Old 08-27-2009, 11:20 PM   #55
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
does anyone have a 08 yaris lb automatic trans ecu with 35000 miles or less on the car when it was pulled im looking for one to buy ?
pennyracer is offline   Reply With Quote
Old 08-28-2009, 10:58 AM   #56
jdms
jdms's Avatar
Drives: 08 Polar white lb
As a side note, a while back nickhjort sent me some pics from when we were trying to figure out if we could get the 07-08 clusters to drive cruise control lights.
Looking back though the pics recently I realized that the cluster has a "core" module with the microcontroller on it, which is plugged into a "carrier" board (i.e. the big circuit board with the lights and speedo). The mileage on the cluster end is stored in flash memory within this microcontroller. If the cold boot via battery disconnect doesn't work, It may be possible to move the core over from the old to new cluster. The question is if the microcontroller is programmed generically and it drives whatever is available on the carrier it is plugged into, or if it is programmed specifically for the carrier.
Attachment 27136
Has anyone tried this yet? I just read through it all and didn't see anyone saying this didn't work.
jdms is offline   Reply With Quote
Old 08-28-2009, 11:13 AM   #57
goku87
goku87's Avatar
Drives: Black HB
ive been scouring junk yards here, back home, and on the internet-a-plenty.
i'm almost tempted to say screw it and get the one from the stealership.
its only $460.00ish....
only.......
Old 08-28-2009, 11:41 PM   #58
Someone from Puerto Rico did, and it did not work for him - The new cluster had a blank display for mileage with the old cluster's core. It may be that you can only swap out ones from the same vintage, or it may be that it just doesn't work.
Old 08-29-2009, 06:33 AM   #59
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
It's also possible they didn't install it correctly, or one of the 50 or so pins were bent, etc. that's a pretty fragile piece. I think that idea makes a lot of sense though.
Old 11-23-2009, 11:32 PM   #60
DamianShadowPaw
Drives: 2008 Yaris 4 door
I just want a clear answer... will a cluster with a Tach work in a Yaris that did not come with a Tach >.> millage doesn't really concern me.
DamianShadowPaw is offline   Reply With Quote
Old 11-23-2009, 11:45 PM   #61
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
yes it will, at a meet last week, we had a 09 S automatic cluster swapped into a pre 09 no tach (manual), worked, we dont know about ODO tho.
Check out my Build thread:
Old 11-30-2009, 03:15 AM   #62
goku87
goku87's Avatar
Drives: Black HB
looking back on this i guess i'm glad i never got the new cluster lol.
Old 08-18-2010, 11:37 AM   #63
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Smile confused
I just bought a cluster from ebay and waiting for arrival. For me, I am after with the tach.
Is the odometer reading stays with the ecm or it follows the cluster ecu?
ricepower is offline   Reply With Quote
Old 08-18-2010, 11:38 AM   #64
It stays with the cluster ECU. The ECM doesn't store odo data.
Old 08-18-2010, 11:42 AM   #65
ricepower
ricepower's Avatar
Thumbs up
Thanks CTScott:
83800-52F80 ----> 83800-52F30 ..fingers cross
Old 08-18-2010, 01:52 PM   #66
83800-52F30 is Canada/Mexico 06-07 for non-ABS, so it will work on yours and will be in KM.
Old 08-19-2010, 03:55 AM   #67
ricepower
ricepower's Avatar
Thumbs up
I think it has the ABS..this is the description i got from toyodiy.com
83800-52F30
NCP93..MTM..CND; WITH 15 INCH DISC WHEEL & CRUISE CONTROL & ABS(ANTI-LOCK BRK SYSTM)-WITH(WITHOUT BRAKE ASSIST)
Old 08-24-2010, 08:47 AM   #68
ricepower
ricepower's Avatar
Thumbs up
My new sedan instrument cluster 83800-52F30
My old instrument cluster 83800-52F80
Many thanks to ebay seller LKQ
Old 08-24-2010, 08:53 PM   #69
CB900F2
Drives: 08 Sedan
du2efs... If you use a flash light on the cluster, can you see the outline of the "Cruise" control logo on the cluster??.. It should be near the top right side of the speedo..
CB900F2 is offline   Reply With Quote
Old 08-25-2010, 10:32 AM   #70
ricepower
ricepower's Avatar
the cluster p/n 83800-52F30 I got has no cruise control led or indicator. I have checked the PCB, no resistor and smt led. :(
Old 08-28-2010, 11:19 AM   #71
ricepower
ricepower's Avatar
Exclamation
I noticed that the Illumination(dial and pointer) is not working after the swap. Everything else is working except the dial pointer illumination.
I have compared the cluster ecu board part by part and its same.Probably the programming is different as i tried to swap the ecu board with the tach and non-tach, the dial and ponter lights works but the tach and speedo is not working.
Last resort is to jumper the clock backlight to the pointer and dial.
Old 11-27-2010, 01:39 PM   #72
darkMINI
Drives: 08 hatch
Before you swapped the ECU was it just the Tach dial and pointer not illuminating, or both the Speedo and Tach dials/pointers?
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Installing Speedhut tach, need help! RedRide DIY / Maintenance / Service 2 07-05-2009 04:02 PM
Canada tach in a US Yaris LB tiksman DIY / Maintenance / Service 49 02-27-2007 02:40 AM
