Old 05-08-2012, 05:24 PM   #37
OH yaris
Drives: 07 hatchback + 06 EVO9
Originally Posted by Ratz View Post
I take it you purchased the 23mm Ultra Racing. Can you please post some pictures? I would like to see the fit as Ultra Racing bars do not use the two additional bushings like Whiteline does.
What counts is you are happy. Congratulations.
Yes, 23mm. Install was pretty straight forward. I was stubborn and tried without taking the wheels off, but ended up doing so. It mounts using the bolt from the rear shock and an additional bolt is provided that goes through a hole a few inches forward (2nd pic). Pretty sturdy in my opinion.
first pic is from passenger side, behind door, towards driver rear tire. Second is passenger rear, and third is from behind the car.
OH yaris is offline   Reply With Quote
Old 05-08-2012, 08:48 PM   #38
catliektheif
catliektheif's Avatar
Drives: 2010 5 Door
Ah! so youre the one that got the last 23mm! i was about to get it!!!
lol okay
Old 05-08-2012, 09:45 PM   #39
Ratz
Ratz's Avatar
Drives: 2011 Yaris 4 Dr. Sedan
Thank you for posting the photos OH yaris, looks very nice. I was curious how is this swaybar installed without any bushings and I got my answer.
Yes, it looks like a very sturdy and simple installation. Also there is no worries about bushings wearing out.
Ratz
Cleverly disguised as a responsible adult.
Ratz is offline   Reply With Quote
Old 05-09-2012, 06:11 AM   #40
allyart
allyart's Avatar
Drives: Yaris Hatchback E A/T 2011
23 mm >>>> 19mm
bigger is better
allyart is offline   Reply With Quote
Old 05-09-2012, 08:20 AM   #41
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
no need to take the wheels off. if it takes you more then 10mins your doing it wrong. best 7minute mod ive ever done to a car.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-09-2012, 09:41 AM   #42
23 mm >>>> 19mm
Whiteline >>>> 23 mm >>>> 19mm
Old 05-09-2012, 10:33 AM   #43
allyart
allyart's Avatar
maybe true but whiteline is not ultra racing's product
Old 05-09-2012, 11:06 AM   #44
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
is the whiteline bar really stiffer?
Colin Chapman disciple
Old 05-09-2012, 12:02 PM   #45
OH yaris
You're quite welcome, and thanks for the thanks!
That's pretty quick, well done! You're invited to help whenever the next project comes up. I'm still learning as I go...
Old 05-09-2012, 04:44 PM   #46
I don't understand what that means. Correct, it's another company's product?
We sell both.
Old 05-09-2012, 09:55 PM   #47
spocksleftball
spocksleftball's Avatar
Drives: 2011 yaris
Will there be any ultra 25mm forthcoming? The whiteline looks...well...iffy
spocksleftball is offline   Reply With Quote
Old 05-10-2012, 12:36 AM   #48
allyart
allyart's Avatar
We sell both.
sorry to confuse you
just want to say that this thread are talking about the ultra racing and not whitelines
and yes you sell both, and at a good price too!
i just cannot understanf why in indonesia they sell the 23mm at $225, far more higher than you, consider that indonesia is malaysia (ultra racing manufacturer) neighbour. i suspect not the shipping cost is that big, maybe our import tax are higher
Old 05-10-2012, 12:47 AM   #49
Ratz
Ratz's Avatar
I would imagine it is stiffer, as my Yaris is 4 Dr. Sedan which has much more weight in the aft end and I did not like the stiffer setting. I would think it would be even more aggressive with hatchbacks. The nice feature for me was it is adjustable by choosing the forward or aft hole.
Even after reading all the comments I would still choose the Whiteline, but I had the advantage of improving the center bushings “U” bolts.
With all due respect to "allyart" comment not being a racing product, I am somewhat puzzled as, after all it is only a swaybar. If the one wheel hits the bump the other wheel is forced to go up as well. If the bar is too stiff you will end up with undesirable condition which I had experienced with stiffer setting. With Whiteline I had the choice to adjust it to my liking and know that I am at my limit.
Since Whiteline is a 22 mm bar I believe it is likely stiffer due to the center bushings configuration. I would have a hard time to think that one would want to have Whiteline bar set on stiff setting in the hatchback car, unless the road is super smooth and driver is in the manic mode.
By the way if the picture on Micro Image website is any indication, the bar is set in it’s softer setting (the end hole)
http://shop.microimageonline.com/Whi...?categoryId=-1
Cheers to all,
Ratz
Old 05-14-2012, 02:49 PM   #50
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
The 23mm UR rear sway is wayyyy stiffer than the TRD one. With the combination of lowering and this suspension add-on, the feeling of the vehicle definitely changes in characteristic. Definitely one of the best mods/value you can get for your car as the Yaris does feel a bit floaty to begin with..
Freestylin is offline   Reply With Quote
Old 05-14-2012, 02:54 PM   #51
that would be me.
Old 05-15-2012, 02:06 PM   #52
racerb
Perhaps I missed it somewhere, but what MM is the TRD bar anyway?
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 05-15-2012, 02:41 PM   #53
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Just checked mine... it's 19mm.
Old 05-15-2012, 04:08 PM   #54
racerb
Thanks man, looks like 23mm UR bar for me, well when Micro Image has them in stock again!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
TRD rear sway bar? Lewis DIY / Maintenance / Service 26 09-10-2013 02:10 PM
Yaris Rear Sway Bar Install ? Spork Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 03-20-2012 09:17 PM
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
WTB Rear Sway Bar nick.dollimount Willing to Buy by private party 2 05-27-2010 02:44 PM
rear sway bar needed vten Willing to Buy by private party 11 11-22-2009 11:50 PM
