Old 11-10-2009, 03:51 PM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
What about this Oil Catch Can?
http://cgi.ebay.co.uk/Viper-Performa...item53ddc7404e
Do you guys suggest me to buy this for my turbo 1NZ?
Old 11-10-2009, 03:59 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
In any case, they look nice.
Old 11-10-2009, 05:15 PM   #3
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
I wouldn't consider buying a catch can unless you can see what is inside it and how it is baffled etc to help the oil vapour condense. Alot that I have seen have nothing inside at all. Cheap but far from ideal.
rob323 is offline   Reply With Quote
Old 11-10-2009, 07:13 PM   #4
1NZYaris1
1NZYaris1's Avatar
or you could buy the new MicroImage Branded ones , they are baffled
with S/S Wool from memmory , and they are a great price
Old 11-11-2009, 01:52 PM   #5
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I checked MI store and can't find them...
Old 11-11-2009, 02:44 AM   #6
Parmas
Parmas's Avatar
Do you know about a particular brand or one you can suggest that suits me best?
Old 11-11-2009, 02:54 AM   #7
rob323
No I can't sorry, not one that is readily available over your way anyway. It's just general advice.
I have always made my own to suit the individual vehicle in the past.
Old 11-11-2009, 01:25 PM   #8
Parmas
Parmas's Avatar
How can I know if the catch can I am seeing is good for my engine?
What Dimensions? LxBxH? Is there a rule to calculate with?
What about fittings dimensions? In, Out & Top?
Old 11-11-2009, 03:11 PM   #9
rob323
In general, the bigger, the better. The larger the volume, the more room for baffles and the more time the oil vapour has to condense and drop out of the air.
My thoughts on size:
Street car running up to 15 psi - 0.5 to 1 litre in volume.
Street car running over 15 psi - minimum 1 litre in volume.
Race car - 2 litres minimum.
Old 11-11-2009, 04:29 PM   #10
Parmas
Parmas's Avatar
Are you sure on that 2litres? We are still talking about a yaris right ?
I think one litre is enough for a weekend 16psi drag race car right?
Ray has some for me to post up and I am just getting in some very nice Simotas that will be less expensive than the one you found there.
Today 08:33 PM
Will check them for sure if it's a fair price including shipping
Old 11-11-2009, 04:34 PM   #11
rob323
Nope, serious. A race (circuit) car (Yaris or otherwise) is probably on boost for at least 50% of the time, compared to a street car which would be lucky to be on boost for 5% of the time. If you are just doing drags, then 1 litre would be heaps.
Do you even have blowby problems in your car or is the catch can just for looks?
Last edited by rob323; 11-11-2009 at 04:37 PM. Reason: DIdn't read the above post fully.
Old 11-11-2009, 02:33 PM   #12
^ I can't find them either, must be a hoax. Just kidding, we need to post them up.
Old 11-11-2009, 02:35 PM   #13
1NZYaris1
1NZYaris1's Avatar
Shit Stirer
And also becuase they are on my Work Bench.
Old 11-11-2009, 04:45 PM   #14
Altitude
Altitude's Avatar
I thought that might be the case...
Old 11-11-2009, 02:35 PM   #15
Parmas $100 USD is a little steep.
Old 11-11-2009, 04:45 PM   #16
Parmas
Parmas's Avatar
What do you mean by "blowby"?
Presently the 2 tubes are just disconnected from the top cover. When I check the enginebay I can see some fumes coming from them also on hot idling especially.
Old 11-11-2009, 09:55 PM   #17
yaris-me
Learn to Relax
On the compression stroke, some of the compressed air/fuel mixture escapes pass the piston rings to the crankcase. That's called "blowby." The escaping gas (blowby) is forced up the oil drain channels in the block and forces oil and gas (blowby) out of the PCV, which is what the oil can is for. The oil can captures the oil and allows the gas (blowby) to go to the intake manifold.
Old 11-11-2009, 10:45 PM   #18
1NZYaris1
1NZYaris1's Avatar
:c lap:
Oil catch tank question window_lee General Yaris / Vitz Discussion 1 07-14-2009 08:04 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
