Old 03-25-2011, 11:53 AM   #37
rapev-8
Drives: toyota
so i gotta remove the wiper arms when i remove the cowl??
rapev-8 is offline   Reply With Quote
Old 03-25-2011, 02:27 PM   #38
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Yes but it's optional. See Page 5 for instructions: attachment
http://www.yarisworld.com/forums/showthread.php?t=15135
Old 06-04-2012, 01:18 PM   #39
TOLMACH
Drives: soarer
I have a stupid question to everybody who knows the answer pls
Background: I plan swaping the stock shocks with blue Tokicos and retain the original springs
Step 14 and Step 19 of the manual above (see the link in the message by ToyToronto) show NUTS being placed in something that looks like a garbage bin. Does this mean I need to buy new nuts (the original ones must not be reused) . Later in the manual nut number apprears as 90179-12145.
Thanks
P.
Old 06-04-2012, 03:43 PM   #40
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Thanks
P.
I don't know the answer, but I believe the fastest way for you to find out is to call Micro Image @ (818) 610-3635. They always answer any questions you might have and will take as much time as needed for you to understand everything.
Colin Chapman disciple
Old 06-04-2012, 07:39 PM   #41
Thanks
P.
I do not know of a single person, myself included, who has tossed out and replaced those nuts with new ones.
Old 06-04-2012, 10:02 PM   #42
TOLMACH
Drives: soarer
Thanks for your opinion
Old 01-31-2013, 11:21 AM   #43
Yarflana
Drives: 2008 Base Model
Maybe I will do this after all. I was flirting with not lowering the car, but putting better struts on the front...now, it may make sense to lower it since you have to remove the spring anyways. I am only concerned about rub.
Yarflana is offline   Reply With Quote
Old 02-22-2013, 11:29 AM   #44
Yarflana
Interesting that they do not show preloading the front before fully tightening the struts as is recommended in most instructions that come with struts. Likely, if you are getting an alignment shortly after install, it doesn't matter...I guess.
Old 02-22-2013, 12:39 PM   #45
^ It's not necessary on the Yaris, if you look at how the top mounts work.
Old 03-19-2013, 03:14 PM   #46
mahout
Drives: Yaris Prius C2
This is to help those that would like to try it themselves
enjoy and be careful.
Very good but one thing left out. They need to point out that the upper mounting nut is double. Removing the top nut is the removaql one to get the shock out. The shock assembly has a nut of its own. And it isn't necessary to remove the cover plastic or wipers.
mahout is offline   Reply With Quote
Old 01-19-2015, 05:38 PM   #47
spookybathtub
Drives: 2007 Yaris HB
What is the last step (45) in that PDF?
spookybathtub is offline   Reply With Quote
Old 01-19-2015, 06:39 PM   #48
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
You mean: Wheel alignment and Head light adjusting?
Check out my Build thread:
Old 02-16-2015, 12:42 PM   #49
zen
Drives: 2014 Yaris HB
Exclamation
Not sure what I'm doing wrong but I'm struggling to remove the top nut with my offset wrench and hex key in place
zen is offline   Reply With Quote
Old 02-19-2015, 12:17 AM   #50
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
If I recall, that was one of the tougher nuts to remove. Have you tried using a cheater bar?
Old 02-20-2015, 02:31 PM   #51
spookybathtub
The torque on that nut is only 55Nm. I couldn't get it with a regular box wrench, but an offset made it easy. Rotate it so the hex key is pressed up against something, then you can get the nut loose.
Old 01-04-2018, 05:24 PM   #52
Saphe
Drives: Yaris 2010
Originally Posted by churp View Post
Good link, but removing wipers and associated cowl covers is not necessary.
Agree! Just cut off 1,5 cm of the head of the 6mm allen key and it will attach easily.
Be careful with the front anti roll bar link. If the locknut is rusty it will probably strip the inside where the allen key fits. Also clean the bolts threads so it doesnt make it seize when you are using the wrench.
Saphe is offline   Reply With Quote
Old 01-05-2018, 12:56 AM   #53
komichal
Good PDF for reference.
I also like the video by KYB. Very understandable. https://www.youtube.com/watch?v=0FEIDAFDnTA&t=436s
I will most probably change the shocks in a few weeks. The springs are not cracked. Can they be "tired" so that it would make sense to change them too despite the fact that they seem intact?
My Yaris 2007 is still on the original shocks and springs and they are nearly gone according to the suspension diagnostic test.
Old 01-05-2018, 01:00 AM   #54
komichal
To compress the springs you can easily get a compressor worth 10 bucks. It will do the job nicely, not as fast as a professional electric compressor but it is safe comparing to any other home-invented mean of compressing the coils. Compressed coil is a grenade ready to explode.
DIY needed for amplifier for sedan install YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 2 02-27-2009 10:07 PM
TRD spring install pics tristan Photo-Video-Media Gallery 10 02-20-2009 10:33 PM
Suspension install: Spring Compressors? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 09-18-2007 10:59 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
