Old 05-01-2010, 07:37 PM   #1
joeljcruz86
Little Eggy
joeljcruz86's Avatar
Drives: Toyota Yaris Liftback 3DR 2009
Send a message via AIM to joeljcruz86
Hey Goku87, I bought the same kit that you did. Only one problem, the Fog Light doesn't light up in my guage cluster. Everything works except the Fog lights will only work if the head lights are on. The way I have it hooked up basically i have the red wire from the fog light harness connected to the red wire from the switch harness. Then I have the green wire from the switch itself tapped into the factory wire harness by the shifter like you did. Then I have the last remaining wire which is the blue/yellowish wire from the relay tapped into the cigarette lighter. Now the "pin connector" plug under my steering wheel is a little different. The Yellow wire is yellow, but the white wire in your picture, it is brown for mine. I don't have any wires tapped into those. So can you or anybody help me to get the Fog Light to light up in my guage cluster??
PS. I drive a 2009 Liftback 3DR
Last edited by joeljcruz86; 05-01-2010 at 07:38 PM. Reason: forgot to put something
joeljcruz86 is offline   Reply With Quote
Old 05-01-2010, 08:48 PM   #2
1NZYaris1
1NZYaris1's Avatar
you cant tap into the cluster , if you are not running a relay in the
factory relay postion , or running the fog lights through the factory wiring that
is installed in all Yaris's .
Old 05-03-2010, 12:24 AM   #3
joeljcruz86
Little Eggy
oh, hmm =/. Well my friend helped me about having the green wire tapped into the factory pin leading to the fog light Light in the guage cluster and it works.. What's the bad thing about that? i mean everything works and i do have the "kit relay" still part of the whole thing. The only disadvantage he told me is that when i switch the high's on, it doesn't disable it and he said that won't pass inspection. =/
Old 06-01-2010, 11:46 AM   #4
Rikster
Rikster's Avatar
Drives: Toyota Yaris (2010)
I want to install the fog lights using the parts that come with the kit!(trough the firewall)
To which wires do i connect the ACC and the Battery power wires using the splice connectors that came with the kit?
Rikster is offline   Reply With Quote
Old 07-19-2010, 03:45 PM   #5
Toyo Chris
Drives: Yaris HB
Thanks a lot, I received my kit today. I hope to install them this week.
Toyo Chris is offline   Reply With Quote
Old 07-23-2010, 12:51 AM   #6
Toyo Chris
Drives: Yaris HB
How can I install the foglights without the factory way. I mean, how can I install them in a way I can turn them on without turning the Headlights on, just turning it on with the switch that comes with the kit and the relay, etc.
Old 07-23-2010, 01:46 AM   #7
Toyo Chris
Drives: Yaris HB
Is there any way of installing the kit without putting it to work with the stock wiring?
Old 08-04-2010, 03:54 PM   #8
Toyo Chris
Drives: Yaris HB
Ok, I finally installed them and put them to work!
Old 08-08-2010, 10:25 AM   #9
husaynkhan
Drives: new vitz
am unable to seee these picture fully, plz help. each pic is loading only at
half
husaynkhan is offline   Reply With Quote
Old 01-20-2011, 06:11 PM   #10
Yarisaur
Drives: 07 Yaris
Okay installed mine only one problem... the indicator light for the switch stays on even with the car off?? is this a problem/ will it kill my battery?
Yarisaur is offline   Reply With Quote
Old 01-20-2011, 08:33 PM   #11
To make the light stay off you have to modify the circuit within the switch. If the switch has LEDs for the lights then there won't be an issue with battery drain.
Old 01-21-2011, 01:22 PM   #12
Yarisaur
Drives: 07 Yaris
And how would i modify the circuit?
Old 01-21-2011, 02:28 PM   #13
Check out this post:
http://www.yarisworld.com/forums/sho...7&postcount=39
Old 02-15-2011, 01:17 PM   #14
facu1984
Drives: 2007
My fog lights work perfect, but the fog indicator light on the panel is not turning on...
any ideas?
facu1984 is offline   Reply With Quote
Old 02-17-2011, 11:45 AM   #15
Brianr4
Drives: 2008 Yaris 3dr Hatchback
I have mine working now, first switch went bad.
Still wondering though if I get a factory stalk with foglight option, how will the fogs operate? Only with the headlights on?
The way they work now I can turn them on anytime, with the car running or not.
Brianr4 is offline   Reply With Quote
Old 02-17-2011, 01:32 PM   #16
If you switch to an OEM stalk they will just work with the low beams on, unless you cut the wire going to pin 4 of the stalk and tie the stalk end of it to ground (which will allow you to turn the fogs on at any time).
Old 03-05-2011, 03:57 PM   #17
Tylermayer
Tylermayer's Avatar
Drives: 2007 Toyota Yaris
how much would it cost to have it done professionally!??
Tylermayer is offline   Reply With Quote
Old 03-06-2011, 07:36 PM   #18
auxmike
auxmike's Avatar
I've had my lights setup for almost 3 years and it's been real good to me thus far. I used the "Clowncar" method that works like a charm using my $14 OEM Toyota relay from Ebay.
I too could'nt get the lighted push button switch to work on my car, so I bought a simple black toggle switch from PepBoys
Also, the bulbs that come with these kits can be garbage, the gaskets on mine would'nt even allow the bulbs to fit snugly. I bought German OSRAM brand and the've lasted thus far without replacing them. Fit tight too!
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 09:45 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
