Old 04-16-2014, 01:50 AM   #1
limochong
limochong's Avatar
Drives: 2007 yaris sedan
Yup~ i need to replace both hubs and both wire harnesses.
Can anyone provide me with the costs for parts ?? Thanks
limochong is offline   Reply With Quote
Old 04-16-2014, 10:16 PM   #2
"G"
Drives: 2007 Yaris Hatch
No, we are not dealers.
"G" is offline   Reply With Quote
Old 04-16-2014, 01:59 AM   #3
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Before selling my Yaris I quoted buying all the necessary parts to fix the ABS / BREAK light issue and the cheapest I could get it was for around $250 but getting some genuine Toyota parts it goes up to around $500
Good luck
D.
CLA 250, 4MATIC
Old 04-16-2014, 08:48 AM   #4
limochong
limochong's Avatar
Thanks a lot!
Old 05-18-2014, 04:24 PM   #5
craigq
Drives: '07 Yaris, '12 GLI
Well last cleaned in Nov-2010, the ABS and ((!)) light are on again. Cleaned the connections and the lights are not going out this time.
craigq is offline   Reply With Quote
Old 05-18-2014, 04:27 PM   #6
Connections are probably broken now. You'd have to check with small cheap sowing needles and a DVOM. Digital volt and ohm meter.
Sent from my iPod Touch
Old 05-19-2014, 12:22 PM   #7
craigq
Yeah, that'll likely be the next step in the troubleshooting process Hopefully it's the rear harnesses and not the sensors pressed into the hubs...
Old 05-19-2014, 12:55 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
if u can scan it ...if it shows both sides , take car for spin after code erased when code comes back see if both or just one ..this will eliminate the good one or one that can wait...main problem is that when u get the light ..code.. u have to replace both ( hub ,harness ) cos its the sensor that is 99% gone :( and that will involve a new hub...sorry.
Old 05-18-2014, 04:28 PM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yup that is about right ...had a Yaris in with same problem Saturday will need new hub and harness price around 300$
Sent from my XT1032 using Tapatalk
Old 05-18-2014, 04:34 PM   #10
auxmike
auxmike's Avatar
That's a darn Shame. When I bought my 08 new I couldn't find one with the abs or the side airbags either. Now I'm glad I don't have it. Abs is pretty useless anyways..
Old 06-07-2014, 07:06 PM   #11
craigq
Replaced the rear passenger side harness (the rubber boot looked terrible, broken up etc.), that didn't clear it. Disconnected the battery cable, not sure if that's required or not as I can't recall what I did the last time, still didn't help. I then replaced the rear hub w/ABS sensor, disconnected negative battery cable, and that cleared it. Wonder when the driver-side will go
Don't have a slide hammer so I improvised a pulley-puller by using two 5" bolts and nuts/washers and some spacers to remove the old hub, surprised it worked
Old 08-25-2014, 11:36 AM   #12
robkay
Drives: Hatch
Just stopping back with an update. In April ('14) I reported that I had removed my sensor cables on the rear, cleaned them and put them back on. (I never did get around to doing the front.) Unfortunately, the BRAKE/ABS indicators did not go out and I just kind of resigned myself to leaving it that way for a while--maybe for good.
Well, about 6 weeks ago the BRAKE/ABS indicators turned off. Not certain the ABS is working again, but they are off. So, for a quick history:
  • My indicators first came on 12/21/13, but then went off the very next day.
  • On 1/27/14 they came on again and stayed on.
  • On 4/10/14 I cleaned the rear connectors, but the indicators stayed on.
  • Sometime in mid-July 2014 the indicators turned off again.
Weirdness. Hoping they stay off, but not counting on it. Still going to pop the fronts off and clean them before cold weather gets here.
robkay is offline   Reply With Quote
Old 02-10-2015, 10:43 AM   #13
sheekeebut
Minimalist
Drives: 07 silver sedan
Digging up this thread. Want to share my experience, which I don't doubt comes from the same problem.
Went to visit the museum last Sunday. Freezing rain, hurrah! Lots of slush and salt downtown as usual. Then, much like all the Torontonians who posted here, I got in the car, started pulling out of the parking garage, and wait, what? An (!) and (ABS) at the same time?
That night, found this thread, took a chance and pulled the rear sensor connectors and blasted the contacts on both ends with CRC MAF sensor cleaner, for lack of other cleaning spray. No dice, errors still stayed on.
Well guess what? Just this morning, like 30 minutes ago, driving down to the office, with error lights on as usual, I was pulling into my parking spot, and, wait, where are those lights? WTF? Just when I was starting to get used to seeing them...
I'm sure I should do those diagnostics per CTScott's info, there must be a dodgy contact somewhere.
sheekeebut is offline   Reply With Quote
Old 02-10-2015, 11:00 AM   #14
robkay
Drives: Hatch
In my case it was exactly the slushy/salty scenario that seemed to trigger the problem. I am happy to say that even though I only did the rear connectors last April, so far, my indicators have not come back on since last July. The ABS has kicked in a couple times, so I know it works. Now, it is probably accurate to say that, this winter, we have not done as much driving in slushy weather as the winter before. Of course, after I cleaned the rears the indicators didn't go out for 3 months. Did my cleaning actually fix the problem, or was it somewhere else and it finally dried out over the Summer? Who knows. In any case, I'm hoping the problem does not resurface as I do not need that expensive repair. If it happens again I'll clean the fronts and if that doesn't fix it I'll probably just live without the ABS.
Old 02-10-2015, 12:47 PM   #15
I was looking at digging up this thread. Mine came on a while ago during the ice storm in January. But it quickly turned off as weather warmed up.
I plugged the TechStream tool and it does show rear left sensor issue. I haven't erased it and ABS is working. But the issue I am having now is the rear right wheel locking up.
I haven't seen the ABS light since then, but I still experience rear right wheel locking up, throwing the car to the left until the rest of the ABS system straightens the car...
Old 03-23-2015, 10:07 AM   #16
Logen9Fingers
Drives: 2007 Yaris sedan
Thank you everyone here. You all have helped me fix my dreaded ABS and Brake light issue. Here is what I went through.
Issue:
ABS and Brake light come on and off. It happens randomly with no Rhyme or reason, and would stay on most of the time. The ABS also kicks in when I roll to a stop; it only happens if I am going slow.
Fix:
Removed back 2 wheels (1 at a time). Sprayed cover to speed sensor harness with WD40. Used flat head screw driver to remove the cover. Cleaned cover with WD40. Disconnected harness from speed sensor (used same screwdriver to gently pry it off). Sprayed dielectric spray inside both ends. Reconnected everything.
So happy I did that this weekend before it started snowing again.
Logen9Fingers is offline   Reply With Quote
Old 08-16-2015, 07:37 PM   #17
trojjanhorse
Drives: 2007 Yaris LE
Hi everyone
I too own an OBD II bluetooth adapter and like many it did not reveal any fault codes.
I jumped 4&13 and here's the flash pattern i witnessed:
3.3..3.4..3.9..94...repeat
The dots are supposed to be seconds between flashes.
Anyone know what these flash patterns mean?
Thank you.
trojjanhorse is offline   Reply With Quote
Old 08-16-2015, 10:35 PM   #18
33 - Right Rear Wheel Speed Sensor Signal
34 - Left Rear Wheel Speed Sensor Signal
39 - Foreign Object is Attached on Tip of Rear Speed Sensor LH
94 - Control Module Communication Bus OFF
