Old 07-15-2009, 04:49 PM   #55
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
I never paid attention to how many miles per bar. Some of you must have a lot of free time on your hands.
I was taught that the gas gage averages out the bounces from the fuel tank floot to come up with what to display. Since the gas float bobs up and down with every bump and twist in the road it is impossible to build a 100% accurate fuel gage. The idea that the Yaris gas tank may not be square is something interesting to think about.
The first reason I learned not to top off you tank is gasoline expands as it's gets warm, and you can lose gasoline. I had that happen after parking my Gremlin on a hill. The second reason not to top off is that most gas pumps now have a vapor capture system. The vapor capture system will suck the extra gas out. So you are just wasting money if you top off.
Back when I had a 86 Horizon it's vapor recovery system failed around 50,000 miles. Over filling the tank? Maybe. But the problem was covered by warrenty and a new after market vapor system was installed by the dealer free of charge.
ellenbetty is offline   Reply With Quote
Old 07-15-2009, 04:55 PM   #56
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The vapor recovery system is why Toyota warns us not to top off.
As a long time topper, I've had problems with expanding fuel overflowing as noted above, and leaks developing in filler hoses. Gas on the concrete floor of the garage fills the house with noxious fumes. My sister had her house burned when such fuel soaked into the garage floor was ignited by a hot pan of wood stove ashes her son set on it.
I no longer top up the tank. I run it in fast till it clicks off, wait a few seconds for the foam to settle, then start it back slowly till it clicks off once more. (Doesn't take more than 1/10 gallon or so extra.) Gives me a consistent enough point of reference for tracking mileage without risking overfilling problems.
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
c one motorsport performance bars badhabitz Performance Modifications 17 08-23-2006 10:31 PM
