Old 12-08-2011, 12:48 PM   #37
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
except that it's annoying on a nice new(ish) car.
I took it out for lunch and noticed it doing the same thing, but this time it didn't get really low and vibrate the cabin. must have been the really cold weather this morning.
Captain Slow is offline   Reply With Quote
Old 12-29-2011, 05:05 PM   #38
Reactor
Drives: 1nz-fe
I'm pretty sure this problem is caused by the MAF sensor sitting too close to the throttle body on the aftermarket intakes. At idle RPM it does not have the proper airflow through the sensor (it measures less air than it should).
Reactor is offline   Reply With Quote
Old 12-31-2011, 08:31 AM   #39
syntax
syntax's Avatar
would spraying with carb cleaner the intake of the TB just after the MAF would help?
may need someone to rev it up while spraying it
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
