#37 |
![]() Drives: 2008 Yaris Liftback Base Model Join Date: Nov 2008
Does the lack of wheel covers noticeably reduce mpg? Any idea how much? This is making me second guess the eBaying of mine...
#38 | ||
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
#39 |
hey loren, 500snakz says its not possible to even get 48mpg so I'd give up on the 55 dream...
![]() http://www.yarisworld.com/forums/showthread.php?t=10642
3,441,567,453 posts BH (Before Hack) |
#40 | |
#41 | |
![]() ![]() ![]() Drives: 2008 Yaris LB Auto Join Date: Nov 2008
... I have an AT, and have pulled over 50 for a trip longer than 200 miles. Oh, and 48... that should be about city mileage in the MT if you drive it well enough. You can do it!Matt
#42 |
here is Bailout's gas log.....
http://www.gassavers.org/garage/viewgaslog/2128
#43 |
oh I know, it's 500snakz that doesn't believe
#44 | |
If you "FAS it up", you can easily exceed that as well... Matt
#45 |
Well then... I think we need to put Snakz on a plane! jk
Matt
#46 |
hahahaha yeah I got it the first time
#47 |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
I'm tired of these mother uckin' snakes on this mother uckin' plane!
too many mother uckers Alright, let's not drag Mr. 500snakes through the mud here. He'll either learn or he won't, but he has nothing to do with this thread... let's be nice to the newbs. Quick question for those who use FAS and have a Scangauge: I gather that I need to set my mode to "Hybrid" to get the Scangauge to work properly. If I do that, will the Scangauge then give me accurate readings even through multiple FAS sessions? (no time to really test the theory before Sunday) Or will the ScanGauge ignore some or all of the FAS session and only report the MPG that occurred while the ignition is on? |
#48 | |
It typically stays on while you are turning off the car, and records all but whatever happens while the car is off... This being said, it fails to record for usually <1sec... If you have it set to hybrid, you will have no problem... My numbers usually stay accurate with FAS usage. ADDED: Oh, and during the FAS your MPG will read over 1000, but you are actually using 0 gas, so this may lead to inaccuracies over the course of a long trip. I only use it going to long red lights. Matt
#49 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
The manual states it's safe to flat tow the Yaris auto for short trips at low speeds on flat surfaces, so you should be ok FASing to red lights.
I've read logs where people who are really good at FASing manuals and P&G increase their mpgs by 20%.
#50 |
![]() ![]() Drives: 2008 Yaris LB 5M Join Date: Oct 2008
My SG2 appears to record accurately while FASing, I set it to hybrid mode. Turn the key off, until the dome light starts to turn on (about a second or so). I do lose that second of SG recording while the key is actually in the off position but not the entire trip. The SG will continue updating from the numbers you had before keying off then back on. I use it as an estimation tool, not taking the numbers as gospel anyway so that second or so does not matter to me. A quick, light clutch while in 5th (or 4th if speed is low) starts the engine.
I only just started using this technique, so not an old pro at it, but found this works for me. EDIT: the iMPG readings while in FAS do vary for me not do the 99999 thing. Depending on speed they will vary from 1,000 to 3,000 iMPG. |
#51 | |
Matt
#52 |
![]() Drives: 07 Yaris Sedan Join Date: Nov 2006
You're going to find it difficult - hypermiling and keeping your overall average speed up to 45 are conflicting goals. You'll probably have to drive above the speed limit for some segments to make up for lost time and stops.
#53 | |
What?
The plan is to P&G up to about 5 over and 10 under the speed limit in most places. (traffic permitting) The highest speed limit is 60, about half of the route is 55. The rest is slower, but will balance out. I've already segmented out the route and calculated times based on expected speeds for each segment. It works... now, if I can just stick to the plan! |
#54 |
I will try and make it to a future one of these...
I have school-related things the rest of the semester ![]() Oh, and word of advice, if you didn't think to... bring your speed average up by hauling ass (hypermiler haul 60) when you hit the downgrades, that way you do not find yourself having to do this on a lot of the flats. Then you could ride your speed down in a great-length FAS. Hope this wasn't common sense... Matt
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Yaris Color and MPG Statistics/Summary | jmharn | General Yaris / Vitz Discussion | 21 | 11-19-2008 04:52 PM |
| Toyota Yaris MPG Review at www.mpgomatic.com | aca72 | Fuel Economy Forum | 23 | 10-31-2008 03:59 PM |
| Am I calculating MPG correctly? | YarisBlazer | General Yaris / Vitz Discussion | 24 | 08-18-2007 11:57 AM |
| Wow, I Got 48.57 mpg | Kaotic Lazagna | General Yaris / Vitz Discussion | 52 | 05-10-2007 10:09 PM |
