Old 10-23-2012, 10:10 AM   #37
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
original tires: 50K
head lamp bulbs: 100K
front brake pads: 116K
and that's it. The rest is filters and oil.
SpaceShot is offline   Reply With Quote
Old 10-24-2012, 02:14 PM   #38
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by nookandcrannycar View Post
Wow. Re Maine, just the brake part of the State Inspection puts the entire State Inspection for Texas to shame.
Yeah, a lot of folks don't realize how stringent it can be in Maine. I guess that it really depends on the shop that you go to, but of course there isn't supposed to be any deviation from the guidelines. As a point of reference below unless mistaken once you get the wear bars I believe that you would fail inspection if you had to go and get a sticker.
Here are pics of my 912s for future reference with 12k miles on them. Not sure that the pics really do them justice on how bald they really are?
Old 10-24-2012, 02:19 PM   #39
harda toenail
Drives: Want a yaris
Tires at 55k. Water pump at 85k. At 89k now, everything else has been oil and filters. Battery will get replaced in next few months.
harda toenail is offline   Reply With Quote
Old 10-24-2012, 02:21 PM   #40
nookandcrannycar
They look almost as bald as can be and still have visible tread on them.
Old 10-24-2012, 04:33 PM   #41
^ grooved slicks is more like it LOL
Old 11-24-2012, 11:47 PM   #42
comk4ver
Drives: '08 Yaris
replaced the tires around 30k?
water pump before 40k
and it looks like I'm going to have to replace the battery tomorrow.
comk4ver is offline   Reply With Quote
Old 11-25-2012, 04:07 AM   #43
yariseggvvti
Drives: Yaris Hatchieback
tire 35k
battery 45k
serpentine belt 55k
alternator 71k
yariseggvvti is offline   Reply With Quote
Old 11-25-2012, 05:15 PM   #44
The Sin
Drives: 2010 Yaris Sedan
Updated 3/8/13
2010 Yaris Sedan manual
242,000 miles
Tires: Factory tires- 70k. Cooper tires - 130k
Battery: 180k
Alternator: 241k
Clutch: still fine
Brakes: still fine
Belt: 200k
Spark Plugs: 100k
I do about 10K miles a month, about 90% hwy
Use full synthetic oil, change every 7K miles
Use a K&N air filter I clean every 40K
The Sin is offline   Reply With Quote
Old 11-25-2012, 07:35 PM   #45
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
I'm curious as to who uses hyper-miler techniques (DFC or coast to stop) when it comes to brakes and tires.
rick996 is offline   Reply With Quote
Old 11-29-2012, 01:12 PM   #46
nookandcrannycar
My brakes were only 20% worn at around 208,000 miles. Yarisworld member trini_per4mance didn't have to get his first brake job until 400,000 miles. I replaced the OEM tires between 69-70,000 miles, the first replacement set of 4 at 140,553 miles and the second replacement set of 4 at 225,562 miles. Each set has exceeded the mileage rating (I think each set was rated at 60k, but one might have been 65k).
I forgot to include in the above 10-22-12 post that I replaced my battery on 9-9-12 (exactly the 3-year mark of 'life' for the battery) at 224,946 miles as a preventative measure. This second battery replaced the OEM battery at 138,055 miles, so 86,891 miles in 3 years.
Old 11-29-2012, 01:36 PM   #47
nookandcrannycar
Just hit 200,000 miles today!
Tires: Factory - 70k. Still on 2nd set of tires, getting new ones tomorrow.
Battery: 180K
Clutch: still fine
Brakes: still fine
Belts: Just started squealing, changing tomorrow.
Use full synthetic oil, change every 10K miles
Wow. If you keep up that mileage rate (and your engine holds up --- which it very likely will) for another 3 years (or less) you will probably pass (at that point) trini_per4mance as the Yarisworld member who is the original owner with the most stated miles on the original engine (472,000 as of about 4 months ago). He has a different job now, so his mileage accumulation slowed way, way down. These cars are so reliable! One member, Mazilla, bought a courier company with a 20 Yaris fleet. All of the cars had between 350,000 - 500,000 miles on them! He kept one of them (that had had the engine replaced) and now is nearing or has reached 500,000 miles on that car. You'll be passing me in just a few months .
Old 01-12-2013, 08:46 PM   #48
lilyaris'10
Drives: Yaris Hatchback 2010
I want to join the hypermiler club! I have a Yaris 2010 w/ 60k at the moment. How often are you hypermilers changing your automatic transmission fluids? Also are you doing flushes or just filter and changes? Thank you in advance!
lilyaris'10 is offline   Reply With Quote
Old 01-12-2013, 09:23 PM   #49
lilyaris'10
Though I do like to be extremely gas efficient, I actually did not mean to use the word hypermiler in my last post. I actually meant that I want to maintain my car in such a way that it lasts as long as possible! My car hit 60k over the weekend and I took it in for a major checkup expecting an ATF fluid change. However, the mechanic didn't recommend one. My car hasn't had one yet. He told me that the fluid is good for up to 100k. I'd love to hear what the experience has been from other people and specifically from trini_per4mance, nookandcrannycar and The Sin since they've been able to maintain their yaris so well!
Old 01-13-2013, 12:14 AM   #50
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Mine will hit 90 k. I haven't replaced anything in the engine bay or brake system.
I have only replaced tires, windshield, did regular oil change, filter, and spark plugs and cleaned the TB and MAF.
HELP.
Old 01-13-2013, 09:50 AM   #51
nookandcrannycar
I go above the PSI recommendation from Toyota, but below the maximum as stated on the tire (44 PSI). I keep it at 38-40 PSI. That's about it, up to this point.
Old 01-13-2013, 10:58 AM   #52
nookandcrannycar
I don't know re ATF. Trini, The Sin, and I all have manual transmissions. I have yet to change my transmission fluid, and Trini didn't change his for the first time until he replaced his clutch for the first time at 448,000 miles.
Old 01-13-2013, 12:46 PM   #53
Kal-El
Kal-El's Avatar
131,000+ miles
Everything is still original with the exception of the belt, battery, & tires.
Even has the original spark plugs which I keep telling myself to replace at some point. Car runs perfect so it gets put off.
I believe the Yaris to be immortal.
Old 01-15-2013, 11:52 AM   #54
nookandcrannycar
I have some info for you re ATF fluid change intervals. UberSilver replied to me on an oil change thread and added that he drives his car fairly hard, so he will be changing his ATF fluid once a year (time period rather than miles). UberSilver doesn't have high mileage on his Yaris yet, but he previously drove another Toyota 500,000 miles with about 20,000 mile oil change intervals, so I'd say his judgement is pretty darn good re getting longevity at the lowest cost. This may not apply to you, as you may have a different driving style, but more information can't hurt.
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Summer tires ! Franck_Qc Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-02-2009 09:36 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
FS: Stock tires on steelies spkrman Items for Sale by private party 9 04-12-2007 06:45 PM
