Old 10-07-2009, 02:56 PM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
1ZZ throttle body
hey guys
please explain how the throttle body works better on the yaris ? does it give better power ? if so , i wanna try fitting it to my 1300cc 2NZFE , as so far , all the 1500cc aftermarket parts work on mine. has anybody got good experience in changing it and what differences they have felt ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 10-07-2009, 03:00 PM   #2
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
The idea of a larger TB is that it allows greater airflow volume into the intake manifold. This should increase HP slightly. You'll need someone who knows more to tell you what part of the powerband it affects most, though I hear reports of people's butt dyno thelling them the midrange is better.
Old 10-07-2009, 03:16 PM   #3
are you dbw? i have an extra 1zz throttle body if you wanna buy it...
Old 10-07-2009, 03:29 PM   #4
hatchbackkid82
Drives: .
This mod is good if you can get it to work, i think there are only a hand full of people that have done this sucessfully. I had it on my car, it did help the mid range, but it started throwing CEL's and started oscillating. I had to take it off. If you get it to work great, i just wouldn't mess with it though. Too much trouble for one mod
Old 10-07-2009, 03:46 PM   #5
jt258
jt258's Avatar
Drives: 10' corolla ce
mine oscillated until i did the throttle body bypass that stopped immediately.did the 1nz chip swap. my stopped throwing cel after 3wks.
jt258 is offline   Reply With Quote
Old 10-07-2009, 03:49 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
In my case it has been a pretty cool mod to DIY. The only real PITA was getting the hose to fit. I swapped the chip and bypassed the coolant line. I've never had any CELs and it's been running strong for at least 5000kms. I do get a high idle (~2.5K) for the first couple of minutes and some oscillation (~500 RPMs) when warm.
The car feels more responsive and it is most noticeable in the mid to high range.
Old 10-07-2009, 04:00 PM   #7
you can rotate the inlet connections on the tb to match the angle of the 1nzfe throttle body
Old 10-07-2009, 06:37 PM   #8
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
The Yaris throttle only opens to 80% at WOT IIRC, so anything of a larger diameter will be limited as well, although you're increasing the amount of air to the engine regardless.
My 1ZZ TB has been on for over 5,000 miles with no issues. No chip swap, I just let the ECU do it's thang. No CEL either, although I had one initially so it might have gotten tired of displaying it on the cluster.
I have a high idle like tk when cold, (2.5K) but it goes away when the engine warms up.
Old 10-07-2009, 07:30 PM   #9
frownonfun
frownonfun's Avatar
i think i've asked you this before but how much?
I crush you like tiny clown car, because you are clown, yes?
Old 10-07-2009, 10:27 PM   #10
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I had a hell of a time with the mod. Loved the extra power/response but after 2 weeks of messing with it and having horrible issues with oscillation and CEL's having to get my car towed 25 miles after my engine suddenly died and then refused to idle after work I gave up and threw the stock throttle body on.
Old 10-08-2009, 12:37 AM   #11
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
This is one mod, even though I'll get help from my mechanics on this, still am afraid to mess with. I need my car practically everyday due to school and work.
I'll avoid this till further down the road a easy slip on, slip off solution is worked into this 50/50 worry free modification.
Old 10-08-2009, 04:43 AM   #12
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
mmmm , thanks for all the info guys , gonna see how my car goes after i do the K&N typhoon intake , DC sports header , and the full de-cat and 2" exhaust.
anybody got any idea of aftermarket cams ??
JDMtuner
www.jdmtuner.co.za
Old 10-08-2009, 08:18 AM   #13
http://www.microimageonline.com/foru...stom-cams.html
Old 10-08-2009, 08:23 AM   #14
hatchbackkid82
Drives: .
Just leave the stock TB on, it's too much of a PITA for like 2-3 hp
Old 10-08-2009, 10:02 AM   #15
JapRulezz
JapRulezz's Avatar
Drives: yaris sedan 2NZ-FE
i own a 2NZ-FE and the K&N typhoon is nice , but i dont think it yields 4.5 HP like the 1.5 version... i think the exhaust will be a good mod with the intake
but i cant stand that loud noise on small speeds
JapRulezz is offline   Reply With Quote
Old 10-08-2009, 05:21 PM   #16
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I wouldn't call 4 bolts and some coolant line a PITA....
Do it It won't take you more than 30min. for 2-3HP
I Drive a 129whp Yaris ;)
Old 10-09-2009, 08:35 AM   #17
hatchbackkid82
Drives: .
You're right, it was a simple install, but the issues that come along with this mod aren't worth the mod itself IMO (Oscillation, CEL, No smooth transition into DFCO, and one members car just shut off if remember right) The install time is short, but trying to get it to play nice withthe ECU is another thing. Don't get me wrong thoug, If i could throw this TB on and not have any issues i would have kept it on, but i had the first 3 problems that i mentioned above. So it had to come off, i think there are only a handful of memebers that have done this sucessfully
Old 10-09-2009, 07:36 PM   #18
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
sorry but
what's PITA? DFCO? IIRC? and WOT?
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
Intake for the 1ZZ throttle body? fuji Performance Modifications 9 06-14-2009 12:02 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
