Old 07-07-2007, 08:52 AM   #37
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
freaking nice DIY by the way
it's legal in canada to have white running light on mirror some FJ cruser have some little round white light on the mirror!
the_boss is offline   Reply With Quote
Old 07-07-2007, 12:19 PM   #38
toyota-belta
Drives: toyota belta s importer
Originally Posted by the_boss View Post
dit moi ses quoi tu veut luis demander et je vais luis traduire!
(tell me what you want to say and Ill translate it!)
bonjour je voudrais savoir ou me brancher pour que mes cover marche avec mes flocher merci
toute mes file sont passer de la porte il me reste a me connecter
merci beaucoup
toyota-belta is offline   Reply With Quote
Old 07-07-2007, 12:53 PM   #39
the_boss
the_boss's Avatar
merci beaucoup
Hey Violin, this guy would like to know where to take the power to have his signal light flashing with his reg, flasher. Everything is ready but he need to know where to tap to get the juice!
Hope you understand what I mean !!
thanks
Old 07-07-2007, 03:47 PM   #40
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
There is a bundle of 4 wires running up from inside the fender to up under each headlight. Those are the ones I have pictured. You have to remove the headlights to get at them. Tap the wires I showed for power - the red wire from the mirror is the power wire for the amber LED and the black is the ground. The ground can go to just about any bolt inside the cabin.
Thanks for translating.
Old 07-07-2007, 07:15 PM   #41
the_boss
the_boss's Avatar
Ok here we go!
Ya une couette de 4 fils qui passe dans chaque coter de fender (aile) jusqua la lumiere avant. ses ceux qu'il a photographier. Faut enlever l'assemblage de la lumiere pour y acceder. tap le fil qui apporte le courant au blinker avec le fil rouge du miroire (courant pour les led jaune) et le noir ses le ground ou mise a la terre, tu peut grounder sur n'importe quel boulons pis sa va faire!
NOTE DE MOI MEME: prend le fil conducteur des blinker avant pis plug les avec le rouges des led jaune du mirroires. dans sa photo y montre quel fil tu doit connecter!. Jespere que sa va aider!
Old 07-07-2007, 08:17 PM   #42
love the global community around here!!!
I am definitely doing this mod. Anyone know where I can get CF LED mirrors?
Old 07-07-2007, 08:28 PM   #43
one more thing. If you don't mind my asking, why not just wire to the side marker, which is only about a foot away from the mirror?
Old 07-08-2007, 08:08 AM   #44
Violin
Violin's Avatar
You could do that, I even had mine popped out for that purpose but decided it was neater where I tapped it.
Old 07-20-2007, 08:36 PM   #45
reggaetonfreak
El Yoe
reggaetonfreak's Avatar
Drives: Yaris Hatchback
im gonna get rid of my side markers with this mod, lol, is way better
Cuban to the bone, sitting in a Yaris, ahi si hay!!...
reggaetonfreak is offline   Reply With Quote
Old 07-20-2007, 09:30 PM   #46
Violin
Violin's Avatar
You'll patch and paint the holes in the fender?
Old 07-21-2007, 10:46 AM   #47
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Because he's anal.
Old 07-31-2007, 05:19 AM   #48
looks good man, is the "white" light really that blue in person or is your camera playing tricks?
Old 07-31-2007, 05:49 AM   #49
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Great install! Looks awesome bigsky2!
Did you add a switch in order to change between LEDs easily? If so, could you please let me know which model you used? Thanks!
Old 07-31-2007, 06:13 AM   #50
hahah yeah, now if only I could actually finish wiring them up myself someday
Old 07-31-2007, 06:18 AM   #51
oh I am the anti-anal (oral?), I'm Mr. Ghetto wiring... I don't even think I can find vampire tap thingies here, gonna trust my good old swiss army knife to cut insulation, and wrap it up in good ol electrical tape
Old 07-31-2007, 06:55 AM   #52
Violin
Violin's Avatar
That white light does look good. Maybe I'll hook them up one day.
Old 08-02-2007, 11:17 AM   #53
jimcat
Green is good
jimcat's Avatar
Drives: Vitz RS
Send a message via MSN to jimcat
I still not install this things as I found it is not fit for yaris
Also it is flashing in blue color
damm.... not worth to spent money to spray it
jimcat is offline   Reply With Quote
Old 08-02-2007, 05:24 PM   #54
redyaris
redyaris's Avatar
Those are the crap thats still going on ebay....and they still dont fit unless you use duct tape.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
