Old 08-14-2012, 11:48 PM   #1
Autocross72
Drives: 2009 3rd Polar white
Subscribe
Autocross72 is offline   Reply With Quote
Old 08-15-2012, 12:15 AM   #2
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Where's the beef
4/20 NEVER FORGET is offline   Reply With Quote
Old 08-15-2012, 12:26 AM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Still waiting on the 90 degree silicone coupling to arrive so that I can finish off the air filter. Sorry, no air filter... no dyno. I'm not going to wreck my engine.
I want to see the results just as much as any of you do.
Old 08-15-2012, 12:29 AM   #4
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
^ we're still waiting, bro. anxiously waiting!
Old 08-15-2012, 12:39 AM   #5
Autocross72
One or two pulls on a Dyno withouut an air filter isn't going to hurt your engine. That said, I'd be more interested in seeing the Dyno numbers with the filter because that is how it will be run in the real world and can be compared more directly to your previous Dyno pulls.
Old 08-15-2012, 01:17 AM   #6
tooter
play every day
tooter's Avatar
I agree.
The second set of dyno pulls need to be done under exactly the same conditions as the baseline pulls with the velocity stack and its matching air filter... except for the tooter manifold being the only change. I want to do this the right way.
Old 08-15-2012, 02:04 AM   #7
That's not going to happen unless ambient temperature and humidity are the same, along with other factors. Did you record ambient conditions and engine intake air temps when you did your baseline pulls?
I think everyone should consider that there is a notable margin for error, counted twice -- once for each dyno session.
Old 08-15-2012, 11:28 AM   #8
tooter
play every day
tooter's Avatar
Yes. They were automatically logged on the chart:
78.46 °F
29.19 in-Hg
Humidity: 45 %
Since it's been really hot and dry, I'll try to pick an early morning dyno time on a day when the Santa Ana winds aren't blowing.
Old 08-15-2012, 08:03 AM   #9
^ That's why I suggested he swap manifolds on the dyno, but he doesn't want to do that.
Old 08-15-2012, 10:43 AM   #10
It's tooter's show, I'm just enjoying the whole thing. And he's quite content if it doesn't make or lose great power. He's having great fun doing this -- that's all that matters.
I like clarity for all when I see words like "exactly the same"; that was the only purpose for my post. And... it makes the pool more interesting.
Old 08-15-2012, 11:35 AM   #11
tooter
play every day
tooter's Avatar
It's good you pointed that out, Garm.
By "exactly the same conditions", I meant engine conditions. That the only change between the first dyno runs and the second is the manifold and nothing else.
I'm already happy that the engine runs great, gets good mileage and that the manifold looks really cool. The change won't be much either way because the throttle body, ECU, and engine are all still exactly the same.
Old 08-15-2012, 12:15 PM   #12
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
you know...if you ordered your silicone coupler from us...you wouldnt be having this issue ;)
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-15-2012, 05:21 PM   #13
tooter
play every day
tooter's Avatar
I had ordered one from an ebay seller and was sent a 45 degree instead of a 90 so he's making it right.
Old 08-15-2012, 12:19 PM   #14
^ Or if he picked one up from my shop.
Old 08-15-2012, 06:57 PM   #15
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Or if he got one from ....oh wait, I don't sell anything.
-Type 07 FFL-
My odometer 03/11
Old 08-15-2012, 07:26 PM   #16
^ and on this forum, neither does malibuguy, and neither does tooter -- but the link to become a vendor is posted for anyone who wants to join the club.
Old 08-16-2012, 09:09 PM   #17
Cars with ITB's and velocity stacks dyno every day. Dyno shops don't have particulate matter floating around; if they did, I'd probably choose another shop.
Since that's not going to hurt your engine, it's not a valid reason to wait.
I don't care when you do it, just pointing out a bad argument when I see one.
Old 08-16-2012, 09:25 PM   #18
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I'll let you know this the Pikes Peak racers don't use air filters and that's back when they ran on dirt. I know this because I had a 900hp TRD 503e engine sitting 2 feet away from me for 2 years.
That was a cool motor ITB"s with a common plenum for the turbo's only bad thing was once the head was bolted on the block couldn't be reused.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
