Old 09-19-2009, 08:09 AM   #1
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
use a multimeter and probe the wires, and make your own diagram, thats what I did when I installed my remote starter.
Old 10-23-2009, 11:39 AM   #2
Sora65
Drives: Beautiful :)
But where im getting at is right?
i could put the wire i need powered in the same hole as the blue one where theres 12v?
Sora65 is offline   Reply With Quote
Old 10-23-2009, 02:53 PM   #3
Yes. That blue +12 is always on though. The pink is switched ground for the inside lights.
Old 11-12-2009, 02:04 PM   #4
yoxx
yoxx's Avatar
Drives: toyota yaris 2008 hatch
How to plug in a water temp gauge?
All I really need is the signal for the temp
wich one is it, please HELP
yoxx is offline   Reply With Quote
Old 11-12-2009, 11:46 PM   #5
There's a 2 pin connector to the engine coolant temp sensor. It has a pink and a blue wire that go to pins 96 (pink) and 97 (blue) on connector C20 of the ECM.
Old 11-13-2009, 01:46 PM   #6
yoxx
yoxx's Avatar
Attachment 30002
hey ctscott
i got a little problem
the water temp that i got, only have one wire for the water temp? wich one should i use for this? the pin 96 (pink wire) or pin 97 (blue wire)
Old 11-13-2009, 02:01 PM   #7
hey ctscott
What temp gauge did you buy?
Old 11-13-2009, 04:05 PM   #8
yoxx
yoxx's Avatar
This is the one I got
http://www.harborfreight.com/cpi/cta...unction=Search
it match my tach and voltmeter
Old 11-13-2009, 07:17 AM   #9
yoxx
yoxx's Avatar
Where r this locate it, for some reason I can't find this box you r showing me, been looking under the hood for an hour and I can't find it
Old 11-13-2009, 08:07 AM   #10
With the hood open it is to your left (the car's right) against the firewall. It is the big silver box with the two large connectors.
Old 11-13-2009, 07:25 AM   #11
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
and the speed sensor wire ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 11-13-2009, 08:11 AM   #12
The easiest place to tap it is at the speedometer. It is the pink wire in pin 17 of connector D1, which is the larger of the two connectors.
Old 11-13-2009, 03:08 PM   #13
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Attachment 30013
where is that connector buddy ?
i wanna hook it up to my apexi rsm speed wire
JDMtuner
www.jdmtuner.co.za
Old 11-13-2009, 03:12 PM   #14
Pop the trim from around the speedometer and you'll see two connectors going to the cluster assembly. If your car is left hand drive the connector you want will be on right and if it's right hand drive it will be on the left.
Old 11-13-2009, 03:18 PM   #15
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
aaah ok ! thx bro !! no other locations for that wire ? like on the ODB2 port? how does the scangauge get speedo signal? cant i somehow hook into that?
JDMtuner
www.jdmtuner.co.za
Old 11-13-2009, 03:13 PM   #16
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
or should i say where in the car do i find that connector?
JDMtuner
www.jdmtuner.co.za
Old 11-18-2009, 05:40 PM   #17
fsj2
fsj2's Avatar
Drives: 2014 SE 5dr
I want to wire up some aftermarket LED driving lights. I want them to come when the car is in drive. Is there a easy place to connect them? 2010 5 dr HB. Thanks.
fsj2 is offline   Reply With Quote
Old 11-18-2009, 06:10 PM   #18
To have them come on when the car is "In drive" with an automatic transmission, you could tap the connector C27 on the transmission. The 10A Gauge circuit feeds through the Park/Neutral/Position Switch on the A/T to feed the indicator on the cluster and the ECM with the position of the A/T shift. For low power lights (LED lights under 1A) you could feed them directly. For high power lights (incandescents or HIDs) you would have the Drive indicator feed the coil of a relay, which would then have it's own power feed for the lights.
C27 is the 9 pin connector on the front of the transmission (by the shift linkage). It has a row of 4 and a row of 5 pins. The center wire (light blue) on the 5 pin row is the "Drive" indicator wire. It will have 12V on it when the shift is in drive. For ground, you can grab a chassis ground, like the ground bolt under the left headlight.
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
