Old 11-15-2009, 09:06 PM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I'm convinced.
Old 11-29-2009, 05:54 PM   #2
docB
Drives: '09 Yaris Sedan
What sway bar did you add Lweis? I leased this car so anything I would add needs to come off easily.
doc
docB is offline   Reply With Quote
Old 12-02-2009, 08:18 PM   #3
advocate
Drives: car
All sway bars install the same and in under 10 minutes by a knowledgeable person. The thicker the bar the more roll resistance that is added. But obviously for you hypermilers, thicker = weights more = slightly less MPG. So take it for what it's worth.
There are 19mm, 22mm, and 23mm swaybars for the Yaris.
Old 12-02-2009, 08:53 PM   #4
There are only 19mm and 23mm as far as I know. TRD is 19mm.
UR 19mm = 12 pounds
UR 23mm = 15 pounds
Old 12-03-2009, 07:07 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
UR 19mm = 12 pounds
UR 23mm = 15 pounds
Ouch!!! So much for getting one of those.
Colin Chapman disciple
Old 12-03-2009, 08:58 PM   #6
Loren
What?
Loren's Avatar
Conventional wisdom says that a Yaris loses about 1mpg for every 100 pounds that is added to it. So, a 12 pound swaybar would maybe take away .12 mpg.
Honestly, I do think that slowing down less for turns (that you'll be able to do more confidently after adding the swaybar) would make AT LEAST that much of a difference.
Old 12-04-2009, 10:42 AM   #7
why?
why?'s Avatar
Drives: Yaris LB
You are right for normal peoples, and if i were to even think about any type of racing it would prolly be a must add. But I am kinda nuts, and am planning on removing the rear interior pieces for weight reduction soon. Just a bit lazy, lol.
As for corner confidence, I love that rear end stepping out, that stuff is just fun. Drifting is my type of entertainment. Speed up into the corners, don't slow down!
lol losing control because you're too fast into a corner and you hit the grass is kinda nuts. I need to learn more about drifting.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? thomasward00 General Yaris / Vitz Discussion 3 07-12-2007 01:22 AM
