Old 09-10-2016, 01:47 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
The new shim was the perfect size, we are now at 10.0 inch pounds witch is right in the middle of the specified range (6.9 - 13.8). Now let's assemble the transmission.
Old 09-10-2016, 01:49 PM   #2
ArmstrongRacing
Data doesn't lie
Here we have both shafts and all of the case components installed, time to seal it up.
Old 09-17-2016, 02:40 PM   #3
ArmstrongRacing
Data doesn't lie
The main case is sealed, and 5th gear assembly installed
Old 09-17-2016, 02:45 PM   #4
ArmstrongRacing
Data doesn't lie
Slide the shifter assy in just to verity you can shift to all 6 gears, if so you can seal the end case
Old 09-17-2016, 02:52 PM   #5
ArmstrongRacing
Data doesn't lie
Now you can install the shifter assy and all brackets/switches. Now you're ready to install the transmission
Old 07-09-2020, 05:13 AM   #6
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
Thanks @ArmstrongRacing for taking the time to put this together! You rock man!
I know this is an old thread and all, but does anyone know if you'll lose your current odometer reading when swapping ECM? Can't seem to find a definitive answer in my searches.
Kasbien is offline   Reply With Quote
Old 07-09-2020, 07:34 AM   #7
No, the odometer reading is built into the dash.
Old 07-10-2020, 07:28 AM   #8
Kasbien
Kasbien's Avatar
Music to my ears. Thanks!
Effects of too much trans fluid in the case? (auto trans) detroiter General Yaris / Vitz Discussion 5 02-24-2009 11:08 PM
Manual To Auto bronsin General Yaris / Vitz Discussion 10 12-22-2008 10:32 PM
What RPM's are you americans getting on Auto trans? BMGYaris General Yaris / Vitz Discussion 12 11-02-2006 02:43 AM
Manual vs. Auto littlecarlove General Yaris / Vitz Discussion 25 10-25-2006 08:45 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
