#1 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
![]() When I get home from work this evening, I'll lay straight edges across the two rows of bolt holes and will be able to give you some x and y measurements. |
play every day
Hey Cranky,
![]() Here's some of the measurements. They're not perfect but accurate to a millimeter because I just used a ruler. Bolt holes on intake manifold to engine head connection looking at the flange from the position of the bolt holes making a W. The y distance between the two rows of bolt holes (not including the one hole that's offset) is 24mm. The x distance between the two holes on either side of the center hole is 166mm. The x distance from the center hole to the end hole which is in line with it is 163mm. The y distance beween the one offset hole and the closest hole to it is 33mm. The x distance between the center hole and the offset hole is 163mm. Hope this helps. Let me know if you need any clarification.
#3 |
![]() ![]() Drives: 2008 yaris hb Join Date: Mar 2011
This intake mod may have a chance. good luck, may the car gods be with you
#4 | |
play every day
![]() I'm a big fan of God and the natural physical laws He designed which govern the flow of events. So I keep an eye out for the signs with arrows on them that say "This Way", and have lots of fun following them just to see where they go. |
#5 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
Interesting. Some of my estimations were spot on, and others were pretty far off. I used pictures of gaskets and the head to get a general idea of the location and then used a SWAG to pin them down.
For the y-distance, did you measure center-to-center or edge-to-edge? All of the images I found showed the bolt hole centers being approximately in line with the long edges of the intake holes, which should be 30mm tall. |
#6 | ||
play every day
I'm taking everything down to the machine shop today to get the flange and throttlebody adaptor made up. ![]() ![]() With the Corolla manifold, the stock Yaris manifold, the white intake gasket, and all of the bolts and studs right there in front of them to, it should be a simple job to fabricate the parts out of 25mm aluminium stock. Last edited by tooter; 06-13-2012 at 12:28 PM. |
#7 |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
such a great little project.
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#8 |
play every day
I just have to tell you guys about something that has nothing to do with our cars.
There is something so fascinating about the flow of events and how sometimes you find yourself in just the proper place in relation to them where you can surf them like a wave. Today was one of those times. Took the parts to the guys I know who have the CNC machine. No problem! ![]() Now... this is what I didn't know. The guy who is creating the CAD file and running the CNC was a design engineer for the Ford Motor Company. And what job did he do? He designed INTAKE MANIFOLDS! When he saw the project he took a genuine personal interest in it. This is turned out to be a perfect synergy of events. To come into contact with just the right people at just the right time. Sometimes the way events unfold can be more fascinating than the events themselves. The prototype manifold should be up and running in under 2 weeks.
#9 |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
Whats the cost on the machine work, flange and TB adaptor?
This project is moving along nicely, well done...I'm excited to see how it turns out.
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
#10 |
play every day
Don't exactly know yet... just whatever the cost of the time and materials comes out to produce a couple sets. This guy is an honest man who will make a fair profit for his time and talents so I let him determine the price, and just said "Let's do it."
![]() Trusting honest people who are trustworthy is a valuable commodity in this world... it's the invisible glue that holds the business world together. |
#11 | |
advocatus diaboli
Greed holds business together...greed and booze.
#12 |
play every day
There's nothing wrong with self interest where both parties financially benefit from freely choosing to enter into a business transaction.
Wealth is created. ![]() ![]() In contrast to self interest is greed where one person's gain can only come from another's loss. Wealth is transferred. ![]()
#13 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I like this project. I have one of these intakes laying around...if this works out in terms of gains mark me down for a flange.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
so when this is all said and done.. whoever gets the blueprint, will someone sell just the flange by itself or start buying up old corolla manifolds and doing all the welding themselves and sell it as a whole?
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
#15 |
play every day
That's still a wide open question because I've yet to find out if this will even work decently.
![]() Should have the first one completed and running in two weeks. I'm looking up the street and so far all the lights are green.
#16 |
Obsessed with 1.5L
I could do the service. There is alot of 1zz corollas in the yards around here and well i fabricate for a living. However welding that thin tubing to a 1" thick flange is going to be a trick...but ive pulled off some crazy stuff before!
#17 |
play every day
I wish that you really were in Malibu...
#18 | |
Love this project. I think it would be easier to take the general idea and make them from scratch in production runs. The flange will be the same on each one and positioned correctly, for example, as opposed to making each one as an individual project. Would bring the cost down as well.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
