Old 07-29-2012, 01:01 PM   #397
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by CrankyOldMan View Post
Mine was that dirty on the outside too. I'm not sure if this applies to non-TDI manifolds, but this seems to be a pretty popular method:
http://youtu.be/oet4qWeZuYA
Wow... that's really exciting...
...but I'd be concerned with melting this manifold's really thin aluminium tubing runners.
Old 07-29-2012, 06:45 PM   #398
enviri
enviri's Avatar
Drives: 2010 Yaris
soo your manifold is off a 1zz drive by cable? If we got hold of the dbw 1zz with the 4 bolt throttle body, would we just need the mounting flange only?
*confused*
Originally Posted by tooter View Post
First I need to know if this setup will even work decently. That will determine whether or not it would be worth your while. We'll all find out if it's "go" or just "show" after the prototype has been run on the dyno.
But IF this works (and, man, that's a really big IF )...
...I do think that the mounting flange, throttle body adaptor and its 3 mounting bolts, and all 3 gaskets would make a really neato "do-it-yourself" kit.
Then you could simply get your own junkyard manifold and finish it up any way you'd like.
Old 07-29-2012, 06:59 PM   #399
tooter
play every day
tooter's Avatar
Yes. It's off of an 1998-2003 Toyota Corolla 1.8L 1ZZ-FE engine with a 3 bolt cable operated throttle body.
*confused*
The adaptor only adapts the Corolla 1ZZ-FE 3 bolt cable controlled throttle body manifold to the Yaris 1NZ-FE 4 bolt electronically controlled throttle body.
Old 07-29-2012, 08:13 PM   #400
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Not entirely true: the Corolla 4-bolt TB is the same mounting pattern, just with a larger diameter hole/valve.
Old 07-29-2012, 09:28 PM   #401
ljming99
Drives: Yaris '06
Nice,
Im guessing the next order of the day would be some dyno charts
ljming99 is offline   Reply With Quote
Old 07-29-2012, 09:34 PM   #402
Viperoni
Drives: 2005 Toyota Echo
Very nice, hit the road yet? :D
2006 Saturn Ion Redline
Old 07-29-2012, 09:41 PM   #403
tooter
play every day
tooter's Avatar
Oh, right... that was the one that people were trying to get to work. The hole in my adaptor is sized to fit the stock Yaris throttle body.
Old 07-29-2012, 09:44 PM   #404
tooter
play every day
tooter's Avatar
Originally Posted by ljming99 View Post
Nice,
You guys are WAY ahead of where I actually am!
The manifold is still in two pieces. First it needs to be welded, then glass beaded, then hot tanked, then I need to fabricate a custom intake for it before I can even begin to think about running the engine.
Old 07-30-2012, 12:17 AM   #405
Viperoni
Just for the heck of it, I found the 1NZ-FXE intake....
http://www.ebay.com/itm/2004-2009-TO...f6d5ae&vxp=mtr
Old 07-30-2012, 12:57 AM   #406
ljming99
Drives: Yaris '06
Haha, its just me but I would get it to a basic "up and running"stage, then run some tests before going all out for the aesthetics / extras.
Old 07-30-2012, 01:26 AM   #407
scroll back everyone, there is a pool for your guesses on horsepower and torque changes (gain or loss)... with a prize.
Old 07-30-2012, 01:56 AM   #408
tooter
play every day
tooter's Avatar
I saw that really odd one, too. It's specifically designed to operate an engine within a narrow rpm range like a stationary industrial engine.
It's made to charge the batteries on a Prius.
Old 07-30-2012, 02:02 AM   #409
tooter
play every day
tooter's Avatar
I'm anxious to get it going, too...
...but I just can't skip welding and hot tanking, because the old manifold is absolutely filthy inside, and I'm not going to risk wrecking a brand new engine. The same place that does the welding also happens to do glass beading.
Old 07-30-2012, 10:26 AM   #410
Viperoni
I believe the engine gets connected to the driveline on the Prius and is used to directly propel the car in addition to the electric motor (as opposed to only charging the batteries).
Old 07-30-2012, 10:28 AM   #411
it does. the engine operates between 1200-5000 rpm
Old 07-30-2012, 10:42 AM   #412
Viperoni
That I didn't know... that definitely makes it easier to increase the engine's efficiency.
Old 07-30-2012, 11:46 AM   #413
tooter
play every day
tooter's Avatar
Same here. I had no idea that the engine was actually connected to the driveline. That manifold configuration is exactly the same as I've seen on stationary industrial engines that operate at a "fixed" rpm.
Do you know that when it's running is it propelling the car concurrently with the electric motor? 1200 to 5000 means that it is never idling, but is always under a load.
Old 07-31-2012, 06:03 PM   #414
tooter
play every day
tooter's Avatar
The manifold pieces went to the welder today, and I'll have it back at the end of this week. I undercut the two inside port edges with a Dremel and they turned out just fine.
Getting closer to dyno time... so you guys had better get your HP/TQ guesses in.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
