Old 06-08-2015, 06:40 PM   #1
townkat
Drives: Yaris '08
i know that, but i understand that the headlights stalk just powers the command of some relays, so just few milliamperes ...
They are controlled by a set of relays, but those relays are controlled by the headlight stalk.
and my suggestion is to change the source of the headlights stalk switch, not its destination
anyway, thanks for the heads up, what you say it's true, just that i think it is not the case here..
townkat is offline   Reply With Quote
Old 06-06-2015, 09:22 PM   #2
townkat
Drives: Yaris '08
so, headlight stalk control some relay, so there is little current going trough it
You really want a relay in there to keep the headlight and ignition circuits separate. The relay allows one circuit to switch the other, without being a direct connection.
if you can detail a little bit on this i would love to understand more, what can happen bad if relay is not used, as i am very tempted to wire them directly if i can't see a direct drawback
thank you
Old 06-08-2015, 01:58 PM   #3
shepd
Drives: 2007 Yaris 5 door RS
If you put more current through a switch than it can handle, typical failure modes include it becoming unreliable, it completely failing, the item physically disintegrating (due to arcing), and at worst, fire.
If a switch is meant to control a relay (likely less than .2 amps) and you place a 10 A current through it (what your headlights draw) I would lean to the end of the list (disintegrating or fire).
shepd is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
need pinout of ignition switch mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 8 12-25-2008 10:20 AM
Ignition switch heats up kurokoma-kun General Yaris / Vitz Discussion 11 06-19-2007 02:53 PM
