Old 12-08-2013, 01:25 PM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
The First Snow Drive
Today drove my Yaris for the first time in the snow. Note that I’m a crappy driver and almost ate a corner . So I keep wondering if anyone had similar experiences?
I've seen other threads speaking about two solutions.
1) Winter tires.
2) E-Break.
vaironl is offline   Reply With Quote
Old 12-08-2013, 02:22 PM   #2
^ fix that first
Old 12-08-2013, 02:23 PM   #3
It is all about the tires. Proper snow tires make a world of difference.
The ebrake is only for fun in the snow (in wide open areas).
Old 12-08-2013, 08:00 PM   #4
roxy1
Drives: 2014 yaris 5 speed
1) Winter tires.
2) E-Break.
im probably of no help. ive been driving through 30 Michigan winters with front wheel drive cars and all weather tires. once in a while I think about winter tires. while they would be better for driving in the snow, I end up driving on pavement 90% of the time due to all the plowing and/or salt.
a few winters ago we had 124 inches of snow (we usually average around 80 in) and I still felt no need for snow tires.
since you live in Virginia, id definitely say save your $350 and just slow down a bit when needed.
roxy1 is offline   Reply With Quote
Old 12-08-2013, 08:20 PM   #5
vaironl
vaironl's Avatar
Adding to this, someone just gave me some advice to downshift without rev matching.
Old 01-05-2014, 09:35 PM   #6
bairjo
I run Michelin X-Ice snows on all 4 tires....very good traction. However, they will "sing" a little on the freeway.
Old 01-06-2014, 01:07 PM   #7
nookandcrannycar
^ fix that first
Old 01-06-2014, 08:45 PM   #8
JustPassinThru
Drives: No more Yaris
Only problem I've had with the Yaris in snow is that clearance is limited under the car - drifts or snowplow piles (as on the edge of the road to your driveway) will high-side it, sooner than other cars.
I speak of the Gen2. I haven't had my 2012 in snow yet - that's what I bought my beater Tercel for.
JustPassinThru is offline   Reply With Quote
Old 01-06-2014, 10:37 PM   #9
bairjo
All vehicles have their limitations. Do not drive a Yaris expecting high results in deep snow....Toyota has other vehicles that do well in those conditions. But if you find yourself in a situation with ice and snow, really bad ice and snow,...drive slow, brake easy, and get the hell off the freeway if you don't have proper snow tires for a Yaris. I already made a post with my choice of snow tires for the Yaris...the next step if they do not perform is to punt and get off the road. The Yaris is not a tank so you are best to get off the road if it is that bad...Good Luck.
Old 01-06-2014, 10:42 PM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Snow tires a must for traction and mainly stopping once u try snows ull never go back whats 400 bucks ...I think once life is worth more..... my only complain with car its light can get funky in snow drifts best advice slow down.
PS I use winterforce awesome tire for deep snow , if u drive hwy mainly get blizacks more of an ice tire
Old 01-07-2014, 05:21 AM   #11
peewee1
PEEWEE1
peewee1's Avatar
Drives: 2009 yaris s sedan
I live in upstate New York, land of snow and icey roads. Best thing to do, run very good tires and drive slow. My Yaris sedan is so light in weight that it sometimes will "FLOAT" on the heavy snows. GO easy on the gas pedal and brake early at stop signs.
peewee1 is offline   Reply With Quote
Old 01-07-2014, 12:20 PM   #12
Frank Necrosis
Drives: 2012 Yaris L MT
This is my second winter in the Yaris. Things I have noticed.... The abs / stability control / traction control systems are slow to respond, very slow. The car is usually well into a skid or slide before the computer decides to do something. Even then, the response is lackluster at best. But, then I am comparing the Yaris to my 2012 STi. The STi's systems are a little higher on the food chain than the Yaris.
Years of driving light, front wheel drive cars helps in knowing what to do. Having a manual transmission helps keep things under control as well.
Overall, I am happy with the Yaris in the snow. It is not much different than any other small fwd car. A few years back, I had a Mini Cooper. The wider tires and low ground clearance made it real interesting in the snow. Luckily, it didnt have any electronic driver aids other than ABS. The emergency brake was my good friend. Light pressure on the e brake could help reduce under steer. A technique I continue to use in the Yaris.
Frank Necrosis is offline   Reply With Quote
Old 01-07-2014, 12:42 PM   #13
nookandcrannycar
I feel for all of you. It was 22 without the wind chill at IAH (Bush Airport) this morning and 16 without the wind chill in some suburbs here....but that is nothing compared to up north....close to 30 below without the wind chill the last two nights in northern Minnesota....colder in Chicago than the 11 degree Summer temp at the South Pole...etc. (all temps Farenheit)
IIRC from 2006, isn't Winnipeg the coldest city in the world with a population of over 500,000? (Even colder than Helsinki or Moscow)
Old 01-07-2014, 12:53 PM   #14
nookandcrannycar
From a post on another site.....34 below F (55 below F with the wind chill) in Saskatoon yesterday......brrrrrrrrr.
Old 01-08-2014, 07:32 AM   #15
Berkut
Berkut's Avatar
Drives: Toyota Vitz '05
I live in Yakutsk is north-east Russia, and today -42C. So here from November to March.)))
Berkut is offline   Reply With Quote
Old 01-08-2014, 10:52 AM   #16
Frank Necrosis
The temp dropped to -10F (-23C) the other night. Luckily the low temps did not last long.
I am still happy I installed a block heater. It is hooked to a timer. A few hours before leaving for work, the timer kicks the heater on. After starting the car, warm air begins blowing in about 30 seconds.
Old 01-08-2014, 07:24 PM   #17
Lippitt
Drives: honda accord
Ask the Canadians, I hear they have lots of them in there. hah
Lippitt is offline   Reply With Quote
Old 01-08-2014, 07:30 PM   #18
vaironl
vaironl's Avatar
I just waited till most of the ice was gone and followed the advice of going slow. Even with my all seasons I was able to handle ok by just going slow :).
what snow tires good for Yaris Hatchback. opor24 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-28-2009 12:53 AM
Studed vs Studless Snow Tires RacerFreakXXX Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 11-05-2009 10:42 PM
Snow getting stuck in frame/tires 3DoorYaris Yaris TS Talk 9 08-17-2009 01:30 PM
Tall thin Snow tires for 14" rims regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 07-25-2009 08:40 AM
Yaris in the snow???? drdavidr4u General Yaris / Vitz Discussion 2 07-08-2006 12:30 PM
