Old 09-12-2013, 12:23 PM   #37
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
So I been reading this and thought I would go look at mine. And sure enough it is.
So I got the idea to lift the rear of the car up off the ground. Then I took a rubber mallot and hit as hard as I could the rim that poked out further. Making sure I hit the center of the rim with as much force as possible. Golf swing style. I lowered and measured it again. I hit it too hard. now the other side pokes out too far. Lifted it back up and slightly tapped it.. and it fixed it.. ;)
So the bushings are sliding in the pockets on the beam?
Old 09-12-2013, 01:20 PM   #38
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
My left side never rubbed with the 10mm spacer in.
Duh, I read that too early I guess...why would it start.
For me I would be adding a spacer to the driver side probably making it rub like the passenger side. I guess I could even it out and add a lil camber. It's like I HAVE to add camber now if I want to fix it...Toyota made me do it.
-Type 07 FFL-
My odometer 03/11
Old 09-12-2013, 01:25 PM   #39
mazilla
advocatus diaboli
mazilla's Avatar
I tried this too, except instead of lifting the car(my hands fatigue easily) I just donkey kicked the passenger rear panel and shifted the body. I had my neighbor put his foot in front of the opposite wheel/tire so only the body would move.
-Type 07 FFL-
My odometer 03/11
Old 09-12-2013, 03:49 PM   #40
If you did move it over it would only be temporary as you would simply be deforming the bushing. As soon as the car starts moving it will find its way back. This is what the pocket in the body looks like. There is no way you are going to deform it by whacking on the hub. With the two pockets being off center as they are, you would have to do some serious cutting and rewelding to center them.
Old 09-13-2013, 01:00 PM   #41
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
ive been running -6 degrees in the rear for close to a year now and i barely notice any unusual wear. The 5-6 months i have had the same tires on the rear and you cant even notice a difference in wear from inside of tire to outside maybe my toe is spot on!
But how many miles did you drive in that time?
D&D is offline   Reply With Quote
Old 09-13-2013, 01:26 PM   #42
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
about 6k ^^^
Old 09-13-2013, 07:21 PM   #43
I run -1.5 in the front and have experienced no abnormal tire wear. I use extremely soft sticky tires too (Toyo R888)
Old 09-14-2013, 12:43 AM   #44
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
no.. this actually did not work. surprise.. CT is right, even if this did work, the amount of autocross I do, it would shimmy back and forth all the time.
-Derrick-
Old 09-14-2013, 10:45 AM   #45
Flipper_1938
When people are pushing the beam around to center things up....what is actually moving?
Old 09-14-2013, 01:16 PM   #46
They are deforming the rubber bushings that the beam bolts go through. They have about 1/2" of material around the bolt and are soft, so you can deform them. When you do so you are actually cocking the beam, rather than sliding to one side, so if it stayed like that the car would go dog style down the road.
Old 05-10-2014, 10:18 AM   #47
DINOeggxo
DINOeggxo's Avatar
Drives: white yaris hatchback.
bumping this back up:
Has anyone ever attempted to modify the rear beam to pull the wheels in more? like cutting re-welding? trying to think of a way to get perfect fitment. or is there a beam from earlier yaris or other model that is narrower and would bolt in?
DINOeggxo is offline   Reply With Quote
Old 05-10-2014, 10:24 AM   #48
I don't believe so on either.
Cutting and re-welding would actually be a reasonable approach, although the simpler solution is to use hub spacers. Using a mismatched set of one 10 mm and one 13 mm Penguin Garage spacer brings them almost perfectly equal. To make them dead on you could purchase a set of 10's or 13's and grind one down to where both sides are identical.
Old 05-10-2014, 10:37 AM   #49
sasquatch
Drives: 04.:R32, 87 Scirocco, 07 yaris
Yea we have considered spacers. But we are looking to maybe bring the wheels in more than just even them out. They already poke out some on each side and hoping to look for options to bring them in rather than just crazy camber..
sasquatch is offline   Reply With Quote
Old 05-10-2014, 10:48 AM   #50
OK. In that case the cut/weld is the way to go. You have about 1/2" to play with before you have to remount the shock mount.
Old 05-10-2014, 02:28 PM   #51
sasquatch
That's what I was gonna ask about haha. So 1/2 inch total or 1/2 inch on each side can be removed. if that makes sense.
Old 05-10-2014, 02:46 PM   #52
!/2" per side. You could get almost 1.5" per side if you cut right up to the shock mount.
Old 05-10-2014, 05:36 PM   #53
sasquatch
I am now intrigued. Will have to look into this more
Old 05-10-2014, 06:01 PM   #54
kimona
kimona's Avatar
Drives: 2014 White VITZ
Same problem up front as discussed a long time ago in another thread somewhere.
Yaris Sport 2009 wheels question andr3w Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-05-2013 07:28 PM
hid hi/low. question on using high beam for DRL! marcus Cosmetic Modifications (Exterior/Interior) 22 06-17-2010 03:12 PM
