Old 07-29-2012, 12:30 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by Bluevitz-rs View Post
There's no risk if the valves are closed. Then just blow it out with compressed air.
This is just a personal preference and I know that other people do this... but I'm not going to grind on a head when its on the engine. There is a sticky residue inside the engine ports that will make small chips stick in the crevices around the valve stems and valve heads even under pressurized air. there's also an issue of blowing tiny metal chips around under the hood. that means the alternator needs to be covered as well as the belt so that chips don't get stuck under it. With one cylinder's valves closed, some of the others will be open, so they would need to be plugged and taped. The only way I'd grind is if the valves were out and the head could be hot tanked afterwards.
There's also another reason... that would be making two changes at once, so I wouldn't be able to accurately quantify the difference on the dyno with just the manifold itself.
But, hey, you're perfectly free to grind your head if you want.
The manifold can be glass beaded because afterwards it can be hot tanked to insure that every particle of blasting medium is gone. Being a junkyard part, it's totally filthy and sticky inside and would need professional cleaning even if it wasn't blasted. It's hard to make out, but this was the original condition...
The runners are all as dirty as those ports, and all the way through, as well as the complete inside of the plenum. There is an intake port that extends into the middle of the plenum which makes it impossible to clean without being totally immersed.
Old 07-29-2012, 12:52 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Mine was that dirty on the outside too. I'm not sure if this applies to non-TDI manifolds, but this seems to be a pretty popular method:
http://youtu.be/oet4qWeZuYA
Old 07-29-2012, 09:28 PM   #3
ljming99
Drives: Yaris '06
Nice,
Im guessing the next order of the day would be some dyno charts
ljming99 is offline   Reply With Quote
Old 07-29-2012, 12:36 AM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
this work is SO much fun to watch. i applaud you.
Old 07-29-2012, 01:08 AM   #5
tooter
play every day
tooter's Avatar
Thanks, groove...
I'm having so much fun learning from this unfolding process and addressing the details as they present themselves by coming up with creative solutions.
Old 07-29-2012, 09:44 AM   #6
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
how much for the flange and adaptor ? can you hve other one made ? :D
Interior:ALL red, black roof
Old 07-29-2012, 12:55 PM   #7
tooter
play every day
tooter's Avatar
First I need to know if this setup will even work decently. That will determine whether or not it would be worth your while. We'll all find out if it's "go" or just "show" after the prototype has been run on the dyno.
But IF this works (and, man, that's a really big IF )...
...I do think that the mounting flange, throttle body adaptor and its 3 mounting bolts, and all 3 gaskets would make a really neato "do-it-yourself" kit.
Then you could simply get your own junkyard manifold and finish it up any way you'd like.
Old 07-29-2012, 06:45 PM   #8
enviri
enviri's Avatar
Drives: 2010 Yaris
soo your manifold is off a 1zz drive by cable? If we got hold of the dbw 1zz with the 4 bolt throttle body, would we just need the mounting flange only?
*confused*
Old 07-29-2012, 06:59 PM   #9
tooter
play every day
tooter's Avatar
Yes. It's off of an 1998-2003 Toyota Corolla 1.8L 1ZZ-FE engine with a 3 bolt cable operated throttle body.
*confused*
The adaptor only adapts the Corolla 1ZZ-FE 3 bolt cable controlled throttle body manifold to the Yaris 1NZ-FE 4 bolt electronically controlled throttle body.
Old 07-29-2012, 08:13 PM   #10
CrankyOldMan
Not entirely true: the Corolla 4-bolt TB is the same mounting pattern, just with a larger diameter hole/valve.
Old 07-29-2012, 09:34 PM   #11
Viperoni
Drives: 2005 Toyota Echo
Very nice, hit the road yet? :D
2006 Saturn Ion Redline
Old 07-30-2012, 12:17 AM   #12
Viperoni
Just for the heck of it, I found the 1NZ-FXE intake....
http://www.ebay.com/itm/2004-2009-TO...f6d5ae&vxp=mtr
Old 07-30-2012, 01:56 AM   #13
tooter
play every day
tooter's Avatar
I saw that really odd one, too. It's specifically designed to operate an engine within a narrow rpm range like a stationary industrial engine.
It's made to charge the batteries on a Prius.
Old 07-30-2012, 10:26 AM   #14
Viperoni
I believe the engine gets connected to the driveline on the Prius and is used to directly propel the car in addition to the electric motor (as opposed to only charging the batteries).
Old 07-30-2012, 10:28 AM   #15
it does. the engine operates between 1200-5000 rpm
Old 07-30-2012, 10:42 AM   #16
Viperoni
That I didn't know... that definitely makes it easier to increase the engine's efficiency.
Old 07-30-2012, 11:46 AM   #17
tooter
play every day
tooter's Avatar
Same here. I had no idea that the engine was actually connected to the driveline. That manifold configuration is exactly the same as I've seen on stationary industrial engines that operate at a "fixed" rpm.
Do you know that when it's running is it propelling the car concurrently with the electric motor? 1200 to 5000 means that it is never idling, but is always under a load.
Old 07-30-2012, 01:26 AM   #18
scroll back everyone, there is a pool for your guesses on horsepower and torque changes (gain or loss)... with a prize.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
