#55 |
#56 |
![]() Drives: 1986 Toyota Corolla GT-S Join Date: Aug 2009
My dealership parts dept friends can't seem to get a handle on D79 8 pin connector as the part number is invalid. Also, when I looked up the 2007 Yaris on toyodiy.com part number diagrams, there isn't a price listed for the 4 pin connector. Perhaps theres just no other way for me to find this connector?
#57 |
Audio Junky
I wonder if mouser or one of the other giant electronics parts shops would have that they of connector....?
#58 | |
#59 |
#60 |
I think 2008 models are too new to be in the database at dealerships because only the 2007 4 pin connector is readily in search systems.
#61 |
so my friend bought a new corolla with his cash for clunkers rebate and his AUX assembly is 8 pin just like the 2008 yaris. I look very closely at the white connector while it was out and without any magnifying glass or a marker to make the numbers stand out, I managed to find out its a tyco electronic connector and i can only make out the numbers 12551 on it. But for sure I recognize the tyco font so I'll be researching this
#62 |
![]() Drives: 2007 yaris sedan Join Date: Mar 2010
thank guys for all the infos...especially Dave for photos ~~ i found my 4 pin connector at passenger side empty slot...it was bit hard to find this plug cause it was small and wrapped with tape with the wire bundle...anyway it was there exactly where Dave mentioned and bought the aux (stereo adapter assy.) around $33 canadian at local dealership. I have 2007 Yaris, Sedan.
#63 | |
http://www.tycoelectronics.com/catal...&RQPN=175964-1 It looks to be a match. I'll be ordering one and see if I can finally link my yaris deck to an aux stereo jack |
#64 |
Tyco 175964-1
Does vitriumgts or anyone else know what the female part number is that matches the Tyco 175964-1?
I'm not even sure if one exists but I would prefer to have that add some wire to the correct pin locations and then splice on my RCA connectors or run the wires into my after market Pioneer stereo harness. The reason I would like to do this is because I'm looking at possibly adding an extra AUX input for people in the back and I would also like to not hack up the existing AUX input to make it work with my new stereo. That way if I sell my car I can remove my stereo and none of the factory wiring would be touched. Thanks for the help. |
#65 |
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback Join Date: Jan 2010
funny you mention that..... i used to work for mouser so if anyone needs a large part order at cost i might still be able to help. they have connectors but the housing isnt gonna work....
#66 |
I'm having a very tough time ordering a single unit of this connector, and I'm working hard to even get a single sample. Its all Bulk orders or nothing. Can anyone provide any help?
#67 | |
No, that connector is not for the AUX jack, and that particular head unit does not support a direct plug in AUX jack. |
#68 | |
Possibly something like this: http://cgi.ebay.co.uk/CTVTYX002-TOYO...item255b652ec5 |
#69 |
![]() Drives: yaris/pc3 Join Date: Apr 2014
Calling CTSCOTT for help!
i have a 2007 LB 5 speed and it came with a factory 4 pin aux connector i check the connection on the HU and the cables that to the aux port connection is sold, cables all work using a ohm meter.. nothing is working.... you keep stating that LB has a 8 pin set up and sedans have the 4 pin?? please help |
#70 | |
Check out the post below, as I suspect the switching mechanism within your port may be damaged: http://www.yarisworld.com/forums/sho...62&postcount=4
#71 |
the aux port looks to be in good
pin 3 and 4 is getting 2.6 ohm when a cable is plugged in radio is model 11807 |
#72 | |
I believe that jack is a Scion one, as the Yaris one has small text that is perpendicular, rather than parallel to the flap.
| DIY: Aux Input Jack Adapter | TinyGiant | DIY / Maintenance / Service | 11 | 11-10-2012 05:33 AM |
| Viper Alarm Install | gwasabi | In Car Entertainment + Electronics (audio / video / alarm) | 28 | 08-11-2010 02:57 PM |
| Hear noise when playing music with TomTom 910 through auxiliary audio input jack | waylandchin | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 04-22-2007 12:25 AM |
| High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 12:49 PM |
| aux input... | djfuji | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 01-23-2007 09:25 PM |
