Old 10-06-2014, 09:38 PM   #35
En4sir
En4sir's Avatar
Drives: '09 Yaris 3dr HB 5sp
I just turned 180,000 miles on my 2009 HB. The bearings in my water pump has been sounding knarly for the last 10,000 miles, however there are no indications of coolant leakage anywhere. I've literally spent the last 2 hours reviewing just about every water pump related post here in YarisWorld, and as a result, am inclined to replace my water pump with an aftermarket pump due to all these posts complaining of OEM pumps (Aisin brand) failing prematurely. A few have stated that they went with an aftermarket and am wondering if anyone recommends any specific aftermarket brand. NAPA sells Aisin and NPW. AutoZone sells Duralast. Advance Auto sells Tough One. Can anyone suggest a brand that they are satisfied with? And if so, how many miles have you driven since installing the aftermarket brand?
Thanks in advance.
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
En4sir is offline   Reply With Quote
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
Water Pump being replaced... Rental Car! slothman86 DIY / Maintenance / Service 12 08-11-2010 04:14 AM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
