Old 12-08-2013, 09:51 AM   #37
ex-x-fire
Google Genuine Toyota Parts.
Old 10-05-2014, 08:31 AM   #38
En4sir
En4sir's Avatar
Drives: '09 Yaris 3dr HB 5sp
I've used these people for several OEM parts after several members of this forum recommending them.
http://toyotapartscheap.com/
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
En4sir is offline   Reply With Quote
Old 10-05-2014, 09:40 AM   #39
lambros
lambros's Avatar
Drives: TOYOTA YARIS S 2009
And my water pump replaced under warranty...
lambros is offline   Reply With Quote
Old 10-05-2014, 01:03 PM   #40
nookandcrannycar
297,058 miles -- original water pump still on the car
Old 10-05-2014, 01:48 PM   #41
CB900F2
Drives: 08 Sedan
Mine was replaced under warranty at an early 30k km , now at 121k km and no issue..
CB900F2 is offline   Reply With Quote
Old 10-06-2014, 09:38 PM   #42
En4sir
En4sir's Avatar
I just turned 180,000 miles on my 2009 HB. The bearings in my water pump has been sounding knarly for the last 10,000 miles, however there are no indications of coolant leakage anywhere. I've literally spent the last 2 hours reviewing just about every water pump related post here in YarisWorld, and as a result, am inclined to replace my water pump with an aftermarket pump due to all these posts complaining of OEM pumps (Aisin brand) failing prematurely. A few have stated that they went with an aftermarket and am wondering if anyone recommends any specific aftermarket brand. NAPA sells Aisin and NPW. AutoZone sells Duralast. Advance Auto sells Tough One. Can anyone suggest a brand that they are satisfied with? And if so, how many miles have you driven since installing the aftermarket brand?
Thanks in advance.
Old 10-06-2014, 09:53 PM   #43
Thanks in advance.
I used a Duralast one on one of my Yaris. The pump had not started leaking, but had gotten grumbly sounding, particularly with the extra load of AC.
I don't think that there is anything wrong with the OEM ones. I think that without a normal tensioning mechanism that most experience premature failure due to an overtightened drive belt.
Old 10-06-2014, 10:23 PM   #44
Gogogordy
Drives: Miss my Yaris, love my Jeep jk
Originally Posted by hyprmiler View Post
not to start an argument over warranties, but I've found that putting a little bit away every month and budget for a repair before it happens saves over buying an extended warranty if you plan on keeping the car for an extended period of time.
glad you got your pump replaced at no cost to you though!
I agree....been burned a time or two on "extended warranties" with their "exclusions" etc., but I suppose it's a personal choice.
The profit margins are quite high on those programs, and the Finance rep at the dealership makes a very nice spiff for selling them, so pricing is quite negotiable....don't pay list!
You're betting against the house when you buy a warranty plan in any case, so my last advice is to make sure the underwriting company is a reputable one (Toyota, Zurich, etc) so do your due diligence BEFORE signing up for that warranty plan.
I'm the Prez at my house...in fact I cruise around in YarForce One!
When I'm not driving my Yaris, I'm doing this:
http://gogogordy1.wix.com/scooter-aficionado
Gogogordy is offline   Reply With Quote
Old 02-14-2017, 10:33 PM   #45
fj40dave
fj40dave's Avatar
Drives: '08 HB
Replaced my original Asin pump a couple day's ago.....got the NAPA lifetime guaranteed one. (NAPA Part #: 42253 [Tru-Flow Water Pumps PART # TFW 42253]) $40.99
Comes with the metal gasket, not the paper one.
Wasn't that big of a deal to do. The noise was caused me to change the pump....the motor didn't overheat or show any performance issues. Been that way for at least the last 20k. (My wife borrowed my Yaris and said something sounded wrong....and didn't like my explanation that it's just the water pump, it's fine :-)
My 2008 HB has 203,000 miles on her....best $12,600 I ever spent on a car!
fj40dave is offline   Reply With Quote
Old 02-15-2017, 08:19 PM   #46
I had my water pump and alternator replaced at 56000km back in 2008 because the bearing failed. I had the pump replaced again about a year ago at 160000km because of a very small leak around the seal.
Sent from my SM-G930W8 using Tapatalk
Old 03-11-2017, 12:00 PM   #47
Tankeryanker
Drives: 08 Hatch
I just replaced mine at 170,000. I think it was going out for awhile. It was $270 to change it.
$24 for new fluid
$75 for pump
the rest was labor.
Tankeryanker is offline   Reply With Quote
Old 03-15-2017, 12:27 AM   #48
Garth g.
Drives: 07 Yaris 2dr hatchback
I have the same colour of hatchback, I like your style. I changed my waterpump in last summer at 230,000.Also did the waterpump in my old sedan. It's a good repair to do if you want to start turning wrenches. One of the first things I learned how to do other than brakes and oil changes.
Garth g. is offline   Reply With Quote
Old 03-20-2017, 01:32 AM   #49
zoidberg444
zoidberg444's Avatar
My water pump bit the dust at somewhere around 70,000 miles. It was bad for a few months. It was making one hell of a racket. I replaced it with a blue print Chinese water pump. Which seems OK at nearly 130,000 miles. I actually have another one on my parts shelf that i got for £25. So i will just whack another one in it goes. I don't know if Aisin ever fixed the problem with the bearings in the OEM ones, i did hear something about switching from a pressed plate construction to a cast construction because of the issue.
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
Water Pump being replaced... Rental Car! slothman86 DIY / Maintenance / Service 12 08-11-2010 04:14 AM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
