Old 02-20-2010, 11:26 PM   #37
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
ozmdd - that's a perfect drop height. Any ride problems?
Old 02-20-2010, 11:36 PM   #38
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Nope, but it was about 1/2" lower at first and was scuffing the front fender liners. I get no rubbing now, even on some of our rougher streets. If I take a dip or bump too fast, I'll occasionally get a momentary rub up front, but its never significant. Bear in mind I'm 40 and not tolerant of noises or rubbing, so minor to me is really minor. The handling is ridiculous with these.
If you have an axle-back exhaust that has larger-diameter tubing AND you do the rear-axle mod (relocating pivot bolt), you may get some rattling when the exhaust bumps the top of the axle. I installed a shorter, stiffer Poly hanger that took care of it, but now the axle is back in stock position (required for SCCA autocross classing), and there is plenty of clearance.
Old 02-21-2010, 03:36 AM   #39
yaris2010RS
yaris2010RS's Avatar
so hold the phone....are u using stock springs? i love to mod and i need to drop it (well tuck it) and i love ure hight, maybe even a little higher would due. but everything i do needs to be custom budget build stuff..... really thinking of jsut cutting the coils...
Old 02-21-2010, 12:54 PM   #40
ozmdd
ozmdd's Avatar
No no no... this is on Megan Coilovers. Lowering springs can give you a nice budget drop but not this low, and your stock shocks/struts will also not do their job as well. Cut springs could be even worse, since they are really soft.
If you want to get a good drop affordably, pick-up some DF210's used from someone on the forum (I saw a set for $100 in the classifieds) or some other 2" drop springs. Don't forget you will need an alignment afterwards. The install is pretty simple though. The three things you need to be sure you have are an offset 17mm box wrench, a set of metric Allen wrenches, and a strut spring compressor (loaner tool at most auto parts stores, also under $30 at Harbor Freight).
If you really want to try cut springs, I've got a set of oem take-offs (<200 miles) that I'll sell you for $40+shipping that you can cut without ruining your originals. (or cut your originals and save these for later).
If you really want the kind of drop I've got (or bigger), start saving for some coilovers. Eventually, that's where you'll go anyway, so save your $$ and don't buy new lowering springs and aftermarket struts. The used-spring method is a fun, cost-effective way to get a drop.
Old 02-21-2010, 07:49 PM   #41
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
That is pretty low but not flush, no -camber and not enough offset...looks good though! I'm a bit of a flush freak myself, just have to be into that kind of look.
Old 02-21-2010, 08:04 PM   #42
jekqmb
Originally Posted by marlondog View Post
No prob! Still trying to figure the whole thing out myself.
Flush means having the rim lip flush with the fender, this can be done by stretching a small tire on a very wide rim with a very crazy offset not meant for your car. It also requires a quite a bit of poke, rolled and pulled fenders, wheel adapters and or spacers. It can also require grinding down the calipers to so the rims clear that depends on your back spacing. You also need either custom shims or camber bolts or companys make them. Extended wheel studs come in handy as well. You can achieve the look in many ways, custom shortend struts with cut springs, coilovers, air ride... The list goes on. If your not rubbing and rolling rough your not low enough! It can cause some major problems if not done right! I've already messed a fender up and went back to lowering springs until garm hooks me up with some new goodies!
Old 02-21-2010, 08:06 PM   #43
jekqmb
The pics I posted I couldn't even fit my cell phone under my car...
Old 02-21-2010, 08:59 PM   #44
wildmongoose26
wildmongoose26's Avatar
Drives: 09 5dr Yaris
good for you?
In the picture I posted I couldnt fit a 2x4 under the car,
Old 02-21-2010, 10:59 PM   #45
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
fyi guys, most Stanceworks/Fatlace/Hellaflush guys aren't THIS big of douchebags, so don't make the association.
Old 02-21-2010, 11:07 PM   #46
jekqmb
Ummmm yes they are.....They are 10x worse! I hang out with some of the top car owners from night garage. And dont get me started on the VW guys, they are the worst when its comes to talking stance!
Old 02-21-2010, 11:09 PM   #47
Gideon
★weeaboo★
Gideon's Avatar
weird. must be a west coast thing about respecting other peoples rides.
Old 02-21-2010, 11:15 PM   #48
jekqmb
Man here in the midwest people either love it or hate, and we have one of the biggest VW chapters and lemme tell ya...Those guys will rip your ass apart if you start talking like you know anything about suspension setups. I was barley allowed to attend a local meet due to my car not looking the part. But not anymore, i took the hard road and it is slowly paying off, im not trying to be a dick, but man ive gone through hell and back here in st.louis to prove the Yaris can look amazing just like any of those cars seen on the stance sites. Im just trying to show people on this site, it can and will be done...you can pull some of the sickest setups off with the Yaris as long as you have the time and put in that effort and take everyones opinions with respect!
Old 02-21-2010, 11:17 PM   #49
90tsi
90tsi's Avatar
Drives: 09 yaris
ive been on that stl forum and there are a ton of god wannabe douche bags that have nothing better to do than try to rip on your ride if its not to there taste.
90tsi is offline   Reply With Quote
Old 02-21-2010, 11:20 PM   #50
jekqmb
Thank you sir! I have finally started earning my respect around my area.....The Yaris is coming along very nice these days and people are getting excited to see the final results!
Old 02-21-2010, 11:21 PM   #51
jekqmb
Ughhh im kind of turning into one of them....Im deleting some of my posts i made in here, haha
Old 02-21-2010, 11:26 PM   #52
Gideon
★weeaboo★
Gideon's Avatar
uhhh, well we know it can be done because it's been done before:
That said, can't wait to see some real pics of your addition!
Old 02-21-2010, 11:27 PM   #53
90tsi
90tsi's Avatar
Drives: 09 yaris
lol well dont let them cross you over to far to that darkside. i mean that stance thing is cool and all but some just dont worry to much about it.
but thats good there not on there flaming you so much i know that ass with a 240 or whatever he drove had some stupid yaris thing in his sig. I kinda figured waste of his day to go thru all that effort to do something no one really give a rats ass about. lol
Old 02-21-2010, 11:33 PM   #54
jekqmb
Hmmm are those AME's?
Help Me Get That Slammed Look... 9vapors Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 02-27-2011 10:27 AM
Daytime Pics of the Slammed 09 5door counterfiend Photo-Video-Media Gallery 32 02-16-2010 02:04 PM
Slammed Walter Photo-Video-Media Gallery 27 02-10-2009 12:30 AM
