#1 | |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
Looked a bit tight in there...Wrap looks good, I just bought some to do my header...eventually.
05' Echo Hatch - Greddy Supercharger - rear disc |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
#3 |
Yes I'm late posting.... I have been busy with lots of works out on going project and this is finally the last mod since there isn't any other space available now LOL!
Summer special tune.... Idividual Twin Radiator setup. The aftermarket rad is fitted after the turbo line in order to prevent unwanted heat from the turbo affecting engine temperature... I was seeing 90C and over with the fan on. Also I installed another fan on the front which is visible on the picture as an add on! I also installed the Torque damper with lots of custom work to make it fit and also an exhaust motor that cuts the exhaust from the middle. Next thing up dyno although the engine is pretty quick with only 12psi boost. I am almost sure it is above 220Bhp now .... hope to make it up till 300Bhp at 16psi! Will post pics and vids on the dyno next up! |
#4 |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Did the extra radiator help? And where are you measuring your water temps?
#5 |
#6 |
My radiator runs full width, it's really too good, the car runs a little too cold when the ambient temps are under 80 degrees outside.
#7 |
time to move the battery to the back of the car. It'll help to offset some of the added weight and free up an additional 1 cubic foot of space for more stuff
#8 |
Still not tried the setup yet cannot tell for now that the extra rad and fan how much they are better. The Water Temps are measured after the water outlet of the engine.
No I love the battery there and I really need to stop modifiying the engine cause I better put some cash on brakes and suspensions! No oil cooler, the oil temps are about 60 - 70 C the max I seen. That is already good that way. Also I don't want to have pressure loss.... |
#9 |
#10 | |
Today I tried the engine on street and pushed it on gears above 6Krpm. I can notice a great benefit with the extra radiator and fan. The max temp seen 91C Degrees and cooled down quickly to 85C in just a minute of the fans on. I need to fine tune the fuel map and Cam timing and then off to the dyno to check powerband and torque accross the rpm range. Cross Fingers!
#11 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
+1 on the suspension.
#12 |
If you don't mind me asking how much did u sink in this thing already?
#13 |
#14 |
Any updates, or dyno numbers?
#15 |
Dyno is scheduled on 29 August and I hope some good numbers at the wheels.
I am a bit worried how much boost and revs I am going to give her because of the stock head so if any would give a heads up of a limit just post it here... During the time I found a good deal on a set of D2 racing shocks. They are extremely sensitive on street and I can feel every little bump on the street (not comfortable at all) but at least rock solid on street corners. Also I am having less wheelspin when giving her full throttle from a stop sign ![]() Here is the update: |
#16 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Set it at 7300 if it still makes power. I just looked at your picture few posts above... make sure your pipes are bead rolled or the dyno session may get pricey if they have to keep putting back blown off intercooler pipes. May be fine at the boost you're at now........
Ptuning.com |
#17 |
I'm excited for you, looking forward to some great numbers!!
#18 |
Thanks for the help guys but I really care about this motor and I prefer being safe than having a wrecked motor for just a few more rpm.
I am thinking of let it run from 6500rpm till 7000rpm and see if it will keep making power and torque on the stock head. I am thinking of boosting till 16psi for now and see how it goes after trying it on the drag strip. The main issue in this country is fuel octane since you don't get constant octane from the station. I will be using the Lucas octane booster to tune and keep giving her every refuelling to be safe. The other issue is tire traction and wheel spin from a stop. The tires are Toyo R888 rally semi-slick tires but still having wheelspin above certain rpm launches. I am trying to set a launch control switch to help with this issue. |
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
