#19 |
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
I am too. We had 12" of snow last weekend and the mayor called off any non-essential travel Monday...I also stayed home from work Tuesday. Wednesday I went back and my Yaris kept up with any other car....no one could do well driving over the chunks of ice left on the road.
#20 |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2012
Winnipeg (Winterpeg) has now dropped to third place for coldest cities in the world with populations over 600,000. Ulan Bator in Mongolia is first, Harbin in China is second and then Winnipeg. Coldest temperature ever recorded in Winnipeg was on February 1st, 1996 at -41.8C with a windchill of -57.1C.
Too cold for me. Roy PS The bear "Whinny the Poo" is named after Winnipeg. |
#21 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
. Such is Winter 280 miles from the Arctic Circle.
#22 | |
![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
#23 | |
#24 |
#25 |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
Not to sound like an ass, but you are saying that saving $350 is better than spending the $350 to have the peace of mind and quite possibly if even once avoiding an accident? That you would not be able to save a totaled car and possibly serious injury or even death to one in the party involved? Yeah, spending the cash could suck, but even if you are a "great" driver in snow it isn't anywhere close to always you that needs your concern...it is also the other drivers out there. Personally, I would pick up a spare set of steelies and mount a set of M+S tires on them. Change them on/off myself rather than paying a shop. Even if you live in an apartment, a stack of tires in a closet or storage space doesn't take up too much room. Being in VA the OP is in a PITA situation as the need for M+S tires is minimal, but if you pay close attention to the weather it is manageable. I lived in the DC area for a few years and had a set of M+S tires. Hell you could even possibly just pick up a set of used ones since you wouldn't barely put mileage on them. They would probably dry rot before you burned down the the wear bars.
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#26 |
This is a very good perspective when you are dealing with severe cold as you are showing. Not to hijack the thread, but one of the biggest mistakes of owners in areas that experience sub zero temps every winter is people not paying attention to the pour point of the motor oil they use. If you don't have a good pour point (example Amsoil is good to -50F) then you risk damage to your motor.
#27 |
You need to remember that there is more than the oil affecting whether or not the engine will start, I am discussing possible damage to internal components due to the oil not having a proper ability to move out of the oilpan through the motor.
Amsoil: Pour Point °C (°F) -51 (-60) Mobil1: Pour Point °C (°F) -48 (-54) Havoline Full Synth: Pour Point °C (°F) -35 (-31) Valvoline Conventional: Pour Point °C (°F) -36 (-32) Penzoil Conventional: Pour Point °C (°F) -39 (-38) Get the picture? When I was in my late teens and didn't care at all what went into my engine and bought the cheapest stuff I could find because I was a starving post high school guy I would wonder why the engine in my cars would have shavings in the pan after the winter. Well, looking at it now I realize that just because the motor would start at -40 it didn't mean "I was all good". That's all I am saying to that. /end hijack
#28 | |
#29 | |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
peace of mind should come from driving accordingly based on the conditions. snow tires wont save a bad driver from anything. in the Midwest id easily estimate 90% of drivers drive on all weather tires (which have improved greatly over the years) and drive pretty well. the bad drivers are bad and snow tires may or may not help them. if anyone wants to spend $350 dollars to drive in snow a handful of times because it makes them feel better, they are free to do so. |
#30 |
#31 |
And here in "Great White North" where I live it is +4C, cloudy and no snow. Just the thought or -44C make me cold.
Roy |
#32 |
![]() ![]() Drives: 2002 Toyota Yaris T-sport Join Date: Jan 2014
In snow.
Clutch. Drive on the clutch. Do not add any power when driving off, just let the clutch gently bite and take you away. After that gently feed a little bit of power. Shift smoothly, and DO revmatch. Otherwise you'll shiftlock much easyer. Not as big a problem but still a situation. Also use the clutch when going into a corner. The front wheels not having to transmit the power to the road makes them much more willing to follow the steering wheel. Also brakes. Ease off a little when you feel the ABS Kick in. And it will kick in early on snow. You want to be at the point just before the abs kicks in, that's the most performance you will get out of your abs-equipped brakes ever. Unless you have real expensive abs. (race abs costs a yaris and then some in some cases). On snow though: Easy on that pedal, when you feel it kick in, back off a little. Because: ABS unleashes/disengages the brakes. In an auto, just gently let go of the brake and don't start feeding power immediately. You'll just spin the wheels a lot getting snow and ugly stuff caked in the wheel wells. And last but not least: LOOK WHERE YOU WANT TO GO, NOT WHERE YOU DO NOT WANT TO GO. Yes, I've seen OP's post is 5 months old now, but a lot of drivers would do well to remember this. If you've got space turning + e-brake + clutch entry is about one of the most aggressive slip angles I ever did get with my 40 bhp Panda.
2002 Toyota Yaris T-sport ![]() 198X BMW E30 modified race car ![]() 1975 Ibanez "Les Paul custom" |
| what snow tires good for Yaris Hatchback. | opor24 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 12-28-2009 12:53 AM |
| Studed vs Studless Snow Tires | RacerFreakXXX | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 11-05-2009 10:42 PM |
| Snow getting stuck in frame/tires | 3DoorYaris | Yaris TS Talk | 9 | 08-17-2009 01:30 PM |
| Tall thin Snow tires for 14" rims | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 07-25-2009 08:40 AM |
| Yaris in the snow???? | drdavidr4u | General Yaris / Vitz Discussion | 2 | 07-08-2006 12:30 PM |
