Old 07-31-2009, 09:17 PM   #1
Originally Posted by CtrlAltDefeat View Post
was that the front or rear strut bar?
Rear for having to pull the wheels. I probably could have slid it into one wheel and then got it into place, but I didn't want to ding up the wheels with the bar or the wrench. My wheels are 16x7 +45 by the way.
I installed the front UR strut tower bar without removing the front wheels and without removing the wiper cowling. I jacked the front up and put it on jack stands and that gave me enough clearance to see to get the bolts up. On top, I found that I could get the socket on the passenger side with no problem and on the driver side I just had to flex the cowling up about 1/4" to get the socket on.
Old 07-31-2009, 08:48 PM   #2
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
not sure. I did mine ghetto style with what ever tools lying around the dusty garage. I think i had to use a 3/8 to 1/2 adapter...
Old 07-31-2009, 08:57 PM   #3
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
I'm on H&R lowering springs and 17's 42mm offset.....no torque wrench here either...
I'll see how it goes, required to torque it or no?
Old 07-31-2009, 09:00 PM   #4
It can be done without removing the wheels, but it's not as much fun. Have a Band-Aid ready for the knuckle that suffers the injury.
Old 07-31-2009, 09:26 PM   #5
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Garm - no pain no gain :P
CTScott - Glad to know that, did you torque to specs or just tighten as much? I really dont want to spend 60+ for a torque wrench :(
Old 07-31-2009, 09:38 PM   #6
I'm one of those people who only breaks out the torque wrench for engine work.
Old 07-31-2009, 09:35 PM   #7
medium tight should be ok. 44 shock bolt, 36 front bolt if you torque them.
Old 07-31-2009, 09:54 PM   #8
YAR1S
YAR1S's Avatar
Im in a bit of a pickle.
I want this rear sway bar
But
do i have to lift it up to get the bar on? Im running stock wheels....
could I use two lift stands on either side?? I only have one but one from another car would be fine would it not?
Hmmm...
I would ask my mechanic but he's pretty old school and may have a fit about adding it on to my yaris... he doesnt even think the trim rings and dust caps are safe enough to have on there (he worries a lot about me, the old geezer :p ).
any thoughts?
-Jen <3
Old 07-31-2009, 10:36 PM   #9
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
if you mean vehicle roadside jacks, I would say if you're in a real dill pickle then it'd be fine just find the lift points on the underside of the car.
Old 08-01-2009, 12:26 AM   #10
CtrlAltDefeat
I ♥ Yaris
You should never get under a car with just the roadside flat tire jacks, they are too unstable... you really need jack stands... I'm pretty sure you have to lift the car to put it on.. the weight of the car will not let you remove the bolt you need to remove to install it (I would imagine the shock might pop out and possibly hurt you)
Old 08-01-2009, 12:31 AM   #11
Shroomster
Shroomster's Avatar
yeah you're right. why use something that's meant to hold the vehicle up in the first place. especially two of said item.
/sarcasm.
^^ctrlaltdefeat - don't take it like I'm dogging you or anything, just my horrible brand of humor
in all honesty though if you have the money to, invest in a nice jack and stands like mentioned.
also the shock will not pop out unless you give it enough clearance, and it will not come flying out either, merely fall out as there is no force applied to it. although they are somewhat hard metal
Old 08-01-2009, 12:45 AM   #12
CtrlAltDefeat
I ♥ Yaris
well jack stands aren't that expensive (the cheapest ones will work, our cars are so light weight) and I'm saying that if you did remove the bolt holding the bottom without the car lifted up at the back the weight of the car will be compressing the shocks and 1. will be nearly impossible to move the bolt, and 2. if you did get the bolt removed, the end of the shock with the weight of the car on it will pop out of place suddenly... The flat tire jacks have small bases and are designed to be subjected mostly vertical force. You start wrenching on the car underneath it and it's likely to slip sideways and fall off of the stands.
Old 08-01-2009, 01:21 AM   #13
If you're on stock springs, I'm willing to bet it's possible to put this on without even jacking up the car.
Old 08-01-2009, 02:10 AM   #14
CtrlAltDefeat
I ♥ Yaris
ahh true... forgot that I had lowering springs on when I installed mine. Well on my install the weight of the car was compressing the shocks, and seemed like it would be a bit dangerous, so on stock springs you're right it might be ok, however I wouldn't risk it
Old 08-01-2009, 03:16 AM   #15
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
Suweet thread. definitely ordering a UR rear sway bar from you just for posting this!
Old 08-01-2009, 10:02 AM   #16
Revsson
Maybe sway bars would have prevented this??
http://cgi.ebay.com/ebaymotors/ws/eB...RL:MOTORS:1123
Old 08-01-2009, 12:14 PM   #17
RedRide
RedRide's Avatar
UPS just delivered Garm's sway bay (23mm) to me yesterday.
Old 08-01-2009, 08:21 PM   #18
YAR1S
YAR1S's Avatar
well damn..... now im nervous.... maybe I wont be putting this on after all unless someone helps me out.... :/
-Jen <3
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:21 PM
