Old 07-09-2012, 12:31 PM   #1
Superstarjr
Drives: Toyota yaris 2006 D4d
New member and need wheel advice
First of all this is a fantastic site with a huge amount of priceless information
I am thinking of changing the wheels on my yaris to something a little wider.
Im thinking of buying these wheels but in 16" not 15"
http://www.ebay.co.uk/itm/XXR-513-15...item3a713f6a5b
My question is would these wheel bolt on with no rubbing??
My yaris is standard apart from a cheeky remap ;)
Any help would help me so so soooo much !!
Superstarjr is offline   Reply With Quote
Old 07-09-2012, 12:39 PM   #2
With an offset of 0, not a hope in hell of no rubbing. Anything with an offset less than 38 gets into rubbing territory depending on tire width.
This is what 0 offset looks like.
Old 07-09-2012, 12:58 PM   #3
Superstarjr
Thank you for the mega fast reply
i see the problem now aha
guess i should keep looking ;)
Old 07-09-2012, 01:25 PM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
More pics of 15x8.25 + 0
Never was able to lower the car down so its in the air but you can see how badly it sticks outside the fender.
Old 07-09-2012, 01:55 PM   #5
Superstarjr
Yeah :)
Its a real shame really cause i really liked the style of those wheels :/
I can think of a way to fit them legally with no rubbing ??
Old 07-09-2012, 01:57 PM   #6
vten
You should be ok with the +25 offsets and 195 width tires .
I have the xxr 527 17x8.25 +25 with tanabe coilover and it doesn't rub ..... It will look a lot better with a negative camber up front if you install the camber bolt .
My camber is -2.8 up front now and I'm very satisfied with the look and handling .
http://www.yarisworld.com/forums/showthread.php?t=40482
^ that's my wheel thread ...
Old 07-09-2012, 04:33 PM   #7
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
you could talk to Garm about getting fender flares and rock the Yaris as a wide body, but there will need to be some wheel measurements to determine if it can be done and still function and look reasonable.
Old 07-09-2012, 04:35 PM   #8
1.5
Form>Function
1.5's Avatar
are stanced out cars illegal in your area
Old 07-09-2012, 05:08 PM   #9
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I think the law there prohibits the tire tread from sticking out of the fender. (Looking straight down from the top of the fender to the ground). The loophole is that nothing is mentioned about the wheel. So stretching tires (tyres) on wide wheels makes it legal - technically. The tire tread still sits within the fender. Might not be true but that's my story and I'm sticking to it.
OP, you can run 16x7 +15 offset
Old 07-09-2012, 05:35 PM   #10
Superstarjr
Where i live (UK) no part of the tire is aloud to stick out from the wheel arch ( fender ) but most police are fairly resonable round my area and seem to allow the tire to stick out but not the tread. same for the mot centers. so not to bad really. I like the idea of really wide tires for the yaris but it needs it to stay as legal as possible ;)
Old 07-09-2012, 05:44 PM   #11
Superstarjr
But saying that my 80 series landcruiser tire tread sticks out a bit
Old 07-09-2012, 05:48 PM   #12
1.5
Form>Function
1.5's Avatar
Thanks Yarisgui, your legal expertise is unrivaled.
That is a crazy law. I wonder if it is because of the small streets in europe they want to make sure all cars stay within a lane. I don't know why else there would be a need for that.
Old 07-09-2012, 05:54 PM   #13
Superstarjr
Yeah our roads are only small i guess
seems weird to me though beause my landcuiser has tread on the sides of the tires which comes out of the fender a few mm yet the police say nothing and it passes its mots no problem ?? surely thats much more dangerous ??
Old 07-09-2012, 07:05 PM   #14
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
wouldn't surprise me if SUV rules were different, in the US especially once a vehicle has a gvwr of over 6000 i think it is pretty much exempt from a ton of rules. Wouldn't surprise me if the rest of the world followed similar ideas.
Colin Chapman disciple
Old 07-09-2012, 08:19 PM   #15
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hi star,
I LOVE that style also. they look like Minilite wheels an old 1960's Mini Cooper.
Over the years, Panasport also made this distinctive style as well as Enkei.
I got exactly the same style, except not as deep dished. They're 15X7...
The offset is +35 but I had to install 5mm spacers to clear the disk brake calipers.
With 195/60 tires, they don't stick out, and don't rub... and the wheels retain their stock diameter so that the odometer and speedometer remain accurate.
Old 07-10-2012, 03:53 AM   #16
Superstarjr
Thank you tooter
That's helped so much !! Your car looks stunning by the way. That center exit exhaust look amazing also :)
I'm defornantly going to be on the search for those wheels in the UK
Old 07-10-2012, 10:58 AM   #17
tooter
play every day
tooter's Avatar
They're Rota RB's, and are manufactured in the Phillipines.
http://www.rotawheels.com/
Old 07-10-2012, 11:08 AM   #18
Superstarjr
Do you think if i was to go with a rota rb 16x8 it would rub ??
cause i want to run a 205x45 or 50 toyo proxes ??
