#1 |
Here are a few shots of my set up, I think the "tabs" on the valve cover are intact.
[QUOTE=cali yaris;654030]Here are a few shots of my set up, I think the "tabs" on the valve cover are intact.
No, there was a tab on the transmission side of the cover that's been removed. But it's nothing a hacksaw can't care of in short order. |
#3 |
#4 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#5 |
Someone please post some decent pics of their stock valve cover.
#6 |
Found one on eBay.
#7 |
blue-vitz, it doesn't look like the fuel rail would cause a problem with the driver side "tab'. My regulator doesn't have to be positioned there, which would be in the way. Maybe it's because of the intake mani instead?
I guess we'll know when pimp does his install. @ packet -- yeah things have to match in my world or I can't sleep. Tanabe is supposed to give me a new sticker for the powdercoated strut brace.
#8 |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
i think pimp had cut his off so he could upgrade his injectors easier.
http://www.yarisworld.com/forums/sho...&postcount=406 |
#9 |
Garm
The black thing comin out of the regulator is for te gauge ? What is the regulator brand ?
#10 | |
Here is AEM's page and PDF for it: http://www.aemelectronics.com/univer...-regulator-338 http://www.aemelectronics.com/Images...s%2025-302.pdf
#11 | |
#12 |
Where is the outlet of the rail going ? and where is the little black thing that comes out of the regulator going ?
#13 | |
"Know it all"
Drives: Lancia Delta Integrale Join Date: Jan 2012
Black hose is going to manifold vacuum/boost, FPR is rising rate based on boost, the more boost it sees the higher fuel pressure gets.
www.microimageonline.com |
#14 |
The bottom of the regulator is the return line/outlet, the left is the feed from the rail, and to the right is the gauge.
#15 |
not quite sure tu understand...
I understand the boost inlet... The left side of the rail(passenger side) goes to the stock feed line as I will turbo... The right side of the rail go to the regulator obviously... Where is the FEED...I dont understand how the fuel can come from the fuel tank if we use the feed line as return line now...
#16 |
I got it I think!!
Fuel rail is feeded from the left(passenger), then it passes trought the fuel rail....then in the regulator...and THEN it goes to the stock feed line which is now return (bottom of the reulator)... Gauge on the right side of the regulator Black hose iandor vaccum boost Now....to mke the completely new feed line....i make hose from the fuel rail and the fuel pump ?
#17 |
Yes -- A new fuel line from the pump to the rail if you include the direction of flow, but yeah. My last post in here on this -- we totally jacked the thread. SORRY PIMP
#18 |
Just read the wholleee thread!!! lollll
will get my engine next week cant wait to start it :D love YW and MI :D
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 02:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
