Old 03-17-2011, 01:51 PM   #37
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Google it. Basically it's near Bowmanville. N/E of Oshawa
http://www.yarisworld.com/forums/showthread.php?t=32770
i see it.. thats not that far at all maybe this summer....thanks
Old 03-17-2011, 02:22 PM   #38
winfong
Drives: VIOS Belta
Yaris sedan Mid-pipe has 2 Catalytic converters - Flip a Coin and remove ONE.....
winfong is offline   Reply With Quote
Old 03-19-2011, 10:56 PM   #39
str8Yaris
str8Yaris's Avatar
Drives: Yaris Sedan Supercharged
Remove the second one... you will get a perfomance... i m going to take the second one off when I'm supercharged....
Blitz S/C @ 9psi
Vegas meet 2011
http://youtu.be/1IEebCmtvP0
str8Yaris is offline   Reply With Quote
Old 03-21-2011, 09:10 AM   #40
2005rs
Drives: 2005 Echo Rs
maybe this "mod" is a given not worth mentioning, but you can lighten your car by about 100 pounds by stripping out the spare tire, jack, tools, owners manual, etc. this does make a noticeable difference
2005rs is offline   Reply With Quote
Old 03-21-2011, 12:05 PM   #41
winfong
Drives: VIOS Belta
does it make a difference???.....
I recommend removing the one closest to the manifold....
Cats retains lots of heat....
your Yaris manifold "heatshield" isn't really that effective...
especially after a drive and you come to a halt.
I always have a problem with Engine bay Heat management.....
Old 03-21-2011, 12:35 PM   #42
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
I use my air scoop on hood to direct air to header/ cat .. Works well . Stole idea from the celica.
I talked to some TRD represatives about the issue of what exactly is the celica hoodscoop used for ? I was told it's mostly for drag/downforce issues and some engine airflow characteristics. Helping with higher speed stability of the FWD. And air circulation around the motor for cooler under hood temps. They said blocking off the scoop or hindering the airflow lessens the airflow through the engine bay and decreases areodynamics.
annn is offline   Reply With Quote
Old 03-23-2011, 02:40 AM   #43
str8Yaris
str8Yaris's Avatar
That's what I need a hood with a air scoop
Blitz S/C @ 9psi
Vegas meet 2011
Old 03-23-2011, 09:49 AM   #44
The exhaust isn't what's making you engine bay hot, it's the hot air going through the rad. You'd need a shroud to vent the air under the car or even better, out the hood with louvers.
Old 03-23-2011, 02:18 PM   #45
I have one for you.
Old 03-23-2011, 02:21 PM   #46
annn
ヤリスワールド
annn's Avatar
Drives: 2008 HB
Extractors on the hoods work excellent.
Old 03-23-2011, 02:59 PM   #47
beZzZ
Learning & Upgrading
beZzZ's Avatar
Drives: 2006 Yaris 5 Dr HB Black
lol i had my 23mm ultra racing sway for a week now been itching to put it on and you just made the itch worst...lol
I can help you to get rid of the itchness by selling it to me
beZzZ is offline   Reply With Quote
Old 03-23-2011, 03:13 PM   #48
marcus
toyota
marcus's Avatar
too bad i just got it installed last night.. but does it have to snow today oh well its all good.
my review:
no way in hell i could have put this on by myself it was so tight to get the upper bolts to line up needed a couple of hammering to get it in but once in everything lines up.. tighter on turns and also did notice less bounciness on the back end when ever i drive on those ripples on the street of toronto ..then it snowed this morning so i was like shi% do i need to drift now.. overall im happy with the product!
thanks garm "MICROIMAGE"
Old 03-31-2011, 11:56 AM   #49
TrashCan Monster
Drives: an egg
suspension will make a drastic change in the car's "fun to drive" factor, upgrade suspension pieces first I'd say
TrashCan Monster is offline   Reply With Quote
Old 03-31-2011, 06:28 PM   #50
str8Yaris
str8Yaris's Avatar
Nice.... now, I want it garm.... lol
I have one for you.
Blitz S/C @ 9psi
Vegas meet 2011
2008, modification, mods, performance, sedan
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 03:59 PM
2ZR-FE mods 2ZR-FE Performance Modifications 5 04-06-2011 04:22 PM
2ZR-FE mods 2ZR-FE Yaris TS Talk 9 02-09-2011 01:10 PM
mods! mods! mods! canadian_princess Cosmetic Modifications (Exterior/Interior) 32 08-23-2009 04:52 PM
Performance mods that won't affect/will hardly affect gas mileage?? Mr.Yaris Performance Modifications 15 07-30-2007 12:32 AM
