#1 |
Just use the link, sign up and pay, you're in as far as I know.
^ You can make any parts you want. A flange for the head isn't proprietary, and neither is a TB adaptor. The manifold itself was designed by Toyota. I personaly wouldn't copy the parts because of (1) professional courtesy, (2) such a small market, and (3) it doesn't make power (that part is just an educated guess at this point).
An intake to go with what tooter made would be really cool and complementary.
#3 | ||||
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
The guys from Puerto Rico did it first. All I did was have the parts made to do what they did. Quote:
![]() You know, this would have been a serious problem if they were still making those manifolds, but since they're all at least decade-old junk yard parts and have long since been rendered obsolete by plastic manifolds, they've sort of fallen into the public domain. Quote:
![]() Hey, are you or Jeff going to be around the shop Saturday morning? ![]() If you have a black 2.5 inch silicone 90 degree connector, I'll drop by and buy one from you. The Post office is clueless as to what happened to the shipment. the tracking number shows acceptance of the parcel, but there is no electronic information after that. It's not the ebay sellers fault either. The guy has been both responsive and communicative. Quote:
#4 |
^ I might well be around tomorrow morning. Might be racing, though. Email me at mcroimg@gmail.com so we can communicate that way -- I don't access the forums from my phone.
#5 |
play every day
Check your messages.
#6 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I wouldnt copy a thing. Im not that kind of guy. As a matter of fact Garm, i got an email thebother day from a guy to copy your center section for the hatchies...i straight up told him "im not copiying garms exhaust"
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#7 |
heh, well thanks. Was it someone on here?
#8 |
Obsessed with 1.5L
Sorry i meant center exit.
I have no idea...it was an email at work not a pm.
#9 |
glad to help out -- FYI everyone, I'll be putting various hoses and couplings up on the site shortly.
#10 |
play every day
Man, you're a life saver!
![]() Here's the results... ![]() ![]() ![]() ![]() ![]() It's ready to DYNO!
#11 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
DYNO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#12 |
play every day
Just got back from test running the final air filter setup and the car runs great!
![]() I was concerned that the MAF signalling might be impaired from cutting and trimming everything on the intake so dang short, but no CEL was triggered so it's good. There is absolutely no wiggle room for that giant air filter, and I'm sure glad that those silicone couplings are flexible because it wouldn't be there if they weren't.
#13 |
play every day
Just called Harry at HK Motorsports Dyno Shop in Van Nuys...
...and we're all set for dyno runs this coming Thursday morning the 23rd. |
#14 |
Yay
#15 |
![]() Drives: Yaris TS 05 Join Date: Jun 2011
excellent!
#16 |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
Time Machine - fast forward till Thursday morning :D
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#17 |
play every day
We'll be there before you know it...
I picked Thursday because it will be the coolest day of the coming week with morning clouds and a high of 87. The peak temprature doesn't hit until about 2 to 3 in the afternoon. I'm the first run scheduled at 11:00 in the morning when it should still be slightly overcast with temps in the high 70's... ...which is similar to the conditions of the baseline dyno runs which were 78 degrees and 45% humidity.
#18 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
Dude, that looks gorgeous! Great work, this has been one of the most informative/entertaining threads on this board in a while!
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
