much machine shop time costs since my time is free.
2008 Yaris Liftback - Bought in '12 with 80k Sold in '17 with 180k Bought back in '20 with 270k Currently collecting parts for the 2zr swap |
#6 | |
play every day
You can drink your coffee again... ...because that's not just for the single prototype, but for a small limited production run of tooters. ![]() I even have the marketing slogan: "if it sucks... it's a tooter"
#7 |
http://www.yarisworld.com/forums/sho...=throttle+body
http://www.yarisworld.com/forums/sho...=throttle+body there's been a few threads on it... |
#8 |
play every day
Thanks for the threads, Blue.
![]() I don't think I want to get involved in drilling out rivets, swapping chips, cracking idle screws, and rerouting coolant lines just now. Right now I'm focused on just one project... the manifold. Things turn out the best when I only do one thing at a time.
#9 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
There have been very mixed results with the 4-bolt DBW Corolla TBs, ranging from no issues to abject failure. They are electrically compatible, but the only real benefit from using one (w/o engine management) is that you effectively open the throttle faster. The corolla has a larger diameter TB, so you allow more air flow for the same throttle signal.
Beyond that, I really don't know the specifics. There's the potential to lean out your AFR too much at WOT because the ECU isn't expecting that much air to be available, and the stock fuel maps may cause it to misbehave. Going to a 3-bolt, cable throttle with a separate throttle position sensor (TPS) is only practical with standalone engine management (this is how Garm gets away with it) due to unresolved issues with the stock TPS signal. I believe that CTScott poked around with a scope and meter on a stock TB but wasn't able (?) to make sense of the signals. There has been a good deal of debate and experimenting with this, but no magic bullet solution. It mostly comes down to the stock ECU being a "learning" unit, and it's not happy with signals outside of the expected range. |
#10 | |
#11 |
play every day
Thanks for the info, Garm.
![]() I know nothing about forced induction, and just figured that the stock plastic OEM manifold was designed for vacuum and not pressure. |
#12 |
play every day
Test fitting time...
![]() ![]() It's a drop in fit! Did a little fine tuning with the Dremel. Since these were both undercuts, I just did them by hand... ![]() ![]() Clears the fuel rail perfectly with ~almost~ zero clearance... ![]() Ports matched flawlessly... ![]() Next up: test fit the throttle body.
#13 |
play every day
The flange is now a drop in fit, the throttle body bolts onto the adaptor like a dream, and the rest of the manifold has no clearance issues... ( goody
)![]() ![]() ![]() ![]() ![]() ![]() However... nothing else fits! ![]() All of the hoses are going to need rerouting, and I'm going to have to find a way to (gulp!) lose 2 3/4 inches on the already super short ram intake to make the air filter fit. But these issues are minor compared to getting the manifold itself to work out. |
#14 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
where did you bought the oem gasket ?
I will need to pickup a bunch of gasket :)
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#15 |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
Wow I like how the first pic look !
#16 |
you should do a little cleanup of the head while the flange has no runners on it. would make it SUPER easy to 100% port match it and get rid of the casting marks.
#17 |
play every day
If the head was off the engine I'd give it a whirl. But with the head on, I don't want to risk getting metal chips in the engine.
#18 |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
