#1 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
C'est la vie
I leaned out from about 11.5 to 12.5:1 afr after raising the boost. Looks like some fuel system upgrades are needed. Going to work on the pump again this weekend.
#3 |
C'est la vie
Well over the weekend I managed to get my 255lph pump installed into the stock fuel filter and regulator inside the tank. I tryed to do this once before with no success. I found previously the pump was loud and overheated in about five minutes of driving and the car would dye out. This time I found the pump was restricted because the outlet tube on the pump is longer then the stock pump. So the tube would bottom out in the filter and restrict flow. So this time I shaved on a angle a little over half the outlet tube on the new pump. This mabe a little hard to picture but it allows the fuel to enter the filter without restriction. I also had to use a larger O-ring to seal the pump tube inside the factory filter that sourounds the pump. Now it is only slightly louder then the factory pump and has been working great from sat. Also my afr has returned to 11.5:1.
#4 |
Balls deep...
Drives: 2007 yaris liftback Join Date: Jul 2007
pimp's car is definitely fun to ride in...
#5 |
C'est la vie
Last weekend I installed a new 3 1/4 inch autometer phantom tach and new JVC 7" touch screen head unit. Also recently installed new Federal 215/40/17 tires. They just barely fit and they rub very slightly on the tie rod when turned to the stop. But look great. Also rerouted my intake tubing and moved the air filter to clean up the engine compartment a little. I am having a spoiler for the rear hatch painted this week. I am loving this little pocket rocket now.
#6 |
Great job pimp! It took a couple days but I read the whole thread lol. I will be starting my Turbo project one day soon and it will be my first so this was VERY enlightening!
Does ur glove box still open? That is a very clean install from the looks!! I like! |
#7 |
C'est la vie
Yes the Glove box still opens, but there is a hole cut in the pocket behind both of the guages for clearance and wiring. I dont use it anymore.
#8 |
C'est la vie
I installed a new spoiler that I ordered on E-bay from China. It was actual plastic [not fiberglass] and its working well. Not to big and not to small, I think. Also towed some friends to a track day with there bikes. With so much weight on the back of the weeee Yaris it sounds like a diesel truck with the turbo. Still had plenty of pull though. One tough car!
#9 |
C'est la vie
Going on a ride today with some friends from Supra forums. Going to some twisty roads to a state park for a little picnic and bullshiting. My friends Supra is pushing 932 ponies to the rear wheels. His turbo is the size of a large dinner plate. His girl friends supra is pushing 420 to the rear wheels with a single turbo conversion. Must be nice to have money. Im sure I will be the only turbo Yaris there, but Im gonna represent!
#10 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
Do it n take pics
#11 |
C'est la vie
Well our Picnic got rained out and postponed to next sunday. I still took pics of some sweet rides.
#12 |
MKIVs :)
#13 |
C'est la vie
Removed my exhaust manafold today and repaird a exhaust leak caused by a stripped manafold bolt. I stripped the bolt hole when the first turbo manafold I had installed cracked. Becaused of the hard to see location of the manafold, I originally thought it loosened up causing the gasket to leak. I overtightened the bolts. I later found the manafold had cracked causing the leak. Garm at Micro Image warrantied the cracked manafold and sent a new one. The new one is working well. I have put off this repair all summer because of the heat and I was not looking forward to installing a helicoil in such a tight location behind the engine.
Well its done and I think it worked out ok. I even installed a new oem manafold gasket. While I was in there I also cranked up the boost a little. Its about 9.5 psi now. I will post later how this all works out.
#14 |
Excellent, can't wait to hear more.
#15 |
C'est la vie
I was planing on getting some dyno testing this week but my stock clutch is starting to slip. Not horrible yet. But it is definitely slipping. I may need to swap it out before it gets to cold out. Going to do some internet shopping.
#16 |
Mine has already started to slip. Think I gonna put up back my exhuast casue I am having some boost creep. Sigh should have went external wastegate lol.
#17 |
C'est la vie
Sigh should have went external wastegate lol.[/QUOTE]
Me to |
#18 |
C'est la vie
Well my clutch can no longer hold up at all. My car has gotten more power then ever now that temps. have got colder. If I nail it in 3-5 gears my clutch will break loose and freewheel, and it will bounce off the rev limiter.
So today I took my trans. out and inspected my flywheel. It still looks ok and hasent turned blue yet. I have heavy duty F1 stage 3 clutch I ordered last week. Tomarrow I will install. Today my back is killing me! ![]() Stay tuned. |
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 02:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
