Old 07-18-2012, 11:47 AM   #37
33OH
Drives: '08 Yaris
I'd say to go without the spacer unless you notice the wheel hits the caliper. As WeeYari said, on a 16" - it most likely will not hit.
If it does hit, most local tire shops carry 5mm wheel spacers and they can be had for $10-$20.
Old 07-18-2012, 12:33 PM   #38
Superstarjr
Drives: Toyota yaris 2006 D4d
Ye iv seen a load of them for under ten £. Looks like il be ordering them on the 20th ish :)
Cheers Josh
Superstarjr is offline   Reply With Quote
Old 10-12-2012, 05:28 AM   #39
bugslife71
Drives: Toyota Yaris 5-door Hatch
Send a message via Yahoo to bugslife71
Hey guys,
Need help. Planning on changing my rims to Rota RBs also. Will a 17sx7.5 4x100 with +45 offset fit my car? Planning on wrapping them also with 205/45/17 tires. Considering also that I have lowering springs installed.
Right now my car has this set-up: Rota Destiny rims that are 17s with an offset of +42 running on 205/40/17 tires. Having also the same lowering springs. With this set-up there is no rubbing whatsoever.
Thanks all.
https://www.facebook.com/photo.php?f...type=1&theater
bugslife71 is offline   Reply With Quote
Old 10-12-2012, 05:10 PM   #40
MUSKOKA800
MUSKOKA800's Avatar
Thanks Yarisgui, your legal expertise is unrivaled.
That is a crazy law. .
Have you seen Formula cars race in the rain?
The purpose of our fenders is to contain water spray. Tread extending out past the fender would generate huge rooster-tails of spray when driven during rain. Not to mention stones and other tread pick-up.
NOT a desirable situation for following drivers.
