Old 11-29-2016, 07:19 AM   #1
Pinchlite
Drives: 2007 yaris HB
cut
I seen a post where they were cut down.
How much do I leave attached?
I will be doing the springswap my self aswell as adding swaybar.
I did replace struts on a civic almost 20 years ago so i know I can do it.
Pinchlite is offline   Reply With Quote
Old 11-29-2016, 09:48 AM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Simple logic ur car will sit 1.5 inch lower so why would u use stock hight bump stops cut 1 inch off at least or every other bump u will hit them and restrict ur suspension travel...also good luck with swaybar links they are fun to remove, use heat if possible also remove wipers and all in that are 10 min job to get to the top shock mounts.
Sent from my HTC One A9 using Tapatalk
Old 11-29-2016, 11:59 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Some people are on coil overs and go way lower than the 2" you get with the Tein springs. On 16's with 40 mm offset, it's going to look excellent. 1.5 would look good too, but I think the Tein drop is perfect.
On Instagram
On Wheelwell
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
