Old 06-01-2010, 11:03 AM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
lol. you don't like that smell? I LOVE that smell. You weren't even going to run a resonator?
Why don't you do what barber did?
nope was going to be straight thru. right now i have from the res back.
Old 05-30-2010, 10:09 PM   #2
I've unplugged the VVT-i solenoid before just to see how the car went. It was night and day. WAY more consistent power and probably a few more up top.
(Unplugging the VVT-i solenoid retards the intake cam to 0° all the time)
Old 05-31-2010, 01:21 PM   #3
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Yes, if you can get it to work.
Old 06-01-2010, 12:38 PM   #4
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Great feedback Astroman. I'm heading to a salvage yard this evening to see what new toys I can find :)
Old 06-01-2010, 12:50 PM   #5
im not sure the throttle body actually nets whp or just better throttle repsonse. the throttle plate is about 25% bigger, so essentially when you're at half throttle its letting in the same air as the stock throttle body lets in at about 63% throttle.
the inlet to the intake manifold is pretty tight to the 1.75" stock throttle body.
i also have to say that im pretty happy with my resonator-back exhaust at the moment. id worry that without a supercharger or turbo, any bigger than 2" you'd lose a lot of bottom-end power (actually i feel like i lost some grunt with the addition of the dc header last month)
Old 06-01-2010, 06:54 PM   #6
Astroman
Modded Moderator
Astroman's Avatar
Stock TB is 2", 1ZZ TB is 2.5". NO loss of bottom end, more power is going to the wheels as the motor runs like a raped ape now.
Will deffinetly be getting a dyno done this summer when the custom header-back exhaust is done.
I will take some pics today if I can, video too
Old 06-01-2010, 07:52 PM   #7
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
nice. looking forward to see the video from u
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 06-01-2010, 09:21 PM   #8
PETERPOOP
PETERPOOP's Avatar
I wouldn't waste your money on a headerback exhaust if your only mods are 1zz TB/I/H/E etc. I'd say do it if you were boosted.
Old 06-02-2010, 10:14 AM   #9
sito
Drives: Toyota
Hi Astroman,
Is the 1zzfe throttle body a direct fit to the stock intake manifold?
Any modifications to it?
Thanks....
sito is offline   Reply With Quote
Old 06-02-2010, 10:16 AM   #10
Astroman
Modded Moderator
Astroman's Avatar
Originally Posted by sito View Post
Hi Astroman,
Thanks....
It's a direct fit, I didn't need to modify anything. If the car runs like crap and throws a CEL then you'd need to swap the chip on the TB. I was lucky, it bolted on and worked.
Old 06-02-2010, 10:19 AM   #11
sito
Drives: Toyota
Cool....
Thanks bro.....
Old 06-02-2010, 10:25 AM   #12
normally you need to turn one of the coolant lines around to reach the OEM 1nzfe lines
i assume you bought yours used from a member?
Old 06-01-2010, 08:44 PM   #13
stock yaris TB is 1.75" isnt it?
Old 06-01-2010, 11:18 PM   #14
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
Astroman,
Good to hear that everything is working out great
FunctionSpec is offline   Reply With Quote
Old 06-02-2010, 02:07 PM   #15
PETERPOOP
PETERPOOP's Avatar
Well if a supercharger is in the future, then I take back my comment about not getting a headerback exhaust. However, I wouldn't get it until after you have the S/C on or sometime soon before you put the S/C on. You wouldn't want to be driving around with 2.25" headerback exhaust and not have the S/C on. You will have no torque AT ALL! hehe
Old 06-02-2010, 02:13 PM   #16
ddongbap
Well, that'll only be true on the low end. When top end kicks in, then it'll be better.
Old 06-02-2010, 02:21 PM   #17
PETERPOOP
PETERPOOP's Avatar
Yes, but it is no fun at all. Trust me. Before I had my blitz wired to be "ON" all the time, I would sometimes drive with the compressor off. That thing had no torque and was somewhat embarrasing to drive. You would have to give it more gas to get it moving and then that would make your muffler louder, yet you weren't moving anywhere. hehe
Old 06-02-2010, 03:57 PM   #18
Yoda
Yoda's Avatar
hope this helps. it was 98* outside when i did this. The blue line is from yesterday. the yellow is from January (88* then)and before i had the res-back.
You would think i would have gained power but seems i have lost quite a bit. not sure whats the cause. Was at least expecting to gain a few from the res-back. Something is off somewhere.
I just changed my oil right before i went on the dyno tho so that maybe it but idk. I use to use valvoline synthetic, but switched to mobile 1 full synthetic. And also switch my octane to 87 rather than the 93 i use.
Mod List
AFE Intake
NST Crank Pulley
DC Header
TRD Axle back Exhaust With mandrel bent to resonator
1ZZ TB
I am running a bit lean. There is more power to be had if i got a tune but probably not worth it. Hope this helps paint a picture of what to expect.
Any questions hit me up....
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
Idea I had, but I can't figure a way to make it work... kac Cosmetic Modifications (Exterior/Interior) 4 08-08-2009 09:17 PM
YarisWorld Marketing Idea *MAD DOG* General Yaris / Vitz Discussion 30 04-12-2009 05:46 AM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
