Old 11-26-2009, 12:21 AM   #37
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Originally Posted by Wattz View Post
But I'll stick with manufacturer recommended fuel octane.
Barring modifications, I think that is a good idea.
RUFFSTUFF is offline   Reply With Quote
Old 11-26-2009, 12:39 AM   #38
Wattz
Drives: 2008 Yaris Hatch
My original post was all from memory. If the link worked (it's the full manual), you could see that the section before that mentions that the engine may knock at times and that it's normal for it to do so occasionally. That's where my engine knock statement came from.
Considering that premium fuel would exacerbate cold start problems (regardless of the root cause), I think Ford's general statement regarding premium fuel stands well enough on its own. These small engines are designed for fuel that burns easily. Using a higher octane is working against the design.
Wattz is offline   Reply With Quote
Old 11-26-2009, 07:18 AM   #39
RUFFSTUFF
Engine knock normal? Ughhhh. Not to pick hairs but premium fuel is not going to cause engine knock. Not a general statement (at least what you posted) as cold starting relates to a specific time in the cars' operation.
Definitely agree that running premium fuel in a low compression motor designed to run regular gas is not going to make it run better... but with less power and perhaps lower efficiency. Unless, of course, it is a Ford motor that knocks occasionally, so I supposed Ford would have you run tap water...
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 11:43 PM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-09-2009 12:26 AM
Review: Adjustable Sway Bar End Links m911gt Performance Modifications 9 04-29-2009 10:25 AM
FT: Polar white Front End in So. Cal Walter Items for Sale by private party 33 01-16-2007 01:11 AM
For trade, polar white front end Walter California 0 01-09-2007 12:38 AM
