Old 04-09-2010, 11:07 AM   #37
Jerkratt
Jerkratt's Avatar
so there IS a relay?! let me knwo where it is
"It hurts more when its wet"
Old 04-09-2010, 12:05 PM   #38
There is not a relay - The seatbelt latches are direct inputs to the SRS ECU.
I can disable the chimes for either or both seatbelts via my TechStream tool, and once I get the YarGauge done, the PC interface option for it will allow people to do it themselves.
Old 04-09-2010, 12:14 PM   #39
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
The only reason to disable it would be hauling something such as a heavy bookbag in the front seat. Other wise it's a good reminder...I wanna know how to change it to something that says "PUT YOUR SEATBELT ON PASSENGER" or something to that extent...
Old 04-12-2010, 03:47 PM   #40
fidgell
Drives: 2006 Yaris RS 3 door
fidgell is offline   Reply With Quote
Old 04-16-2010, 09:31 AM   #41
pawngilly
Drives: toyota belta
I do not see the need to disable the seat belt warning , but usually grab the passenger buckle from the other side and plug it into the drivers latch..presto..no sound .
Why go all to that trouble ?
pawngilly is offline   Reply With Quote
Old 04-16-2010, 09:46 AM   #42
1stToyota
1stToyota's Avatar
I grabbed a free short seat belt extension from the dealership and use it in the passenger latch. I can't very well buckle the passenger seat belt with my dachshund riding shotgun, so I came up with that easy solution..
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 05-03-2010, 12:29 AM   #43
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
What about this?
Originally Posted by vodkalush View Post
What for:
If you want to disable your seatbelt alarm. I tend to do alot of work on/in my car and I hate the alarm when I turn the car on. So I wanted away to temp disable the alarm.
How about doing this? It's rather simple....
http://www.scionxdforum.com/forum/sh...Q5fAccessories
This seatbelt a small but useful 3 inch extension to the female receiver installed on your car/truck/van. Between model A & model B it was designed to fit 98% of the vehicles produced in the last 30 years. It is a personal seatbelt extension that simply clicks in when you are ready to GO! Take it with you between vehicles and on trips. Our seatbelt extension has been designed from the ground up to be more compact and more compatible with your vehicle. Note: Our seatbelt clip will stop your seatbelt alarm from going off
bobolinko is offline   Reply With Quote
Old 05-03-2010, 10:50 AM   #44
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
not a bad solution, but at 25 bucks a bit pricey for some...plus some may find it bulky and gaudy looking...but once again, not a bad solution...nice find...
Old 05-03-2010, 11:15 AM   #45
1stToyota
1stToyota's Avatar
I like it. Sort of the approach I took, except mine was free from the dealer. Since my daschund uses that seat I throw a towel on the seat and no one knows it's there, unless they need the seat, then I simply unlatch it so they can use the belt w/o the extension.
2008 Scion xD
Old 06-03-2010, 01:56 AM   #46
Focus_Sh1ft
Focus_Sh1ft's Avatar
I couldn't get this to work. I tried a 2.2k, 5.6k, and 10 ohm resistor and no dice.
Anyone have any advice? The dealership refuses to disable it for me because apparently it's a federal law to have seat belt sensors now
Old 06-03-2010, 07:24 AM   #47
The seatbelt latch has an active circuit, so you can't just bypass it with a resistor. Your best two options are to 1-Find someone with a TechStream tool and have them disable it for you or 2-remove the piezo chime from the cluster.
Old 02-15-2023, 10:16 AM   #48
dumpstar
Drives: 2008 Toyota Yaris
I have no advice-- but I am in the same boat. It did not work for me. All splicing in a 2.2k ohm resistor did was make the airbag light come on too. Did you figure out a solution?
dumpstar is offline   Reply With Quote
Old 02-15-2023, 02:52 PM   #49
enviri
enviri's Avatar
Drives: 2010 Yaris
ebay the toyota techstream cable and software for like 35 dollars and literally save yourself the headache, then take a minute to disable it
Old 02-15-2023, 06:11 PM   #50
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
This.
I fished an old Lenovo Thinkpad out of an E-waste bin, tossed in a 1TB hard drive, bought a cable and downloaded a totally legal copy of Techstream. Now I can mess around with vehicle settings. Unfortunately there isn't a whole lot you can adjust with the Yaris but there are a handful of things, one being that seat belt light.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
