Old 04-26-2009, 09:18 PM   #37
kngrsll
Apexing Egg!!
kngrsll's Avatar
sweeeeeet!! the g/f is buying a 23mm rear sway bar for my birthday :) :) :)
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 04-27-2009, 02:19 AM   #38
Klinton
Klinton's Avatar
Drives: 2009 Yaris sedan Flint Mica
sounds like a great lady!!!
205/45/17 Nittos/ KN tyhoon 69 intake
EURO areo muffler / DF 210 Springs
NST 10% Pulley/ 15% tint
600watt rockford punch 12" subs and amp
micro image rocks!
Klinton is offline   Reply With Quote
Old 04-28-2009, 04:06 AM   #39
fuji
fuji's Avatar
Drives: Polar White Yaris HB
I just ordered mine. Might have to beef up the front later!
fuji is offline   Reply With Quote
Old 04-28-2009, 10:07 AM   #40
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
We seem to be missing the "banging head against wall" smiley. So, you'll have to use your imagination and picture me banging my head against the wall now.
Old 04-28-2009, 03:55 PM   #41
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Old 04-28-2009, 04:22 PM   #42
justjesus
justjesus's Avatar
Drives: 2008 Liftback
yup yup.
Good write up / driver's impression.
Old 04-30-2009, 11:55 AM   #43
detroiter
detroiter's Avatar
I'm curious how your driving experience has been since it's been some time from installing your Ultra Racing bar, any updates since you've had some seat time with it?
Old 04-30-2009, 12:03 PM   #44
Loren
What?
Loren's Avatar
I work from home, so I don't put a lot of miles on the car. Since the last update that I made Sunday, I've driven the car exactly once. Nothing new to report. I like it, it works for me, not much more to say.
The more I drive with it, the more I'm going to get used to it. I don't expect I'll have anything more to add. The initial impressions were the most relevant things I could tell you, and that is past. I'd have to change the car back to the way it was before in order to give that same level of comparison again.
I'll post up after I actually do an autocross in full-competition mode and review that aspect.
Old 04-30-2009, 12:36 PM   #45
CompanyXPaladin
Drives: 08 Yaris 5-speed
I just got my 19mm bar 6 weeks ago - now I want the 23mm bar.. Curse you, Loren!
Nice review - thanks for the write-up.
CompanyXPaladin is offline   Reply With Quote
Old 04-30-2009, 12:49 PM   #46
detroiter
detroiter's Avatar
I see what you mean. Well thank you for what you have contributed so far, looks like my TRD bar might be a thing of the past and will look to the future with a UR one
Old 04-30-2009, 01:12 PM   #47
CtrlAltDefeat
I ♥ Yaris
So the UR 23mm seems to be better then the 19mm TRD... wonder if that's because of the tighter fitting of the UR or the size. When I bought my UR Sway bar only the 19mm was available unfortunately, and I wonder how much of a difference it would have been with the 23mm... any thoughts, Loren?
Old 04-30-2009, 01:40 PM   #48
Loren
What?
Loren's Avatar
"Better" is relative to what you expect from it and what else you've done to your suspension. For the average street driver with an otherwise stock or near stock suspension, the 19mm bar is probably all you really need.
The 23mm is "better" for me not because of the tightness of fitment, that is purely incidental and in no way effects how the bar works. It's better for my needs because it is a larger diameter and therefore stiffer. Being stiffer, it does everything that a rear stabilizer bar does to a greater degree, which is good for the kind of competition driving that I do.
"How much difference" between the 19 and 23mm bars? 4 millimeters! I can't quantify it any more than that. I've already reviewed it in comparison to the TRD 19mm bar on MY car, that's all I can do, man.
Will a 23mm bar be "better" for you? I can't answer that. I will say this, however... I subscribe to the "if it ain't broke, don't fix it" principle. With the stock suspension, the body roll is awful and a 19mm bar fixes that. The problem *I* was fighting was understeer in a competition environment. The 23mm bar did a better job of fixing THAT problem. If you're not having that problem, then you don't need to fix it.
Old 04-30-2009, 03:36 PM   #49
CtrlAltDefeat
I ♥ Yaris
hmm ok well my ultimate goal in the future is to buy a DD and turn my current Yari into a track car. I would have liked to have gotten a 23mm and not have to buy the same part twice, but my then maybe I'll need a new one (i think they lose their stiffness after a while, right?) If not I'll see if I truly need it by then...
Old 04-30-2009, 03:52 PM   #50
Loren
What?
Loren's Avatar
Um, no, they don't lose their stiffness after a while.
Old 04-30-2009, 04:12 PM   #51
CtrlAltDefeat
I ♥ Yaris
oh ok... I figured like the chassis itself, it would lose it's stiffness after a while
Old 05-01-2009, 10:13 PM   #52
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
I got a question will sway bar relief the rear wobble I get sometimes in the highway at speed around 70mph? normaly it's on windy days, wide turns and well highway stuff..
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 05-02-2009, 09:11 AM   #53
Loren
What?
Loren's Avatar
Yep.
Old 05-03-2009, 09:58 PM   #54
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
It won't elmininate but it helped mine out a lot (19mm UR sway bar)
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
