Old 10-13-2009, 08:17 PM   #37
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
When you say intake, do you mean intake manifold, or just CAI?
Old 10-13-2009, 08:17 PM   #38
ozmdd
ozmdd's Avatar
Which cat did you delete?
Old 10-14-2009, 12:54 PM   #39
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
-The one without the O2 sensor
-I mean CAI.
I Drive a 129whp Yaris ;)
Old 10-16-2009, 12:02 AM   #40
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Originally Posted by hatchbackkid82 View Post
You're right, it was a simple install, but the issues that come along with this mod aren't worth the mod itself IMO (Oscillation, CEL, No smooth transition into DFCO, and one members car just shut off if remember right) The install time is short, but trying to get it to play nice withthe ECU is another thing. Don't get me wrong thoug, If i could throw this TB on and not have any issues i would have kept it on, but i had the first 3 problems that i mentioned above. So it had to come off, i think there are only a handful of memebers that have done this sucessfully
That was me. finally ran perfect with no CEL/oscillation at all and 5 minutes later at a stop light it just died and left me stranded 20 miles from home
Old 10-16-2009, 12:12 AM   #41
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Wow that sucks...
It's weird how inconsistent this mod is turning out to be... Some have no problems and others, well...
you can rotate the inlet connections on the tb to match the angle of the 1nzfe throttle body
Oh I just ended up using a dremel... Came out perfect but took a while to get there.
Old 12-14-2009, 09:33 AM   #42
SEVEN
Drives: 07' HB Black
Originally Posted by YarisPR View Post
Maybe it has to do with my custom intake, maybe.
My mods:
-Intake
-Underdrive Crank Pulley
-Header
-2" custom exhaust (only 1 cat deleted)
-1zz TB (its on right now, but as I mention, it has done it without the TB)
-Nothing else for now
I haven't scan it because the CEL goes off as soon as it gets back to normal.
This might be a good mystery to solve.
Check the spark-plugs, I was running on nitrous when this first happened, after that it kept happening and I didn't know what it was (although it only happened while I was using nitrous) I asked my friend, he told me to check the spark plugs, and surely, 2 of them were burned to sh*t. Hope this helped.
When life passes you by ... dowshift
SEVEN is offline   Reply With Quote
Old 12-15-2009, 04:35 PM   #43
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I did charged my spark-plugs recently and it hasn't happend again
Old 02-12-2010, 01:40 PM   #44
So has anyone actually tried the 1ZZ TB with a bored out intake manifold so the two fit one another?
Old 03-14-2010, 12:57 AM   #45
xbalance
Drives: stock
i having problem to find a 1zz TB beside 1zz TB that able to install in our 1nz manifold is there any other DBW TB we can install?
xbalance is offline   Reply With Quote
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
Intake for the 1ZZ throttle body? fuji Performance Modifications 9 06-14-2009 12:02 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
