Old 12-16-2011, 08:26 PM   #1
wildcard
wildcard's Avatar
Drives: 09 3dr HB 5sp
Please for the love of god get that poor bike some better tires than those shinko's.
wildcard is offline   Reply With Quote
Old 02-02-2012, 08:34 AM   #2
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
10 psi still going. Just wanted to post some pice of my blow off recirc. setup. Not the best looking but it works great. Also in the turbo pics. U can see the brace I put on to support the weight of the turbo. It drops down from the bottom of the down pipe.
Old 02-04-2012, 10:42 PM   #3
yaris2010RS
yaris2010RS's Avatar
it took me about 3.5 hours but i finally read and completly understood just about everything. lol
Great write up and great help/advice from others. i will hopefully be starting my install in about 2 weeks and this thread made things alot clearer.
Old 02-05-2012, 10:08 PM   #4
pimp my yaris
C'est la vie
Its all worth it. It will make your car a blast to drive. I always get a thumbs up from the turbo neon guys and Subie wrx owners. Its so much fun smoking those turbo coopers.
Old 02-05-2012, 10:24 PM   #5
yaris2010RS
where did u hook up your bov vacume line to?
Old 02-10-2012, 08:13 AM   #6
pimp my yaris
C'est la vie
I put a vaccume T off the evap. purge solinoid. The line attaches on the intake near the throttle body.
Old 02-10-2012, 11:05 AM   #7
You are ready, young padawan....
Old 03-22-2012, 08:22 AM   #8
pimp my yaris
C'est la vie
Made A big move yesterday and cranked up the turbo to 12psi. Hade to make a competely new map for my FIC. Old map was only good to 10psi. Its was running VERY STRONG for about an hour of very hard driving. Then I noticed the AFR's were getting a little lean. I will do some retuning if possible. I may need more fuel system upgrades at this power level. Possibly new rail with a return line or even lager injectors? The good news is I am no longer using that jimmy rigged pull spring on my wastegate as my boost controller.
Old 03-22-2012, 05:56 PM   #9
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Before you continue do a compression test so we can see what it is before 12. Your rods are goona be the first thing to go. Careful you don't burn up the exhaust valves that can make it show lean sometimes. And Dyno that thing so you can brag about it
Old 03-22-2012, 08:44 AM   #10
Boy you're getting brave. Do you have a spare motor just in case?
Old 03-22-2012, 11:53 PM   #11
pimp my yaris
C'est la vie
Latest vid of stock 1nzfe at 12psi. Actually spikes to 13psi before dropping to 12psi. This was a forth gear roll on. Sorry, Im not good with filming.
http://www.youtube.com/watch?v=CfaEW...ature=youtu.be
Old 04-16-2012, 10:14 PM   #12
pimp my yaris
C'est la vie
Did another dyno run at Sound Performance in Bensenville Il. They squezzed me in on a Buick dyno shootout on saturday. I pulled 197whp on a mustang dyno. They typically read 5% lower then Dynapac dynos.
Old 04-16-2012, 10:46 PM   #13
OH yeah, nice!
Old 04-17-2012, 12:34 PM   #14
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
that is awesome.
Colin Chapman disciple
Old 04-17-2012, 01:00 PM   #15
Focus_Sh1ft
Focus_Sh1ft's Avatar
So ridiculous... I would have never thought our engines could put down so much power stock.
Old 04-21-2012, 10:32 PM   #16
pimp my yaris
C'est la vie
Well a couple of days ago I was driving to the grocery store and when I was leaving my neighborhood I nailed the gas in second gear. The tires broke loose and kept spinning until about 50mph. When I let of the gas and shifted into third gear I heard a loud knocking noise tied with rpm. I pulled over and saw no oil leaking. I drove home with the noise as the damage had already been done. I thought for sure I spun a rod bearing. I drained the oil and saw no metal chips in my oil. So then I did a compression test, 3cyl. at 155 to 160psi and 1cyl. at 95psi. Mystery solved. I slapped a valve at high rpm. Now I have a bent valve.
I am now working on removing my cyl. head. I also bought a used 80k mile motor from a local junk yard for 350$. I am going to put the head on my car, so I can get back on the road for now.
Then I am going to order pistons and rods for the short block soon so I can start on a higher boost motor. Goal 275-300hp
Old 04-21-2012, 10:37 PM   #17
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
for some reason they don't like 25+ psi either.
Old 04-21-2012, 11:47 PM   #18
pimp my yaris
C'est la vie
? Who is making performance valve springs besides Ferrea. 1000$ for valves and spring is a little stiff. And stock seem a little weak for my extended high RPM abuse.
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
