#1 |
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
Can't wait to see the results, best of luck to you guys and thanks for being the ones to test this all out!!
^I wouldnt be happy either, lol.
If mikey can post the part number he used, Id probably look for one too, that would be so sweet. |
#3 |
SIPNDEW
i will when it comes in. i dont remember what it was. i ordered it from the dealer so i know its gotta be right.
#4 |
ellenbetty
Drives: 2 2007 Yaris 3 door liftback Join Date: Nov 2008
I remember reading warnings about loss of odometer reading can occurs when the car's battery is disconnected. Warnings to involve the dealer when disconnecting the car's battery. The dealer can handle reprogramming the odometer when the battery is reconnected. So my guess is if you replace the gages and the new odometer reading is wrong, take the vehicle to the dealer and have the odometer reprogrammed with the correct odometer mileage.
#5 |
^ if this was the case all the guys that have changed there leds would have experienced this issue and after do them in mine the odometer memory remains.
#6 |
SIPNDEW
i have the new S cluster in my car ready to be installed tonight.
#7 |
SIPNDEW
here is the final verdict!
everything swapped over fine and plugged right up. it WILL need to be programmed though as the miles will NOT carry over. not sure about 08s but thats the case on my 09. |
#8 |
Did you get an 08 or 09 combination meter? Also, what is the part number on the one you received?
#9 |
╚══════════RN
Very cool. Please keep us updated when you get it reprogrammed -- any obstacles that kind of stuff.
#10 |
╚══════════RN
And pics!
#11 |
![]() Drives: 96 Bonneville SSE/08 Yaris LB Join Date: Oct 2008
Absolutely fantastic news.
#12 |
SIPNDEW
i got an 09 cluster. there were no problems installing it at all, it was very easy and took about 10 mins or less and you only need a phillips head screwdriver.. ill take a pic later tonight for you guys and post a pic of the box with the P/N.
#13 | |
You may want to try for the heck of it disconnecting the negative battery cable for a couple of minutes to see if perhaps on a cold boot the ECM and the combination meter do some type of a sync. |
#14 |
SIPNDEW
ill go do that right now and let you guys know here in a few mins. im at work so i cant upload pics or anything because of the blocks.
#15 |
SIPNDEW
well the negative terminal cant be taken off because of the strut bar being almost on top of it. ill have to tinker with it when i get home and dont have to be away from my desk for a long time. ill let you guys know later.
#16 |
You can try just popping the two ECM connectors.
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 HB, A/T, Power W/L/M Join Date: Oct 2008
8380052P10 =$385.60
Instrument panel - Cluster and switches - Cluster assy - W/o abs W/s model - Hatchback 2008
Never take eyes off opponent - Bruce Lee |
#18 |
SIPNDEW
for a 2009 the hatches auto and manual share the same part #. and they all have ABS so the 1 part number i post for 2009 will fit all 09 hatches
| DIY Oil Pressure Gauge Install | LtNoogie | DIY / Maintenance / Service | 13 | 11-20-2009 04:13 PM |
| A-pillar gauge pod | Tonavi | Cosmetic Modifications (Exterior/Interior) | 26 | 02-26-2009 07:35 AM |
| Yaris safety pack - where is it located? | signs | General Yaris / Vitz Discussion | 5 | 02-22-2009 06:43 AM |
| A-Pillar gauge pods that can fit tweeters? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 11-23-2008 02:25 PM |
| Gauge Pod for Liftback? | eight_heads | General Yaris / Vitz Discussion | 2 | 06-07-2007 10:41 AM |
