Old 03-02-2011, 01:56 AM   #55
yaris2010RS
yaris2010RS's Avatar
4x6 should fit in the hole in the door but u will need a mount plate of some sort. i put a 6" in front and it still needed a mounting plate (used 1" think plywood)
Old 03-02-2011, 05:28 PM   #56
aareyn
aareyn's Avatar
Drives: yaris sedan
That's what I figured, thanks. As for the dash adapter, does it matter the years on these cars? I can't seem to find one that specifically says 2011.
aareyn is offline   Reply With Quote
Old 03-02-2011, 05:39 PM   #57
yaris2010RS
as far as i know interior hasnt changed. the 08 tim fit my 2010 so u should be okay there
Old 03-03-2011, 01:18 AM   #58
aareyn
aareyn's Avatar
Drives: yaris sedan
Cool, thanks, now I just have to find one
Old 02-06-2012, 08:17 PM   #59
bsg916
Drives: 2007 Toyota Yaris Hatchback
Just curious if anyone ran into this problem with replacing the front door speakers with the template pdf. I used a 3/4 in piece of wood which is like half the thickness of the factory bracket but now I cannot fit my door panel back on, it appears to be hitting something, but with such little space it is hard to tell what it is hitting the speaker or the template itself. Any idea would be helpful.
Brian
bsg916 is offline   Reply With Quote
Old 07-20-2012, 09:54 AM   #60
letitbekate
Drives: 2009 Yaris hatchback 4 door
What about speaker sizes for a 2009 Toyota yaris 5 door hatchback? I see this thread was started a number of years ago. Has the sizing changed at all? Thanks!
letitbekate is offline   Reply With Quote
Old 07-26-2012, 10:35 PM   #61
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
As far as I know, speaker sizes haven't changed since the '07 restyle. The bigger issue will be finding speakers that fit into either the stock shell or the Scosche SAT6. My Polk DXi650's will not fit in either, so I'm going to make some from sheet plastic or cheap cutting boards.
Old 08-31-2012, 06:48 AM   #62
Vittas
Siberian
Drives: Yaris Sedan S 2007
just finished replacing of stock speakers in front doors of sedan'07. "why Toyota use this type of speakers?" - was the main question of this work)))) Who knew the answer?
now i'm happy with Kicx alq6.2 )) wooden spacers helps me)))
Vittas is offline   Reply With Quote
Old 08-27-2013, 11:05 PM   #63
pardos
Drives: yaris
I think the one is great :DVD Radio Special for Toyota Yaris - Navigaiton Digital TV DVB-T
pardos is offline   Reply With Quote
Old 02-26-2014, 11:11 PM   #64
dschultz9
dschultz9's Avatar
Drives: '09 Yaris 5 door Hatchback
Ok so I figured out the difference. If I obtain one of these kits, realistically, how hard is it to replace? Will I need any other parts? How long will it take for an amateur?
An hour or two at most make sure you match up the wiring in accordance with the manual for the headunit. I would also highly reccomend soldering and head shrinking everything. Here is a great video to get you started.
http://www.youtube.com/watch?v=aIHr3qXCJxk
dschultz9 is offline   Reply With Quote
Old 03-29-2015, 02:47 PM   #65
MJZ
Drives: 2008 Yaris 3 Door Manual
So I purchased the Scosche TA02B car stereo adapter (which only has 2 connectors. Today when I took my factory radio out, it's got 3 plugs, not 2. What gives?
MJZ is offline   Reply With Quote
Old 03-31-2015, 03:00 PM   #66
ehud42
Drives: 2009 Yaris Sedan 5spd
Nice 6.5" template - am wondering if anyone has a template for the 6x9 / sedan adapter?
(Lots of sites sell adapters, but I got a small CNC & 3D printer - eventually I want to make my own adapter).
ehud42 is offline   Reply With Quote
Old 05-31-2015, 10:27 AM   #67
levy49
Drives: 2007 Toyota yaris
2007 Toyota yaris wiringnhelp!!!
OK i got a 2007 Toyota yaris and I want to change my factory deck, not sure if it will matter but my factory deck is silver instead of black like I had seen on YouTube, and when I was looking for a wiring harness there is ones with and without the factory amp to power the two back speakers, so what I'm asking is what wiring harness do I get, its the 4 door hatchback so any help is greatly appreciated
Thanks in advance
levy49 is offline   Reply With Quote
Old 05-31-2015, 10:56 AM   #68
You need this.
http://www.amazon.ca/Metra-70-1761-W.../dp/B0002BEQJ8
Old 05-31-2015, 06:42 PM   #69
levy49
Thanks illusionx but also another question, will i need an amp interface to keep the chimes? I never wired one of these and i never needed one, but the two other cars i wired a deck for was a 2003 subaru impreza and a 2003 saturn ion so i guess they didnt need them, and thanks for the quick reply
Again thanks in advance
P.s. the part number i was looking at is metra TYTO-01
Old 06-01-2015, 12:27 AM   #70
This part is designed for aftermarket radio install if you have a build in amp like the JBL or mark Levinson audio system in the Lexus.
Old 05-23-2017, 07:51 PM   #71
David C
Drives: White '07 3dr LB
Anyone installed a pair of Rockford P1650 speakers in their front doors of a 2nd gen 3dr HB ? RF website specs states 2.24" mounting depth, just want to make sure the door have enough depth to fit these speakers.
Thanks
David C is offline   Reply With Quote
Old 05-30-2017, 07:11 AM   #72
miiser
miiser's Avatar
Drives: yaris 2009
I really want help here:
I replaced my factory front speakers with a pair of jvc cs-j620x in my 2009 HB yaris. The music is a lot clearer now, but the bass is terrible. So what should I do now?
Buy an amp?
Change the HU?
Soundeadning the doors?
I am all stock right now. I don't want bass that will keep my neighbors awake. I just want some decent music depth. Please suggest
miiser is offline   Reply With Quote
aftermarket stereo kit? xCookiE General Yaris / Vitz Discussion 4 02-16-2006 10:33 PM
