Old 10-13-2010, 10:35 PM   #37
Originally Posted by magnum23 View Post
Yes that is good, mine is exactly as the picture you posted, where exactly is this part, (The silver box on the passenger side of the firewall)?
Pop the hood and look to the left:
Old 10-13-2010, 10:41 PM   #38
magnum23
Drives: Blue,Sedan
Mine is 89661-52J50
magnum23 is offline   Reply With Quote
Old 10-13-2010, 10:47 PM   #39
Mine is 89661-52J50
OK - That's the same as my 09 LB, so the ECM is fine.
Do you have a volt meter and know how to use it?
Old 10-13-2010, 10:59 PM   #40
magnum23
Drives: Blue,Sedan
I dont have one accesible right now? But why I should check? What do you think is the problem?
Thanks in advance.
Old 10-13-2010, 11:05 PM   #41
Thanks in advance.
If you measure the voltage between the blue and brown wires (with the ignition in the on position) at the connector under the dash, you should see 12V. If you hold the on/off switch it should drop to 0V and then pop back to 12 when you release it. That's a good starting point.
Old 10-13-2010, 11:13 PM   #42
magnum23
Drives: Blue,Sedan
I will try that tomorrow morning and post the results, thanks for your help, looking forward to that cruise control!!!!
Old 10-14-2010, 11:16 AM   #43
magnum23
Drives: Blue,Sedan
I tried to get a read between the blue and brown wires with a digital multimeter, but It dont display any voltage, Im not really sure but I think Im doing it right. I used a Craftsman digital multimeter, put the knob in the VDC section, in the 20 value, and the cables the black in com, and the red in V, mA. I tried in the end of the plug and directly to the cable and nothing.
What Follows?
Thanks in advance.
Old 10-14-2010, 11:23 AM   #44
What Follows?
Thanks in advance.
You have the meter setup properly. The important thing is to make sure that the metal tips of the meter probes are actually touching the metal of the connector pins. You want to go in from the side where the blue and brown wires enter the connector.
Also, make sure you have the key in the ON position when taking the measurement.
Old 10-14-2010, 12:01 PM   #45
magnum23
Drives: Blue,Sedan
Ok, I checked again and there is no voltage reading, I tried the same with another plug in the wiring and got a 12v reading, I think there is no voltage getting to the CC switch thorugh the plug.
Old 10-14-2010, 12:28 PM   #46
OK. The next thing to check is if the ECM pin is actually there for the blue cruise control wire. You can remove the connector (you press in on the gray part and then lift it to release the connector). If you look in the hole side of the connector, you will see that some holes have metal visible and others do not. Check the pin circled below (note that the connector in this photo does not have visible metal, so it is lacking the pin for cruise control):
Old 10-14-2010, 12:40 PM   #47
magnum23
Drives: Blue,Sedan
I think that is the problem the pin is not there on that side.
Old 10-14-2010, 12:43 PM   #48
If that is the case, you'd need to follow the procedure on the first page for the 2008 or older Yaris to add the pin, and then run the wire from it to the blue wire. The brown should be fine, as that one is just a ground.
Old 10-14-2010, 12:48 PM   #49
magnum23
Drives: Blue,Sedan
Ok, but where does the blue wire from the switch should lead? They just cut it on the middle from the cabin to the ECM?
Old 10-14-2010, 01:02 PM   #50
The wire goes from the ECM to a junction connector that is way up under the left corner of the dash. From there a second wire goes from the junction connector to the connector under the steering wheel.
Old 10-14-2010, 09:20 PM   #51
magnum23
Drives: Blue,Sedan
I will be running that wire tomorrow morning then, Do I need the special connector listed for adding the connection to the ECM or could I tested just passing the cable through the space where it goes on the black plug that goes to the ecm?
Do a regular cable connector works? ( the little square ones)
Thanks for your help!!!
Old 10-14-2010, 09:23 PM   #52
You definitely want to get one of the real pins for permanent installation, but you can try the "shove a wire in" method for testing. I wouldn't try any other type of pin, as if it gets stuck you'll have a real mess.
Old 10-14-2010, 09:27 PM   #53
magnum23
Drives: Blue,Sedan
Thanks for your real fast reply, I will try the wire method tomorrow, and order the special pin from the local dealer tomorrow. I will post if it works.
Old 10-15-2010, 12:40 PM   #54
magnum23
Drives: Blue,Sedan
Update:
I did the wiring, but the cruise control icon is not showing up in the cluster, but I did what you told before, to measure the volt, and now is getting the 12 volt, and when I press the On/Off bottom on the stalk the volt drop to 0.1
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
